how do you remove a stripped bolt (top cap)
roca rule
by roca rule
just recently i removed my stem on a look 595 for inspection. the stem was fine but when i went to tighten the top cap bolt i used a 3/16" instead of a 5mm allen. i want to remove the bolt and replace it because i forgot to put a shim on the headset.
em3
by em3
If u stripped a 5mm allen head using a 3/16" wrench, uthat mrans u are applying way too much torque to ur top cap. Even using the 3/16" wrench (albeit not recommended) u could easily reach the MINIMAL torque necessary (1.5-2 Nm) to preload ur bearings. Here is a primer on how to properly adjust a threadless headset:
http://www.parktool.com/blog/repair-hel ... et-service
Try finding a crisp/new 5mm and try to fit into the stripped head or as a crude alternative a sharp edged flat head screwdriver that fits snugly withing the head might also do the trick.
EM3
______________
roca rule
by roca rule
The problem is that the bolt is recessed about 2 cm in.
Sent from my PG86100 using Tapatalk 2
artray
by artray
Tiny explosives
stella-azzurra
by stella-azzurra
Drill a small pilot hole. At the store ask for the section with the it extractors and ask what bit you need to drill with first.You shouldn't have to drill to deep. After that, use the bit extractor by hand, . Remember that it is reverse threaded so it will pull the bit out as it goes down.
the picture
em3
by em3
roca rule wrote:The problem is that the bolt is recessed about 2 cm in.
...are you talking about your headset top cap or the compression plug/insert in your fork steertube?
EM3
______________
eric
by eric
Be careful using those screw extractors. I call them ez-breaks instad of ez-outs, because you're more likely to snap it off inside the stuck screw than you are to remove the screw. Once you break it you are really screwed, as the extractor is harder than your drill bits.
You should not be putting significant torque on a headset cap screw. Loosen the stem clamps before turning the cap screw.
stella-azzurra
by stella-azzurra
If the extractor is harder than your drill bits why would it snap off? :noidea:
madmole
by madmole
Easier, get a drill bit thats wider or same width as the thread but narrower than the head and just drill down the head until it breaks off.
Remove top cap
Clamp Mole grips on remains of bolt and unscrew
Cervelo S3 2011. Blinged 6.718 Kg
artray
by artray
Nanobots ?
eric
by eric
stella-azzurra wrote:If the extractor is harder than your drill bits why would it snap off? :noidea:
Hard steel is brittle.
stella-azzurra
by stella-azzurra
Eric, extractors are made to extract bolts. This is a puny top cap bolt which is low torque. We are not talking about a rusted bolt that is seized. Please.
BobSantini
by BobSantini
r o y g b i v
canbakay
by canbakay
Before all this try a less aggressive method,
Remove handlebar, loosen stem bolts and keep turning the stem - the top cap and it's bolt will most likely come loose for you to finish off by hand.
