Cannondale Headset help
by dane476
I've got a cannondale carbon six frame, just brought it to build a training bike, and have no idea on the headset, currently has a cane creek is24 but can't find anything about it anywhere, had the bearings out and both top and bottom say 1 1/8, 36 x 45, is this a standard integrated system?? Just checking before I buy anything? Which headsets would be compatible??
by em3
by dane476
Anyone else??? Cane creek doesn't have the six on there
by thisisatest
36*45 is standard I.S.. if it also says 41.8, or measures 41.8mm as the outside diameter, then it's an "in-betweener", a mix of I.S. and Campy fitment. Sweet, huh? It's a way some companies have been making bearings to install into Campy-fit frames, but to use I.S. crown race, compression ring, top cone...
So first, measure the diameter of the largest part of the hole in the head tube. If it's 41.0mm, then it's all IS. Get an IS headset or just the bearings.
If it's 41.8mm, the FRAME is campy-fit. If you're replacing the whole headset, just get a campy-fit headset, no problems. If you were hoping to just replace bearings in this situation, it may be more trouble than its worth.
