It is currently Thu Jan 18, 2018 7:07 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Oct 25, 2012 1:04 pm
I have a new carbon MTB frame with gloss paint that I would like to protect (at least the underside of the tubes) and am wondering what kind of tape you would suggest. I am located in the US and would also appreciate a supplier suggestion.
Thanks!
PostPosted: Thu Oct 25, 2012 1:21 pm
Helicopter tape
PostPosted: Thu Oct 25, 2012 2:18 pm
Thanks!
you can use a 3M material that they use for cars...clearbra. you can get a small roll from griotsgarage.com
http://www.griotsgarage.com/product/pro ... y=ourPicks
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Thu Oct 25, 2012 2:32 pm
I used hockey tape, the one you wrap pads and skates with, it does a great job, check out my vertex 2013 in my sig, I put some on the downtube
PostPosted: Thu Oct 25, 2012 4:45 pm
Thanks for the ideas. I have also been suggested to use 3M Scotch 2228 and also ICS Racer's Tape.
PostPosted: Thu Oct 25, 2012 5:18 pm
I use One Industries clear number plate background for Motocross bikes. You get 3 12" x 18" sheets per pack. Any offroad motorcycle shop can get this for you. Stay away from N-Style, Factory Effex, etc. their glue is not as good as the One Ind. stuff. After you clean your frame, do a final prep with alcohol, do it in the warmest dust free room you have, use a hair drier to pre-heat the frame & clear tape. When finished leave it in a warm room for 24 hours before riding.
PostPosted: Fri Oct 26, 2012 3:07 am
I use Crankskins. It is essentially the same 3M tape listed above, but you get it cut to specific sizes for you. It turns out being a bit cheaper then buying it from Griot's.
PostPosted: Wed Nov 07, 2012 8:31 pm
I use Bikeshield kit to protect de frame.
PostPosted: Wed Nov 07, 2012 8:44 pm
The best :wink:
http://perso.orange.fr/courirenmontagne
PostPosted: Wed Nov 07, 2012 10:45 pm
It's not exactly tape, but Frame Defender has out a kit with a bunch of different sized pads. They protect but also absorb the impact making it different from other things that just deflect.
http://www.framedefender.com
PostPosted: Wed Nov 07, 2012 10:53 pm
Sheesh and I thought this was weight weenies - all that heavy tape and stuff! :D
PostPosted: Thu Nov 08, 2012 6:23 am
http://www.veloskin.com
thin, easy to install around tubes and tough
There are no new unread posts for this topic. "Helicopter" tape removal from frame
Leviathan
7
1024
Tue May 23, 2017 2:11 am
audiophilitis View the latest post
There are no new unread posts for this topic. Attachment(s) Anyway to install bar tape without using electric tape?
Noctiluxx
19
1029
Tue Jan 16, 2018 10:17 am
jacobeh View the latest post
There are no new unread posts for this topic. Attachment(s) Rim tape check
possibleweenie
7
643
Thu Aug 24, 2017 11:56 am
Marin View the latest post
There are no new unread posts for this topic. Tape instead of hoods?
whydobearsxplod
13
1457
Fri Sep 29, 2017 4:46 pm
whydobearsxplod View the latest post
There are no new unread posts for this topic. lightweight rim tape?
in Everything wheels
addictR1
20
1827
Sat Jun 10, 2017 3:06 am
BikeAnon View the latest post
Users browsing this forum: No registered users and 5 guests
