It is currently Sun Jan 21, 2018 10:00 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: Enve 1.25's
PostPosted: Wed Oct 10, 2012 5:40 pm
I have a set of Enve 45 clinchers that I love and I also have a set of wrecked DA C35 tubs. I'm looking at replacing the C35's with a set of Enve 1.25 tubs with Alchemy hubs. Any feedback on these rims? I would be looking at going 28/28 cause I weigh in the 90-95 kg range.
 Post subject: Re: Enve 1.25's
PostPosted: Wed Oct 10, 2012 6:03 pm
they used to be sub 200g and flexy. I think they are now around 250g and have a better reputation.
PostPosted: Wed Oct 10, 2012 6:35 pm
25mm front and 45mm rear?
Smart 3.4?
www.ergottwheels.com
PostPosted: Wed Oct 10, 2012 7:03 pm
Wasn't looking to do a 35mm/45mm mix. I was more interested in the 1.25's weight and wondering about durability at my weight.
PostPosted: Wed Oct 10, 2012 7:31 pm
The 25 is a solid rim, but I really do view that to be very climbing oriented. If your going to be using it for cruising the flats at all, I think that Erics suggestion of the 3.4 is a much more practical one. The 25 is built to log vertical, and if thats what you do predominantly, then it could be a good choice.
With regards to the spoke count, I think that the 28 up front is somewhat overkill. The fact that tension will be even from drive to non drive side up front will make it much stiffer than the rear, and going with a 24 or even 20 hole count would be just fine for you.
Good call on the 28 rear though.
http://www.zencyclery.com
PostPosted: Wed Oct 10, 2012 9:01 pm
Honestly... It would probably be more wise, at your weight, to go with a more solid rim, than try to save 45g on your wheels. I'd suggest going with the stronger/heavier rims, and just drop that 45 grams off your gut.
PostPosted: Wed Oct 10, 2012 9:07 pm
I'm not too sure about this. I think you would be hard pressed to find a tubular rim out there that in that depth that is stronger and more durable than the 25. It is ridiculously stiff, even though it only comes in at 250g.
PostPosted: Wed Oct 10, 2012 9:08 pm
2011: Can you tell me the moment of inertia on that 45 grams in the gut? Also, what's that force at 50mph?
Thanks :wink:
Current:
T2
Retired:
PostPosted: Wed Oct 10, 2012 11:38 pm
I have used 1.24's and a 1.25 and highly recommend the latter. Nicer profile, more robust -- save 50 grams elsewhere. My 1.24's both warped on me with very light use. The 1.25 looks like it is meant to be ridden.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Wed Oct 10, 2012 11:55 pm
Agree. The 1.25 is an amazing rim, I had a set and loved them (sold only because rear was built on PowerTap hub and I switched to SRM for power needs). Put these with Alchemy hubs and you have the ultimate climbing wheels. having said that, I didn't get another set of 1.25s as my 3.4s are "good enough" as climbing wheels and more versatile on the flats and rollers.
EVO Hi-Mod | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 3/5
P5 | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 7
T1 | Power2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
SuperX Hi-Mod Disc | Sram Red | Power2Max NG
PostPosted: Thu Oct 11, 2012 12:24 am
Agreed. The 3.4s are stellar for an everyday driver type of wheelset, where as the 25s are a climbers dream.
PostPosted: Thu Oct 11, 2012 3:05 pm
What's better on Enve 1.25's than other 20mm (chinese) carbon rims in the 250g territory to justify the substantial price difference?
Asking because also interested in building an ~1000g wheelset.
PostPosted: Thu Oct 11, 2012 3:48 pm
Enve has molded spoke holes. Everyone else drills theirs. Enve also has a 5 year warranty, most others only have a 1 year. Another perk is that they are made in the US, and they are extremely durable. I have read plenty of horror stories about Chinese carbon.
PostPosted: Thu Oct 11, 2012 3:56 pm
Not sure where you are located but if in europe, Corima winium at 270g is a much cheaper option and is an excellent low profile rim.
PostPosted: Thu Oct 11, 2012 6:00 pm
Would I be able to get away with a 24 spoke count on the rear??
There are no new unread posts for this topic. Non-enve pads on enve wheels
AttacknowAttackoften
36
3698
Sat Jan 13, 2018 4:16 pm
izza View the latest post
There are no new unread posts for this topic. ENVE SES 4.5 with ENVE hub => brake rub
ODC
40
3554
Sat Dec 16, 2017 5:50 pm
jj911c2 View the latest post
There are no new unread posts for this topic. Enve 3.4 V2 tubular
solarider
Fri Jun 16, 2017 7:26 pm
solarider View the latest post
There are no new unread posts for this topic. Enve 3.4 SES and Zero Gravity Brakes
markcp
Tue May 23, 2017 4:15 pm
Beaver View the latest post
There are no new unread posts for this topic. Enve SES tire choice
20
1926
Fri Feb 03, 2017 4:02 pm
VTR1000SP2 View the latest post
Users browsing this forum: Broady, brumbar, GothicCastle, silvalis, Squashednuts and 36 guests
cron
