It is currently Wed Dec 13, 2017 8:06 pm
Post new topic  Reply to topic  [ 354 posts ]  Go to page Previous 113 14 15 16 1724 Next
PostPosted: Mon Sep 30, 2013 2:18 pm
the claim is all you need is new rear derailleur and cassette; and you might need to update the firmware/get a new front junction box and cables.
so 2x300-350mm cables
3 or 5 port front junction
DA Rear D
11 speed cassette and compatible free hub
650b Ritchey
Colnago Mapei
S-Works Tarmac
PostPosted: Tue Oct 01, 2013 1:04 pm
53x12 wrote:
Pat, which junction box A do you have?
If you have the newer SM-EW90 A all you need is the associated battery charger, SM-BCR2.
If you have the older SM-EW67A-E you will need the SM-PCE1 PC interface.
If I am wrong, someone can correct me on that.
I'll have to check this out and see.
PostPosted: Tue Oct 01, 2013 1:06 pm
DA Rear D
Pardon my lack of knowledge on this.... does the new junction box not just replace the old one? why new cables needed?
PostPosted: Tue Oct 01, 2013 1:12 pm
The old junction box had fixed cables, the new box is fully modular.
PostPosted: Tue Oct 01, 2013 2:30 pm
Omiar wrote:
thisisatest wrote:
The number of speeds the system will shift for, and the distance that it will move per shift, is controlled at the rear derailleur.
In other words:
6770 can shift 11speed, if you use a 9070 rear derailleur. 9070 can shift 10speed, if you use a 6770 rear derailleur.
This is how the Shimano guys at interbike explained it on more than one occasion.
Excellent information :thumbup:
SpoonMan wrote:
Working with very small electric motors (amongst other things), I assume that means the motors are not 'stepping' motors, but infinitely variable - otherwise you couldn't have a 10-step motor run 11 cogs
Well, along with the 9 (10spd) or 10 (11spd) steps for gear change, they also have 15 steps inward and 15 steps outward from the initial position.
I thought a stepper motor was configured such that 'X' number of steps were assigned to Rad or 360 degrees, not equated to the output of a linkage system (ex. the derailleur). Meaning the stepper motors are fabricated such that there could very well be 500 steps (the ones I've used had over 2000) per 360 degrees of rotation. So to when programming how many steps would equate from one cog to another would be something like 1500 or 2000 steps, depending on if there is a gear box, or other mechanical advantage linkage (i.e. RD).
If this was the case, someone could easily reprogram the # of steps to go from 10 to 11 cassette. Someone tell me if I am way off on this. FYI, I still use cable shifting. The Di2 is still voodoo to me.
PostPosted: Mon Oct 07, 2013 8:42 pm
DA Rear D
I'm a little confused.... i was under the impression that I didn't have to change the junction box, just get the SM-PCE1 for the Etube ability and update. and then change the rear Der, and cogset.....
Pat
PostPosted: Mon Oct 28, 2013 9:00 pm
In a recent crash, I bent my RD-6770 derailleur plates (in addition to my frame's derailleur hanger). If RD-6770 and RD-6700 parts are the same, it looks like plates are Shimano parts Y5X998030 (outer plate) & Y5X908100 (inner plate) (Tech doc PDF: http://goo.gl/0QH4t2).
I was running short cage plates ("SS"), but I'd also be open to running medium cage plates ("GS").
Does anyone know where I can buy replacement parts? If this wasn't Di2, I'd probably just buy a new derailleur.
PostPosted: Mon Oct 28, 2013 11:11 pm
Hello,
is it possible to use the newer RD 6870 and FD 6870 with the 6770 Sti's and still 10 Speed?
Regards Harald.
PostPosted: Mon Oct 28, 2013 11:33 pm
DA Rear D
Pat
You don't need to change junction box if running 6770 since it uses the same wire as 6870/9070. Only change junction box if you want to run Shimano internal battery mod.
PostPosted: Mon Oct 28, 2013 11:38 pm
lotushiast wrote:
Hello,
Regards Harald.
Harald, no I don't believe so as RD controls if it is 10 or 11 speed. I don't want to say never ever as I'm sure someone will be able to find some hack.
PostPosted: Tue Oct 29, 2013 1:55 pm
DA Rear D
Pat
Great so it looks like in total I'll need, 11 speed derailleurs, 11 speed cassette and update. is anyone have a solid answer on whether both derailleurs are needed? or just the rear unit
Pat
PostPosted: Tue Oct 29, 2013 6:22 pm
shimano say you need both, but then again they would.
PostPosted: Tue Oct 29, 2013 6:58 pm
I'm not sure I have read anyone using 6770 shifters and tried 6870/9070 RD/FD yet. Hopefully in the upcoming months we will hear more about that. But speculation was that you only needed the RD as this was the 'brains' for whether it is 10 or 11 speed.
PostPosted: Tue Oct 29, 2013 9:22 pm
I can confirm this use case: FD-6770 + RD-9070 will work as 11-speed (on an otherwise 9070 time trial setup).
One observation: an FD-6770 auto-trims differently vs. an FD-9070. My notes (and video) below, where largest cog = 1 and smallest cog = 11. I'm highlighting when the trim events occurs, e.g. "7-to-6"....
Ultegra 10-speed FD (FD-6770) & Dura-Ace 11-speed RD (RD-9070): http://www.youtube.com/watch?v=v1vewETe1q0
Front chainring: small
Up: 7-to-6 & 4-to-3
Down: 5-to-6 & 7-to-8
Front chainring: big
Up: 7-to-6 & 5-to-4
Down: 5-to-6, 8-to-9
Dura-Ace 11 speed FD (FD-9070) & Dura-Ace 11-speed RD (RD-9070): http://www.youtube.com/watch?v=BM388hQSeyE
Up: 8-to-7 & 5-to-4
Down: 5-to-6 & 8-to-9
Up: 9-to-8, 6-to-5
Down: 6-to-7, 9-to-10
PostPosted: Wed Oct 30, 2013 7:04 am
Thanks 415brian! Very good info
Good to know that I can just upgrade the RD and cassette first...At least I can upgrade to 9070 slowly! :)
There are no new unread posts for this topic. Ultegra 6770 Di2 Auto-trim?
Staffan
Sun Nov 05, 2017 1:35 pm
glepore View the latest post
There are no new unread posts for this topic. Need schematic of rd 6770
yumseyo
Mon Jun 05, 2017 8:59 pm
yumseyo View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
There are no new unread posts for this topic. Ultegra brake
Timmy269
Fri Oct 13, 2017 1:08 pm
Timmy269 View the latest post
There are no new unread posts for this topic. Power2max vs Pioneer Ultegra
JBeauBikes2
9
914
Wed Aug 30, 2017 9:22 am
RJKflyer View the latest post
Users browsing this forum: AJS914, Aleksandr, Bing [Bot], blantonator, kookie, lovemyway, raggi, rainerhq and 30 guests
