It is currently Mon Dec 18, 2017 4:34 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
 Post subject: Challenge "Eroica" tyres
PostPosted: Wed Nov 07, 2012 11:02 am
Just found out about Challenge's new "Eroica" model the other day, a 30mm gravel tyre as the name suggests. Since their "Paris Roubaix" (much like Vittoria's Pavé) doesn't have a great puncture protection reputation, I'd be interested if this one might be better. (Would be fun to ride tubs on gravel too, but don't want to flat out in the woods.)
Unfortunately Challenge has not yet answered my request whether the puncture protection layer of the Eroica was stronger than their P-R's. Does anyone here have some info already? @challenge, I'm looking at you :-)
PostPosted: Wed Nov 07, 2012 8:38 pm
30mm? My FMB Paris-Roubaix is touching the fork and almost frame. Is there any frame/fork/brakeset that will work with 30mm?
Real 30mm then, my 27mm FMB is 28,2 wide. Not like Continental GP 4 Season 28 that was 25,3 wide on a wheel.
/jonas l
PostPosted: Thu Nov 08, 2012 4:45 am
I have a pair of 30mm gran bois tires (clinchers) I use on a touring frame. These tires are really more like 32mm. Ican fit the front on my enve 1.0 fork with zero clearance on the top. I've thought about fitting brass shims in the dropouts to give more clearance. It looks like the wheel could move down 2 mm and still have the QR and hub be contacting the dropout. I doubt i'll do it but if a road fork was made to have the brake pads at the very bottom of of the adjustment range their would be plenty of clearance.
PostPosted: Thu Nov 08, 2012 3:48 pm
info@challengetech.it wrote:
Eroica have a thicker tread and wider PPS than Parigi Roubaix.
So I'm assuming the PPS thickness is the same, but thicker thread will help too.
As regards volume, I would think that they tested it to clear most common frames and brakes?
PostPosted: Fri Nov 09, 2012 2:50 am
Tubbie Guru
Hi,
It's common practice for tyre manufacturers to share the same puncture protection belt across the board. They just have it cut to the correct width for the tyre and that's it.
Ciao, ;)
PostPosted: Fri Nov 09, 2012 11:21 am
fdegrove, so what do you think are the chances that the Eroica is just a P-R casing with more rubber and a wider PPS? P-R is said to be around 29mm in reality, so it's not worlds apart.
PostPosted: Fri Nov 09, 2012 12:18 pm
Tubbie Guru
Hi,
Quite likely it's just that indeed.
Ciao, ;)
PostPosted: Mon Nov 12, 2012 12:09 pm
there's more to the world than short-reach brakes
PostPosted: Mon Nov 12, 2012 12:53 pm
I recently fitted a Hutchinson CX tire (33-34mm) in a Merckx Strada O.S. frameset and it fit.
My Renovo R1 wooden bike project and the reason for my passion for all that is wood.
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Tue Nov 13, 2012 5:17 am
I'm sure stuff like that happens, but it would be pretty dissapointing if they market the PR as 27 and the eroica as 30 when both are the same casing.
PostPosted: Tue Nov 13, 2012 10:49 am
Tubbie Guru
Hi,
I really don't see why that would be such a big deal.
Ciao, ;)
PostPosted: Tue Nov 13, 2012 2:36 pm
It wouldn't be a big deal, but it would be nice if mfg can get simple things like size, weight, color, etc correct.
PostPosted: Wed Nov 14, 2012 8:39 am
Tried to mount some P-R's on my scott cr1 and the rear was rubbing the top of the rear stay bridge. The pro4's I have on the way, 25mm but I think reviews say they're more like 26.5 should be just peachy (i hope).
The PR i mounted was my buddy's who use to work for Challenge and been riding their tires for the last few years as team issue stuff, he doesn't have a whole lot of faith in the new Eroica tires as far as durability...
PostPosted: Thu Nov 29, 2012 3:00 pm
Challenge confirmed that the PPS thickness was the same as in the P-R models (but wider, as said above).
Really tempted to try this in spring., or maybe Vittoria Pavé.
PostPosted: Wed Jan 09, 2013 2:05 pm
A fellow weightweenie's (mounting) experience with the Eroica clinchers: http://ridingthecatskills.com/2012/12/1 ... ica-tight/
There are no new unread posts for this topic. the weight of air in our tyres
Delorre
13
2344
Fri Jan 20, 2017 3:29 pm
964Cup View the latest post
There are no new unread posts for this topic. Colnago C60 winter tyres
plook
Tue Nov 07, 2017 11:19 pm
shipley View the latest post
There are no new unread posts for this topic. Aging tan wall tyres?
PLuKE
7
558
Fri Nov 17, 2017 11:51 pm
PLuKE View the latest post
There are no new unread posts for this topic. Bontrager R4 Tubular tyres - views?
campagowlo
Mon Apr 17, 2017 7:41 pm
russianbear View the latest post
There are no new unread posts for this topic. Fast, light 700x20c tyres / tires?
kman
Mon Jan 02, 2017 11:44 am
kman View the latest post
Users browsing this forum: Baidu [Spider], kookie, nick312, spdntrxi, wheelbuilder and 36 guests
