Tuned Pedals called PlaySpeed if you reversed the name...
dereksmalls
by dereksmalls
I see the official version is actually going to be released to the public in January - according to Bikerumour.com. No indication of their weight but $400 - $600 depending on steel or ti axles. :shock: I'm still well happy with my custom pair
voodoojar
by voodoojar
so how much does the cleat weigh?
drmutley
by drmutley
From wiggles Facebook page today... "Coming Soon"...
weeracerweenie
by weeracerweenie
Pfffft been there done that... Bikerumour covered it but the article wasnt massively enlightening :noidea:
I guess there's worse hobbies than making a bike light? Right?
Rick
by Rick
With the aluminum body at 90 degrees to the bowties, perhaps it eliminates the plastic cleat body wear which would also alleviate the lateral rocking issue that some people have.
Might be a significant improvement even if you don't need the mor open style "Pave" mud shedding features.
dereksmalls
by dereksmalls
The pictures in the Wiggle shot there actually differ fromthe pictures from ones in the bikerumour article. Image Notice the raised contact points on bearing covers and the the pedal end looks more cut off and blunt in comparison. The Wiggle shots are the original ones that Speedplay designed
Rick
by Rick
Aha! Note how the pedal contact points at 90 degrees to the bowties have been flattened to give a high-durability cleat contact point.
Me very interested now. I switched from SPDPLY to DA last year, but I am getting tired of my poor ability to clip in quickly.
Maybe not so interested after I read this:
The price reflects the amount of machining time needed to make each pedal with Stainless axle versions listed at $400 and titanium axles at $600. :evil:
shimmeD
by shimmeD
Not at that price for me either.
I'm checking out Bebop next. I like Speedplay but Bebop may last longer, at the expense of a little bit of stack and adjustability of float amount.
Less is more.
Kraaf
by Kraaf
Now you've gone and said it...
I love you guys. Seriously.
odin99
by odin99
saw them at interbike. the guy said they actually weigh in a few grams more than the normal zer0 version.
eljimberino
by eljimberino
Rick wrote:Aha! Note how the pedal contact points at 90 degrees to the bowties have been flattened to give a high-durability cleat contact point.
Hi Rick,
Did you make any progress on the lateral rocking issue and the new pave pedals?
Thank you
mambo
by mambo
I currently use bebops and like them. They do take some getting used to but the pedals seem practically indestructible. These are well worth a look. The guys who purchased these a decade or more ago still swear by them and a few actually banded together to make replacement cleats (though it seems the cleats last for years) and it seems as if they have just gone back into production.
http://www.coombe.com/millennium_pedal_features.html
I think they make a great alternative if like me you prefer not to buy from speedplay.
Owner Cicli Schiavona - hand made, custom Italian carbon frames at prices you won't believe!
www.ciclischiavona.com
https://www.facebook.com/pages/Cicli-Sc ... 8745538716
eljimberino
by eljimberino
Hi Mambo,
I have emailed Coombe about how to determine which coloured line cleat to purchase. Am I missing this info their website?
Do you recommend buying an extra cleat or two when you buy, or do they really last ages?
Thank you
Rick
by Rick
eljimberino wrote:Hi Rick,
Thank you
I never tried them; I am still on the Dura Ace.
If you want my reasoning:
I like speedplay, and I never really had any serious "rocking" issues that I could feel while riding, but I did note that there was wear that allowed rocking. It seems like a combination of cleat and pedal body wear. So the two most attractive features were the float and the low weight. At one time SPDPLY had an enormous weight advantage, but over the years everyone else seems to have caught up, so even DA is not that much heavier. And although I like foat, I apparently don't need it because my legs have been fine on DA, even with the blue cleats. DA are relatively dirt cheap, rock solid, , the bearings are THE BEST, and the cleats wear FOREVER. I only change them because they end up looking ugly.
With three active bikes, I can get DA, ultegra, and 105, and they all function identically and flawlessly for dirt cheap. If I tried to outfit three bikes with Pave', I would have to cancel my vacations.
So, like all things, there are a series of tradeoffs. I am not a SPDPY "hater", and if you really need float, they are still a great choice. Time also has some good float from what I've heard, but I have never used them.
Squint
by Squint
Code: Select all
                            A         B         C
medial shoulder thickness   17.00 mm  16.39     16.96
lateral shoulder            16.95     16.79     16.91
bowtie thickness            2.77      2.77      2.77
Pedal A: Zero. brand new.
Pedal B: Zero. Oldest pedal. Severe rolling. PTFE shim used for 1/2 to 2/3s of its life.
Pedal C: Zero. Several years old. Severe rolling. Used exclusively with PTFE shim.
