It is currently Thu Jan 18, 2018 11:15 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Mon Dec 10, 2012 9:24 pm
All the people saying don't use it are welcome to send me their carbon parts with minor cosmetic damage.
Blog: http://thesetbackpost.com/
PostPosted: Mon Dec 10, 2012 11:00 pm
This looks exactly the same as the "printing" I've gotten on every single pair of carbon bars I've used at the clamping point. I haven't seen it on my carbon seat posts though.
Democracy dies in darkness. It's not fake news just because it's not flattering, Trump.
PostPosted: Tue Dec 11, 2012 4:38 am
While I wouldn't care to take a chance with my "undercarriage" in case the SP should break, since you asked have you tried tapping the post there with a metalic object at the area in question and elsewhere to listen for differences in sound that might suggest the area in question is "soft"??
PostPosted: Tue Dec 11, 2012 5:30 am
If you do plan on using it, I'd still sand down the gouge as to remove any possibility of a stress riser there. Also, I would round off the edges of the seat tube split and the top edge as well. Emery cloth or jeweler's files work well for this.
PostPosted: Tue Dec 11, 2012 9:46 am
+1
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Tue Dec 11, 2012 10:15 am
I fixed one of my pupil's posts that was like this. Looked exactly the same from the outside.
Simple test:
Get a bright light and look at it inside. Any deviation inside at the same place means it's failed. If the wall over that zone is uniform inside it's probably fine.
My pupil's one had a small deviation so I knew the tube had started to fail. I roughened the inner surface and epoxied a reasonably thick UD patch over the zone and pressurized it into place using an old bike tube and many layers of cellotape as a make-shift bladder. Worked a treat. The "dimple" that remained on the exterior was filled using epoxy resin then sanded flat and given a couple of coats of clear. You couldn't tell it had ever been touched and the deformation never recurred. It lasted for ages and was still functional when he replaced the pillar with a longer one.
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
There are no new unread posts for this topic. 3T handlebars with stem imprint. Safe to ride?
Mep
31
4066
Sat Jun 17, 2017 6:00 pm
bikemaniack View the latest post
There are no new unread posts for this topic. Attachment(s) Simple, safe and tough components that save weight.
Lewn777
26
4057
Sat Jun 24, 2017 2:14 am
BikeAnon View the latest post
There are no new unread posts for this topic. Looking for 30.9 seatpost
dbnm
Sun Sep 24, 2017 2:52 am
silvalis View the latest post
There are no new unread posts for this topic. 20mm Seatpost vs 5mm
p3dalfaster
Thu Jun 08, 2017 10:01 am
2lo8 View the latest post
There are no new unread posts for this topic. Ti seatpost in a Ti frame?
taztaylortaz
Sun Nov 26, 2017 8:16 am
TonyM View the latest post
Users browsing this forum: bilwit, Bing [Bot], buhx2, indrek, micky and 49 guests
