It is currently Thu Jan 18, 2018 4:44 pm
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Dura Ace 9000 hubs
PostPosted: Tue Nov 27, 2012 11:13 am
No more silver hubs.
Like Campag.
Such a pity.
VeloKicks
The Gram
The Men of Steel
PostPosted: Tue Nov 27, 2012 12:25 pm
They are black. If I knew how to post pic's here I would take a pic of a carbon clincher I built recently. The rear wheel came in at 720 grams.. not bad.
PostPosted: Wed Nov 28, 2012 7:44 pm
mine shine a blue / grey in the sun.
PostPosted: Mon Dec 03, 2012 10:42 pm
Like Campag.
Such a pity.
It is a shame, and unlike campag you can't use the older shiny version on current groupsets. I still have a brand new set of shiny record hubs in the cupboard.
PostPosted: Mon Dec 03, 2012 10:58 pm
Nothing a little caustic soda won't sort out
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Wed Dec 19, 2012 6:03 pm
I'm also building a new 11-speed wheel set using the new DA9000 24-hole rear hub and Stan's Alpha 340 rim. I would like to build it using 3-cross on the drive side and radial on the non-drive side but having difficulty calculating the spoke lengths. Any assistance would be appreciated.
Scott
PostPosted: Thu Dec 20, 2012 2:31 am
Pretty sure you can't build 3x on a 24 holed hub.
PostPosted: Wed Feb 20, 2013 3:02 am
Attached is a screenshot for different spoke combos for this hub with Stan's Alpha 340 rim.
Cheers,
Jason.
 Post subject: Dura Ace 9000 hubs
PostPosted: Wed Feb 20, 2013 3:06 am
Shop Wrench
What program is that screenshot from?
PostPosted: Wed Feb 20, 2013 4:48 am
Location: somewere floating between here and the other side
Why is that ? Are the spoke going to cross spoke heads of other spokes ?
PostPosted: Wed Feb 20, 2013 6:04 am
Its from here: http://lenni.info/edd/
PostPosted: Wed Feb 20, 2013 7:52 am
Generally speaking, that's one reason and the other is avoid extreme angles entering the rim.
Many more experienced wheel builders than I on this forum could provide a more precise answer...
AX Lightness Vial Evo, Carl Strong Titanium
PostPosted: Sat Aug 24, 2013 6:51 am
Guerdi wrote:
If someone's interested in building a wheelset with those new 9000 hubs, here are the specs :
9000 Freehub :
Spoke Holes PCD : 44 mm (Non drive side) / 45 mm (drive side)
Flange distance : 56.9 mm
Flange distance 28 holes : 56.5 mm
Dish : 9.75 mm
Dish 28 holes : 9.95 mm
9000 Front hub :
Spoke Holes PCD : 38 mm
Flange distance : 74.0 mm
Does anyone know the spoke hole diameter on the front and rear hubs? I read an article suggesting narrow spoke holes such that a Sapim CX-Ray spoke wouldn't fit but this sounds hard to believe.
PostPosted: Sun Aug 25, 2013 12:18 am
They fit.
formerly rruff...
PostPosted: Sun Aug 25, 2013 4:41 am
WMW wrote:
They fit.
Thanks.
So this guy has it all wrong then.
http://paolocoppo.drupalgardens.com/content/dura-ace-9000-hubs-finally-here
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
There are no new unread posts for this topic. Dura Ace 9100/9150 noisier than 9000!
James0133
11
3488
Sun Aug 20, 2017 5:44 am
James0133 View the latest post
There are no new unread posts for this topic. Tips for dura ace 9000 hood replacement.
SpecializedColnago
Wed Jan 25, 2017 7:21 pm
rossjm11 View the latest post
Users browsing this forum: buhx2, elzilcho, Google [Bot], Hastur, ingLatour, Massi, Yahoo [Bot] and 29 guests
