Rotor 3D Cranks compatibility with Shimano BB86 BB
Lucas1234
by Lucas1234
I have the opportunity to but a Giant TCR Advanced for 650 dollars but the bottom bracket is BB86 can I use the Rotor crank with the Shimano BB86 bottom bracket?
istigatrice
by istigatrice
I can't find the link, but I remember that it does work, but with the Rotor BB86 BB, not sure about compatibility with the Shimano BB though
I write the weightweenies blog, hope you like it :)
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
thisisatest
by thisisatest
As long as it is not the 3d+, but the regular 3d, it will work. Rotor 3d cranks fit the same as Shimano, they are cross-compatible.
Omiar
by Omiar
Yes, the 3D works with regular BB86 bottom bracket cups. The 3D+ needs special bottom bracket cups which are currently only made by Rotor itself.
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
JamieL
by JamieL
I was under the impression that the Rotor 3D+ would work with the Zipp Vumaquad BSA68 bottom bracket. I hope so or i'll have to get one of those Rotor ones when my Power2max get delivered. Anyone out there able to confirm this?
thisisatest
by thisisatest
3d+ will work with vumaquad cups.
ms6073
by ms6073
thisisatest wrote:3d+ will work with vumaquad cups.
But Vumaquad cups will not work for the OP's Giant TCR with a BB86 bottom bracket. 8)
ultyguy
by ultyguy
Hi all, bump here....link above seems to suggest that 3D+ will work with Shimano BB86 (Scott, Giant) if you use 4130 pressfit cups, right?
JensW
by JensW
ultyguy wrote:Hi all, bump here....link above seems to suggest that 3D+ will work with Shimano BB86 (Scott, Giant) if you use 4130 pressfit cups, right?
yes thats sounds right
rcb78
by rcb78
I can confirm that you can also use an FSA 386evo to PF86 bottom bracket for the 3D+. The overall width is slightly less so I did have add about 1 or 2 mm worth of shims but it works perfectly. Much better price and easier for your LBS to source.
ultyguy
by ultyguy
Nice one!
