It is currently Wed Dec 13, 2017 6:42 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Nov 16, 2012 12:07 am
Hi All,
I am looking for procedure or tips on how to install new carbon fibre blades (springs) on Look KEO blade. Is there a trick to do it or do I have to muscle it in with my fingers?
My C59 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=80193
PostPosted: Fri Nov 16, 2012 12:21 am
There's a special tool to do it that some bike shops have. It's expensive to buy so best get them to do it.
PostPosted: Fri Nov 16, 2012 1:27 am
Unscrew the hinge of the rear door and pull it out. The blade just falls off then. Install in reverse. I've never seen the tool, only heard about one, but have swapped many blades.
PostPosted: Fri Nov 16, 2012 1:40 am
Cheers thisisatest! Very useful to know.
PostPosted: Fri Nov 16, 2012 2:27 am
thisisatest :thumbup:
PostPosted: Fri Nov 16, 2012 3:41 am
If you don't mind the slight derailment, can I ask why you're replacing? Did a previous blade break? (If so, how?)
PostPosted: Fri Nov 16, 2012 4:18 am
Yes it broke. I was crossing busy intersection (from red light) and when I tried to clip in I put my foot on the other side of the pedal and pressed with full force to get of the intersection ASAP (big pick up truck was coming my way) and my foot slipped of the pedal. When I got home I noticed that blade was delaminated and one of the layers was cracked. I think when I stomped on it with my shoe it bent the other way and it cracked.
PostPosted: Fri Nov 16, 2012 10:52 am
I wonder if that's how some of the other breakages have occurred without people realising what they've done.
PostPosted: Sun Nov 18, 2012 6:46 am
Thanks for the update. I will be careful not to repeat your mistake!
There are no new unread posts for this topic. Look pedal washers and Keo Blade 2
liam7020
Wed Jan 25, 2017 1:03 am
liam7020 View the latest post
There are no new unread posts for this topic. Cervelo S5 replacement
brycerider
23
2465
Thu Jun 22, 2017 8:55 am
brycerider View the latest post
There are no new unread posts for this topic. Tire replacement - tube also?
mvcap
9
907
Sun Jan 08, 2017 8:24 pm
RussellS View the latest post
There are no new unread posts for this topic. Supersix Evo braze on replacement
nickf
Tue Aug 01, 2017 9:13 pm
androidavies View the latest post
There are no new unread posts for this topic. Assos Air Jacket 851 Replacement
joeyb1000
Tue Aug 01, 2017 10:51 am
kgt View the latest post
Users browsing this forum: Google Adsense [Bot], phm8147, survivor and 30 guests
