Post new topic Reply to topic  [ 32 posts ]
Go to page 1, 2, 3  Next
PostPosted: Wed Oct 17, 2012 3:34 pm
2012 Cervelo R5 VWD 54cm Frameset
- 3T Stealth Ergonova Team 42cm
- 3T Stealth ARX Team 110mm
- 3T Stealth Dorico Team
- Fizik Arione (Manganese Rails)
- 2012/13 SRAM Red Groupset
- Enduro GXP BB Adapter
- LOOK Keo Max 2 Carbon
- Planet X 50mm Tubular Wheelset
- Continental Competition 22mm Tires
- Lizard Skin DSP 2.5mm Bar Tape
- Arundel Mandible Oil Slick Cages x 2
- K-Edge Garmin Mount
- Garmin Edge 500
Weight - 14lbs 4oz or 6,464g with two cages and K-Edge
Bike is pretty much done. I still need to cut the steerer tube down and the only realistic change I will make at this point is the saddle.
Probably going to swap it out for either Fizik Antares 00 or the new Kurve Chameleon.
 Post subject: Re: 2012 Cervelo R5 VWD
PostPosted: Wed Oct 17, 2012 4:32 pm
Very nice bike stephen. Well done. :beerchug:
How do you like the Planet X tubular wheels? They sure do look sharp on the bike.
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
PostPosted: Wed Oct 17, 2012 4:49 pm
thanks !
i'm coming from an S5 Team - just swapped all the parts over, but definitely loving the R5
the planet x tubulars are awesome ! i'm not an expert on carbon wheels as i've only ever ridden the stock fulcrum racing 7s and Ts.
but they definitely offer a significant aero advantage over those and about a pound in weight savings.
braking has been solid, no squeaking with the planet x pads, much better ride than the fulcrums.
honestly, no complaints when it comes to the wheels especially considering i paid $500CAD shipped to my door from the UK
PostPosted: Wed Oct 17, 2012 4:55 pm
Great build . Somehow it seems like it should weigh a bit less.
Love the stem slammed as well
:thumbup:
PostPosted: Wed Oct 17, 2012 5:04 pm
that's what i initially thought as well.
but with the wheels being a bit chunky (1450g) for carbon tubulars, quite a bit of weight could be saved there.
and then all the little gram counting by going LTD cockpit, lighter tires, saddle etc.
but i'm more than happy with the weight and the bike overall !
PostPosted: Wed Oct 17, 2012 7:54 pm
That thing looks so awesome!!
PostPosted: Wed Oct 17, 2012 8:03 pm
Great bike and GREAT photo :thumbup:
PostPosted: Wed Oct 17, 2012 11:21 pm
Very nice looking bike. :thumbup:
PostPosted: Thu Oct 18, 2012 1:19 am
:thumbup:
the seatpost, skewers, and seat are places where you could potentially save 200+grams maybe a pound all in all.
light weight setback seatposts are hard to find and expensive, so you can potentially cut the post down a bit when you get your fit dialed in. skewers and seats are very easy to find light, maybe research what lightweight alternatives offer similar fit/comfort to the current saddle.
looking at the current set up/fit it looks like you might be able to go with a zero setback seatpost... if thats the case then you can really save weight (almost 100g savings alone) with the plethora of uber light weight zero setback seatposts.
nice build! looks so simple and functional. the R5 is probably the best looking sloping geometry frame today because it looks simultaneously old school and modern.
PostPosted: Thu Oct 18, 2012 2:27 pm
thanks guys !
and thanks for the advice! altho i was able to put this bike together very very cost effectively, i've definitely tapped out my budget.
i'm also not a huge fan of the aesthetics of some super lightweight components. i really just wanted to have an all black look on this bike.
and the weight is still pretty low.
the saddle will probably be the main change - antares 00 will save me about 100g from what i have now.
i'm coming from an S5 Team which was super fast and i actually really did like, but over time i just fell in love with the look and ride of the R series.
i think you hit it on the head with the look of the frame, both old school and modern :)
PostPosted: Sat Oct 20, 2012 7:52 pm
Really nice, I was hesitating between the r5 and s5 and decided to go with the S5 but now I regret it a little bit.
PostPosted: Sun Oct 21, 2012 1:56 pm
Cut steerer = perfection, everyone else can go home! New sram red and the r5 looks wicked. Lovely balance to it.
PostPosted: Sun Oct 21, 2012 4:00 pm
:thumbup:
Ball park UCI weight limit seems bang on for that bike. It's a pro level bike (bar the great value wheels) so you'd expect it to weigh what it does.
The frame may weigh 200g less than many but 200g isn't going to turn a bike around to a WW build. Unless you are going for an ultra WW build, frame weight, within reason, isn't that important.
PostPosted: Mon Oct 22, 2012 4:09 pm
@stef32 - that's exactly what i felt, but was able to swing a great deal in a swap
@Monkeyboy3333 - steerer was cut down over the weekend, altho i left a teeny tiny spacer above ... don't judge me ! lol thanks for the compliments !
@konky - agreed ! i wasn't aiming to build a sub 13lb bike so i'm very happy with it as is. and personally i'm not a huge fan of the super lightweight components (aesthetically anyway) either.
PostPosted: Mon Oct 22, 2012 5:23 pm
nice R5 stephen, can you tell me your height, i see it is a 54cm, thanks
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Bing [Bot], jsprbcn, thencameyou and 21 guests
There are no new unread posts for this topic. My 2012 Cervelo S2
therouler
Mon Sep 10, 2012 6:47 pm
petepeterson View the latest post
There are no new unread posts for this topic. 2012 Cervelo S5 with Ultegra Di2
wangsanegara
15
3275
Tue Nov 20, 2012 2:42 am
wangsanegara View the latest post
There are no new unread posts for this topic. CERVELO R5vwd 2012
Naturel
Fri Apr 19, 2013 7:26 pm
Naturel View the latest post
There are no new unread posts for this topic. 2012 Cervelo R3 Team
MikeR3
Tue Aug 21, 2012 3:57 pm
NGMN View the latest post
There are no new unread posts for this topic. Attachment(s) 2012 cervelo r3 frameset 58cm
Jersland
Tue Jun 18, 2013 4:29 pm
Jersland View the latest post
It is currently Wed Jun 19, 2013 11:31 am
