It is currently Mon Jan 22, 2018 1:48 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Oct 26, 2012 12:42 am
I am looking for some help. I installed a new BB30 Sram Red Quarq 50X34 on a Boardman 9.81 today. The first thing I found that it the chainrings sat way to far out and the chain line is out of wack. On this set-up there is 2 nylon/plastic spacers, one on the drive size that is 12mm wide and one that sits between the NDS crank and bearing pre-loader. There is no way I can get this to work. I was on the phone with Quarq, though they were very helpfull couldn't get this figured out.
Is there any one that has installed this new Red Quarq have similar issues?
PostPosted: Fri Oct 26, 2012 1:18 am
Can you show us a picture? It sounds like you have it installed correctly...
Edit: How does the bearing adjuster look? Were you able to preload the bearings with it? Also make sure that the bearing shields are the correct ones. PF30 and BB30 are different.
PostPosted: Fri Oct 26, 2012 11:16 am
Yes, all that is correct.
PostPosted: Fri Oct 26, 2012 3:09 pm
fwiw with the sram 2010 s975 srm, the fitting instructions were the same as the ones for normal red cranks
maybe the 2012 crank instructions will help figure it out...
http://cdn.sram.com/cdn/farfuture/lSlIBkjFhi-5ho4VoiqLvZsW0KdjrTt4vv0gC5A4P8w/mtime:1327445280/sites/default/files/techdocs/95-6115-012-000_rev_b_red_cranksets.pdf
is there any side-side play? with my s975 it was possible to slightly misalign the shaft, so that it felt like it was fully seated but wasn't, this causes the cranks to end up too far apart
PostPosted: Fri Oct 26, 2012 5:46 pm
Have you tried another crankset on the bike and measured the chainline differences from that crank to the SRAM Red Quarq? We just spoke to a guy at SRAM's dealer service and he also assured us that the chainline of the regular SRAM BB30 cranks and our SRAM Red Quarq BB30 cranks should be very similar.
It sounds like you are installing it correctly. It does look at bit unique with the spacer on the drive side, but that is how they are supposed to be. The SRAM Red BB30 Quarq cranks are different from the regular SRAM Red cranks in that the regular SRAM Red BB30 cranks have a shorter spindle and do not have the drive side spacer like our cranks. That extra space where we have to use a spacer is taken up on the regular SRAM Red BB30 cranks in the inherent spider / spindle design.
Pete Jacobs, 2012 Ironman champion has a Boardman bike with a SRAM Red BB30 Quarq so we would expect this setup to also work on your bike as well: http://www.slowtwitch.com/Products/Tri_Bike_by_brand/Pete_Jacob_s_Boardman_AiR_3161.html
I'm not sure if our tech showed you the link on our website to the Red Quarq BB30 installation addendum: http://www.quarq.com/i/95-6118-004-000_REV_A_RED_Quarq_BB30_IA_Addendum.pdf
Mieke
Quarq Technology
PostPosted: Fri Oct 26, 2012 10:33 pm
Yes, I installed another BB30 and the chain line did not change.. [b]so It is in the design of the bike[/b]. I have never seen anything as severe as on this Boardman. I found another thread about the Boardman 9.81 with chain line issues similar to what I have been experiencing. It is quite severe in the big ring and largest cog in back.
Thanks everyone
PostPosted: Fri Sep 16, 2016 11:17 pm
Hi,
Just re-activating a very old thread.. :)
I just bought a 2016 Boardman Air 9.8 and have fitted my Quarg red22 BB30 Power meter on it. I am experiencing the exact same issues as you have - The chainline is off by a wide margin. I have to be in the 2-3 smallest cogs in the back to get a decent line.
- Did anyone find a decent solution to the problem?
I am considering replacing the wide driveside spacer with something 5-6 mm narrower, and adding the same amount of spacers on the ND side instead - Not a pretty solution, but I dont see any other way?
kind regards
Christian
PostPosted: Sun Sep 18, 2016 7:10 pm
I am not sure if you SHOULD have to do it, or if the fault is in the cranks or frame (most likely the frame). But it is pretty simple to adjust chainline with spacers sold by Wheels Manufacturing and purchasable on ebay.
In fact, I have just done that recently on one of my old bikes. I also used them to make sure that the Q is completely symmetric, Left & Right.
PostPosted: Mon Oct 03, 2016 9:03 pm
Well I have now moved the chainrings inwards by 2.5mm by adding spacers on the NDS and exchanging the 13mm standard spacer on the drive side with smaller spacers..
Seems to work well on the work stand, now with a much nicer chain line.
If you look closely you can detect the slightly different spacing between the crankarms and the frame on either side, and thereby the different Q-factor - but hopefully the shift towards the NDS is so small, that it wont mean to much for my pedal position and cause knee issues or other nasty things..
christian
There are no new unread posts for this topic. Cannondale Quarq Installation Issues
58teeth
10
582
Fri Jan 05, 2018 3:26 pm
58teeth View the latest post
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 6 ]
Shrike
75
12074
Thu Dec 14, 2017 7:12 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. eTap cross chain issues?
possibleweenie
Sat Jul 08, 2017 10:13 pm
possibleweenie View the latest post
There are no new unread posts for this topic. Quarq DZero Spider Sram Rotor compatibility
Jian81
Sun Dec 17, 2017 7:02 am
dre_lo82 View the latest post
There are no new unread posts for this topic. needing help Quarq cranks Sram and rotor, swapping them between bikes.
charlie0
Sat Sep 30, 2017 12:12 am
alcatraz View the latest post
Users browsing this forum: Bing [Bot], HammerTime2, joe1234, nickf, Rioken, Tohan and 38 guests
