It is currently Thu Oct 19, 2017 11:01 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sun Dec 02, 2012 2:24 am
Hi all,
I saw a pic of some DIY hydraulic brakes a pro mechanic whipped up that were alot more sleek than a black box under the stem :shock: But i cant seem to track down the site :evil: anyway i was just curious if any WW have come up with a DIY alternative to the big name versions?
Thanks!
PostPosted: Mon Dec 03, 2012 4:08 pm
DIY hydraulic is not something you just hack together in a weekend. I'd be surprised to see a homemade solution :beerchug:
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Mon Dec 03, 2012 5:53 pm
Was it The future of cyclo-cross - disc brakes? that describes using the USE converter unveiled at Eurobike in 2011?
PostPosted: Mon Dec 03, 2012 9:23 pm
Are you talking about that guy from ibis bikes who modified a pair of formula levers so that they were actuated by the cables in the road brakes? i don't remember the particulars, but they had to be cut down to accomodate the setup, but he raced masters singlespeed on them without problem. i think the other odd part of his setup was he was running a carbon tranyn frame with 'cross wheels and tires rather than 26" wheels.
PostPosted: Tue Dec 04, 2012 1:18 am
That USE set-up is beautiful! I doubt it'll ever be available though.
PostPosted: Tue Dec 04, 2012 5:37 am
Yup the USE set-up was it! i thought it was thrown together DIY, but anyhow, i'm a fan of those, much prettier than the parabox.
Thanks for the responses! :beerchug:
PostPosted: Tue Dec 04, 2012 7:30 pm
That USE set up is pure sex, BUT what is the silver bullet which converts cable pull to a master hydraulic cylinder? That's not some off the shelf part from another application. That looks highly specialized for this purpose.
But wow is it sublime :-) I like it.
PostPosted: Tue Dec 04, 2012 11:11 pm
Santana tandems have had a part like that for years that converts Shimano sis liver pull to hydraulic to operate a rear disc brake. The part appears to be the same size.
For certain parts stiffer is more important than lighter.
PostPosted: Wed Dec 05, 2012 12:56 am
Got a link? I looked at the site and only found references for Avid, Bengal, and Winzip mechanical discs.
PostPosted: Wed Dec 05, 2012 1:14 am
My Santana is a 2004 and they used that system through the 2000-2009 era, but apparently converted to using mechanical discs in later years. There were problems with bleeding and adjustment and some tandem owners in my era converted their bikes to Avid bb7 mechanical discs.
http://santanatandem.com/Library/Adjustable.pdf
The first item on page 2. The cable comes in from the left and the hydro hose goes out the right. Santana had a little welded attachment on the downtube right behind the steer tube and it was hydro the rest of the way back. Also the part that stuck out the top was a fluid reservoir and probably would not need to be that tall on something for a cross bike with much smaller caliper pucks. These things were made by Formula for Santana as far as I know. I just went out and looked at mine and it says Formula on it in red. I have an extra one of these that I bought as backup in case ours ever failed if you want to experiment. I would part with it for $150 which is way less than Santana sold them for.
PostPosted: Wed Dec 05, 2012 4:57 pm
Great manual. I love manuals written by people with:
a) an enducation
b) a good grasp of the language the manual is written in
c) a sense of humour
There used to be more documents like this in cycling before the lawyers took over. I have a 1994 manual that came with a Fat Chance Wicked frameset I bought, bizarrely written.
There are no new unread posts for this topic. hydraulic brakes tutorial
emorydptt
Thu Jan 19, 2017 12:46 am
emorydptt View the latest post
in MTB
emorydptt
Thu Jan 19, 2017 12:45 am
There are no new unread posts for this topic. TT shifters (Di2) and hydraulic brakes (how do i make this?)
wheelsONfire
Sun Nov 13, 2016 8:15 pm
wingguy View the latest post
There are no new unread posts for this topic. New SRAM Red ETAP HRD Hydraulic Disc Groupset / Wifli + Post Mount Brakes
stefanot
Mon Jul 10, 2017 5:17 pm
stefanot View the latest post
There are no new unread posts for this topic. Cross Mechanical Disk on full carbon setup. Recomendations for Lightest Brakes?
[ Go to page: 1 2 3 4 ]
RoosterWheels
51
4264
Fri Jun 02, 2017 6:35 pm
joejack951 View the latest post
Users browsing this forum: grover and 4 guests
