It is currently Thu Dec 14, 2017 11:56 pm
Post new topic  Reply to topic  [ 85 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Sat Nov 10, 2012 8:31 pm
tiquitain wrote:
Which headset spacers will fit the R5? because its 1-3/8" fork
It's tapered steerer tube. Bottom 1 3/8", top standard 1 1/8", so that gives you a pretty good choice of spacers :wink:
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Sun Nov 11, 2012 2:53 am
That crank you're describing is their S900/950/975 or derivative. It is not a "pure" bb30, it is bb30 compatible with its 30mm spindle. Those cranks mentioned have about 90mm of spindle between the arms, as opposed to 69-70mm. Sram red, New red, force (with built-in, non-removable spiders) will not fit bbright.
PostPosted: Sun Nov 11, 2012 3:03 am
According to Damon Ricard, new Red should work on BBright
http://forum.slowtwitch.com/cgi-bin/gfo ... 12#4269912
PostPosted: Sun Nov 11, 2012 6:34 pm
it's a good news.
Alhoa
PostPosted: Mon Nov 12, 2012 3:58 am
http://forum.slowtwitch.com/cgi-bin/gfo ... 12#4269912" onclick="window.open(this.href);return false;
Look closer. That "red" crank is the quarq variant, with separate spider. Arms may be updated, but otherwise, that crank is a direct descendant of the S900 series. Completely different animal.
PostPosted: Mon Nov 12, 2012 4:20 am
http://forum.slowtwitch.com/cgi-bin/gfo ... 12#4269912" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
+1...unless you are willing to spend over $2K for the Quark variant (the only Sram 2012/13 BB30 crank compatible with BBRight), you will not have a Red crank on your R5
______________
PostPosted: Mon Nov 12, 2012 5:41 pm
Just arrived from Royles, paid on Fri :thumbup:
In the box:
Bare frame 58
Fork 315g
Seatpost Dorico 187g
Seatpost clamp 17g (steel bolt)
Headset FSA 66g
BB Sram 85g
Alu insert with star 20g
Top cup 15g
Cable guide 5g
Cervelo S5
PostPosted: Mon Nov 12, 2012 7:12 pm
It doesn´t come with a frame chain protector sticker?
PostPosted: Mon Nov 12, 2012 7:17 pm
I find it interesting that the R5 VWD frames made in 2011 were approximately 50 grams lighter than R5 VWD frames made in 2012. I am not sure exactly when they gained weight but they gained a noticeable amount of weight. My guess is that it happened sometime in the later part of 2011. I think the same thing happened with the R3. The R5 VWD frames are still fantastic frames and are still a competitive weight considering the competition. But they don't make them like they use to.
PostPosted: Mon Nov 12, 2012 8:10 pm
Did came indeed, 3g :beerchug:
sedluk wrote:
Another comparison, the 51cm 2011 R5 frame weighed 820 grams and the fork weighed 337 grams.
Cervelo S5
PostPosted: Mon Nov 12, 2012 10:07 pm
All frames in size 51cm
2010 R3 SL about 850 grams
2011 R5 about 820 grams
Made in 2011 R5 VWD about 725 grams
Made in 2012 R5 VWD about 770 grams
R5ca about 700 grams without bearings
PostPosted: Mon Nov 12, 2012 10:29 pm
Based on that table of weights the suckers (including me) that bought R5s before the VWD models came out didn't do so badly after all. Only 50g difference compared to the 2012 models and you got a Rotor crank thrown in.
PostPosted: Mon Nov 12, 2012 11:28 pm
2011 R5 vwd? Isn't the vwd notation new for 2012?
PostPosted: Tue Nov 13, 2012 8:59 am
Vwd frames, like any other, vary in weight. I seem to remember a recent 51cm one weigh 705g, and an r5ca at the same time be either 660 or 640, can't remember exactly.
I guess I have some weighing, photographing to do in the next couple days...
PostPosted: Tue Nov 13, 2012 11:55 am
Where can I found instructions about the correct instalation of the BB of my new R5? What is necesary to mount it? Only grease?
There are no new unread posts for this topic. Increasing Drop
rossjm11
16
1070
Thu Dec 07, 2017 4:05 pm
ergott View the latest post
There are no new unread posts for this topic. carbon price per gram
Boshk
Sun Nov 05, 2017 5:35 am
zappafile123 View the latest post
There are no new unread posts for this topic. Chain drop issue
JBeauBikes2
16
1082
Mon Jul 17, 2017 8:34 pm
JBeauBikes2 View the latest post
There are no new unread posts for this topic. Bar end shifters on drop bars
ericoschmitt
Tue Dec 05, 2017 3:13 am
ericoschmitt View the latest post
This topic is locked, you cannot edit posts or make further replies. Best price for Dura Ace 9150 Upgrade kit?
Noctiluxx
Sun Jun 04, 2017 6:28 pm
Noctiluxx View the latest post
Users browsing this forum: antonioiglesius, Baidu [Spider], d36, dvq, JohnHinMD, kookie, nickf, PSJoyce, snowdevlin, sooni, Ticlimax, TobinHatesYou and 42 guests
