It is currently Wed Jan 24, 2018 5:08 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Oct 21, 2012 4:00 am
I really like the new finish on the dura ace
PostPosted: Sun Oct 21, 2012 7:19 pm
Shit. I just wet myself...
PostPosted: Sun Oct 21, 2012 9:53 pm
Very classy indeed. That look is bang on where it's at. Beautifully styled.
PostPosted: Wed Dec 19, 2012 9:59 am
do you mean whole bike weight 14.02 pounds with pedals?
PostPosted: Wed Dec 19, 2012 11:56 pm
Love it. I've got a couple hundred miles on the same frame. Fantastic photos. Enjoy!!
PostPosted: Wed Jan 02, 2013 8:35 pm
yes it came out to 14.02 with pedals
PostPosted: Fri Jan 04, 2013 8:33 am
Great build, good job.
So did you ever mount the 7900 (10)spd cassette and give it a try?
Or did you just go ahead and pull off the (11) tooth from a D-Ace 9000 and mount that cassette?
Also, which D-Ace 9000 cassette are you running, which gear ratio?
I just saw the answer to m question; you have the 11 - 28.
But did you ever give the (10) spd cassette a try?
PostPosted: Fri Jan 04, 2013 9:39 am
Just to clarify, you pulled the 11tooth sprocket and I guess used a bigger lockring against the 12? And that works out ok? Oh and stunning looking bike by the way.
Ti or dye!
PostPosted: Fri Jan 04, 2013 6:04 pm
That's an interesting point, question. As we know, lockrings do come in (2) varieties; (11)tooth and (12)tooth.
If I'm 'forced' to buy the D-Ace 9000 cassette (can't dial in the shifting with a (10) spd cassette) I will buy the (11) spd, 11 - 25 model. Then pull out the (16) tooth cog and install it. With the (16) tooth cog removed it will be a match for the cogs found in the 7900 & 6700 (10)spd 11 - 25 cassette.
PostPosted: Fri Jan 04, 2013 6:06 pm
I'm in the same situation as the O.P., I'm having to wait for a new free hub body to be built for my hub.
PostPosted: Fri Jan 04, 2013 7:25 pm
Is it possible to pull the 16 sprocket, is it not attached to a carrier with other sprockets?
Ti or dye!
PostPosted: Sat Jan 05, 2013 12:54 am
Enve 3.4's on Tune hubs? Yummy.
Road bike: Pinarello Dogma 60.1
TT bike: Trek Speed Concept
http://www.youtube.com/watch?v=D4XxCZagAjk
PostPosted: Sat Jan 05, 2013 11:38 am
Superb!
PostPosted: Sun Jan 06, 2013 8:27 am
yes you can pull it, and it will create the same cog 'set-up' as seen for the 7900 (10) spd 11 - 25 cassette
For that matter, you could pull the (16) from the 9000/ 11 - 23 OR the 9000/ 11 - 25
and then simply bolt it on your (10) spd free-hub body. I've been 'pulling' various cogs for years to create custom set ups.
http://techdocs.shimano.com/techdocs/bl ... ID=jLc_YdS" onclick="window.open(this.href);return false;
http://techdocs.shimano.com/media/techd ... 807221.pdf" onclick="window.open(this.href);return false;
http://techdocs.shimano.com/media/techd ... 728250.pdf" onclick="window.open(this.href);return false;
Of course 'pulling' a cog on the (11) speed is going to make the entire cassette a 'hair' more narrow than your normal 7900 cassette, but the O.P. has done it successfully.
PostPosted: Wed Jan 09, 2013 5:08 pm
Sing with me... Isn't she lovely?. One of the best over here.
Biomechanical spreadsheet. Sizing&Fitting.
http://weightweenies.starbike.com/forum ... 8e319d185b
There are no new unread posts for this topic. Specialized S Works Shoes 44
Herb5998
Sun Oct 15, 2017 2:39 pm
Herb5998 View the latest post
There are no new unread posts for this topic. Specialized S-works stems
rvlvr
Tue Aug 01, 2017 8:10 pm
rvlvr View the latest post
There are no new unread posts for this topic. Specialized S-Works Diverge
cerro
Mon Oct 16, 2017 7:44 am
cerro View the latest post
There are no new unread posts for this topic. Specialized S-works Aerotec
Zephri
Sun Nov 12, 2017 12:47 am
Zephri View the latest post
There are no new unread posts for this topic. FS-2012 Specialized S-Works Venge
Bianchi10
Sat Dec 09, 2017 6:39 pm
Bianchi10 View the latest post
Users browsing this forum: Herb5998, JS300 and 5 guests
