It is currently Wed Jan 24, 2018 12:51 pm
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Clarks Brake Cables
PostPosted: Sat Oct 20, 2012 9:20 pm
Has anyone weighed in Clarks cables against the Jagwires, for instance?
I'm currently attempting to choose between the following:
http://www.wiggle.co.uk/clarks-universa ... cable-kit/
http://www.wiggle.co.uk/jagwire-ripcord ... cable-kit/
Ultimately is there going to be much difference for a single speed build? I'm already over-budget just a tad so am trying to shave the pennies but if weight it a factor I'm probably willing to splash out a bit more.
Cheers,
Tom
 Post subject: Re: Clarks Brake Cables
PostPosted: Sat Oct 20, 2012 10:14 pm
The reason not to choose clarks is not weight. A cable of the same diameter and and length of differing brands should weight approximatley same if it all made of SS. The big differeneces are in the outers.
I don't use clarks as they are not stainless enough or at least thats my reasoning. Also I don't think there campag cables have very good ends. I quite like transfils cables and outers. Even there cheap workshop outer packs are teflon lined. Seen reibale too but not the lightest. Campag cables (if you run campag) are the best I have used. so slick.
www.thecycleclinic.co.uk
PostPosted: Sat Oct 20, 2012 10:43 pm
Tubbie Guru
Hi,
Isn't it Clarks who manufacture Campa's cables?
Ciao, ;)
PostPosted: Sat Oct 20, 2012 10:56 pm
That would be these then?
http://www.wiggle.co.uk/transfil-campag ... cable-set/
I guess they're widely compatible? I was likely going to go with these levers:
http://www.ebay.co.uk/itm/Tektro-RL721- ... 3cc6a4cc74
EDIT: I just realised that's a crosstop lever. Still, is it valid to use that as a standard lever on a single speed without a drop lever also?
Last edited by TomCastellani on Sat Oct 20, 2012 11:43 pm, edited 1 time in total.
PostPosted: Sat Oct 20, 2012 11:38 pm
Clarks may manufacture Campag cables but in Campag cables the stainless steel used has more chromium/nickel so it is more stainless/less magnetic than the clarks cables. Also there have been some worryiong failures of the brake cables heads on clarks cables and some issues with their campag cables aand campag shifters.
There are no new unread posts for this topic. Brake Cables
Stueys
7
917
Wed Aug 23, 2017 1:39 am
beanbiken View the latest post
There are no new unread posts for this topic. Jagwire elite link brake cables
Chris3g
14
1247
Wed Nov 15, 2017 2:55 pm
CallumRD1 View the latest post
There are no new unread posts for this topic. lightweight cables that's not squishy
addictR1
Wed Nov 22, 2017 7:25 pm
sungod View the latest post
There are no new unread posts for this topic. Inners and outers for gear cables?
alastairb
9
1087
Thu Feb 23, 2017 10:35 pm
bremerradkurier View the latest post
There are no new unread posts for this topic. Advice on cleaning up my front cables please
Mtek
13
808
Wed Jan 17, 2018 2:51 am
sugarkane View the latest post
Users browsing this forum: Bing [Bot], Hennesy, Jian81, siim, userfriendly and 19 guests
