My Internal DIY Di2 setup
Johhny Bravo
by Johhny Bravo
Hi guys, I'd like to present you my internal DIY Di2 setup
internal battery from ebay
head tube drilling
inner chainstays drilling
dropout drilling
bottom bracket drilling
Bike ready! (6.340kg)
Ride safe!
Eduardo
2011 Look 695 SR
adidavas
by adidavas
nice look except stem :) I want it black in your setup.
erikw1968
by erikw1968
Looking great.
cloudnine
by cloudnine
Nicely done! :thumbup:
4crosswheels
by 4crosswheels
Hi there,
What battery are you using? what did you use to physically do the drilling?
thanks
Bruce
micky
by micky
Nice work but as I was very interested in this sort of project myself, it stopped me when I was reading in another WW topic that Scott would be against drilling cause the carbon tubes are too thin. :|
Johhny Bravo
by Johhny Bravo
4crosswheels wrote:Hi there,
thanks
Bruce
did it with a dremel and the battery is from ebay seller "eapathome", who is a member in this forum
Ride safe!
Eduardo
2011 Look 695 SR
Johhny Bravo
by Johhny Bravo
micky wrote:Nice work but as I was very interested in this sort of project myself, it stopped me when I was reading in another WW topic that Scott would be against drilling cause the carbon tubes are too thin. :|
that's BS
my previous frame was a FACTORY DRILLED 2009 scott addict R1 - the tubes are exactly the same and the holes are also on the same locations.
Ride safe!
Eduardo
2011 Look 695 SR
jamesstout
by jamesstout
thanks
Bruce
a video of the process would have been cool. How inconvenient is charging?
Johhny Bravo
by Johhny Bravo
it´s CONvenient: the charger that comes with the internal battery charges thru the front wiring harness. You don't need to connect it to battery for charging. Just unplug the head unit cable and plug the charger to the wire.
Ride safe!
Eduardo
2011 Look 695 SR
Svetty
by Svetty
that's BS
But do they still sell them like that or have they stopped having learned from experience ;)
1spd
by 1spd
I don't have Di2 at all but am just curious if the battery just drops all they way down to the bottom, hangs there, weges some how, stops at the bottle cage bolt area??? Just curious. Looks good though. Nothing like drilling a perfectly nice frame! Well done!
Cannondale Synapse (alu)...it works
Johhny Bravo
by Johhny Bravo
Svetty wrote:
that's BS
of course they still sell them like that - but now it's the FO1L version (addict R1 are no longer made)
Ride safe!
Eduardo
2011 Look 695 SR
Johhny Bravo
by Johhny Bravo
1spd wrote:I don't have Di2 at all but am just curious if the battery just drops all they way down to the bottom, hangs there, weges some how, stops at the bottle cage bolt area??? Just curious. Looks good though. Nothing like drilling a perfectly nice frame! Well done!
i wrapped the battery with rubber (old inner tube) so it fits tight against the inside of the seatpost - this way it doesn't slip up/down.
Ride safe!
Eduardo
2011 Look 695 SR
tetonrider
by tetonrider
excellent work!
what do you do to ensure the wires do not rub on the crank spindle? gravity will want to pull them down a bit. that bend from the downtube wire as it curves up the seat tube is an issue (minor one!) i've had on a similar project i did.
was it difficult to get a dremel inside the bottom bracket? i'd imagine the angles are tight.
thanks for sharing!
