It is currently Sat Dec 16, 2017 2:34 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Thu Nov 29, 2012 3:17 pm
Just ordered a C260 stem and subsequently read a review regarding the installation. Seems the 260* wrap-around clamping section means installation works like an old quill-style stem, "threading" the naked bar through the stem, not just simply removing the faceplate and poping it in.
Has anyone managed to do this with a 3T Ergonova Team? I'm worried about clearing the fat, flat top section of the bar.
2012 SuperSix - 6.30kg
PostPosted: Thu Nov 29, 2012 4:33 pm
Haven't tried with those bars specifically, but the Ritchey ergo bars go in. You do have to be rather creative on the installation of it, and it will require a bare handlebar. If you're planning on swapping out your cockpit a bunch, I would advise against it
PostPosted: Thu Nov 29, 2012 4:40 pm
I have this exact setup, C260 stem and Ergonova bars. On my set, the stem scratched the bars over the flat top section of the bars, mostly under the where the bar tape would go but some of the scratches would show. There was no way to install the stem without scratching the bars. This was with the stem and bars completely bare off the bike. I ended up removing all the paint from the bars, installing the stem and then clearing the bare carbon with the stem attached. Looks cool now bare but impossible to make any changes without ruining the finish.
PostPosted: Thu Nov 29, 2012 4:45 pm
That's what I was afraid of - thanks for the reply. I will send the stem back - I'm on a Vibe 7S and have no issues with it per se, just wanted to shave a little weight.
PostPosted: Thu Nov 29, 2012 6:33 pm
No problem. The stem is very light, got it down to 100g with Ti bolts for a 110mm length.
PostPosted: Thu Nov 29, 2012 11:14 pm
Sweet - that's where I wanted to get. My Vibe is 128g for 120mm length with Ti bolts. I like the Ergonovas too much to get rid of them just for a stem.
PostPosted: Thu Nov 29, 2012 11:55 pm
Try sanding the edges (of the stem) a little bit before you toss it out; just getting rid of some of the paint and rough edges may be enough to allow the bar a smooth passage and will help with limiting the amount of cuts, scratches etc. on the bar.
Storck Fenomalist 6.8kg
PostPosted: Fri Nov 30, 2012 12:56 am
that stem did not scratch my zipp carbon sl 31.6 bars, i am not say that our bars are the same. I just took the tape off and turn it like the directions tell you to and go slow and it was good to go. the stem is light, i also have the 110 and it came in at 105 grams with the stock bolts.
PostPosted: Fri Nov 30, 2012 3:04 am
...not to mention putting some masking or other tape on bars at entry point to avoid scratching on these harder to fit bars. EM3
______________
PostPosted: Sun Dec 02, 2012 12:48 pm
I had already sanded down my bars and re-clearcoated but managed to slip it on without scratching. I have the carbon wrap version and with ti bolts it is 117 for 120mm.
PostPosted: Sun Dec 02, 2012 4:27 pm
I had this stem for a little while. Decided it wasnt worth the risk of scratching the bars, so opted for the Extralite. 110mm comes in at 86g. New ultimate stem is supposedly pretty light as well.
PostPosted: Thu Dec 13, 2012 7:18 pm
Do you find the Extralite stiff "enough". Very subjective, but did you notice any decrease moving from the stem you had before?
PostPosted: Thu Dec 13, 2012 7:31 pm
The Deda Zero 100 weighs in at about the same and can be had for about $75. Personally I am running the Zipp Corse SL and got it down to about 110g w/ ti bolts and it cost me $70 (came in black as well). No way in hell the C260 would fit around my new ITM Pathom bar though.
Cannondale Synapse (alu)...it works
There are no new unread posts for this topic. Ergonova discontinued?
Zakalwe
15
3489
Sun Mar 12, 2017 5:12 pm
spliid View the latest post
There are no new unread posts for this topic. 3T Ergonova/Ernova
Geordiepaul
Wed Sep 27, 2017 7:52 pm
corky View the latest post
There are no new unread posts for this topic. Ritchey wheels
Tubby16
Tue Dec 20, 2016 8:16 am
Tubby16 View the latest post
There are no new unread posts for this topic. Ritchey Road Logic as second bike..
3Pio
40
2594
Sun Dec 10, 2017 5:49 am
CLEAR View the latest post
There are no new unread posts for this topic. Ritchey NeoClassic so close to perfect but not quite...
xcnick
30
2355
Mon Sep 04, 2017 7:42 pm
BdaGhisallo View the latest post
Users browsing this forum: Autriche, Google Adsense [Bot], jmagoulas, renoracing and 39 guests
