It is currently Mon Jan 22, 2018 9:47 am
Post new topic  Reply to topic  [ 359 posts ]  Go to page 1 2 3 4 524 Next
PostPosted: Fri Oct 05, 2012 2:33 pm
Past topics
New firmware: viewtopic.php?f=3&t=107124
Saw the new Shimano catalog today. Some of it is available online also.
There is a climbers switch
http://techdocs.shimano.com/media/techd ... 799997.pdf
and TT bar end shiftes (no techdoc yet however), but no TT brake lever and shifter combo.
There is an internal battery SM-BTR2 coming, but there was no picture of it. The battery is the same for 9070 Di2, 6770 Di2 and Alfine systems.
I found a schema of Alfine Di2 parts, from there we can only assume that it is a round stick type battery.
(last page) http://www.fuchs-movesa.ch/tradepro/sho ... n_2012.pdf
Interesting is that the SW-R600 climber switch seems to be the same for both 9070 and 6770. The question of both groupsets overall compability and 6770 possible 11-speed upgrade is still unknown.
Scott Foil Ultegra Di2
Scott Scale 35 26"
Scott Spark LTD 29" M8000
PostPosted: Fri Oct 05, 2012 2:50 pm
I'm still waiting for a firmware update to make it work on 11-speed. In fact, with electronic shifting, there's no reason that Shimano/ Campy parts couldn't be reprogrammed to work on each other's cassettes. But I can't see spending 6770 prices on locking myself into 10-speed... wish Shimano would realize that.
PostPosted: Fri Oct 05, 2012 4:02 pm
Technically it is possible for sure. The main question is in markteing and sales.
Scott Scale 35 26"
PostPosted: Fri Oct 05, 2012 5:03 pm
Sounds like an aftermarket opportunity for an entrepreneurial programmer in the audience. :idea:
PostPosted: Fri Oct 12, 2012 4:41 pm
Something new - Canyon has specced Shimano Di2 ST-9071 brake/shift levers for their otherwise full spec Ultegra Di2 Speedmax time trial bikes.
So from this we can assume that all the shifters seem to be compatible between the two groupsets.
Scott Scale 35 26"
PostPosted: Sat Nov 03, 2012 7:14 pm
New firmware just came out for the Ultegra Di2 (this is the second time since original manufacture). No idea what fixes or changes it contains, but the version number went to "2". :noidea:
PostPosted: Sun Nov 04, 2012 1:15 am
http://techdocs.shimano.com/media/techd ... 799997.pdf" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
God, that climber's switch is fugly, I've seen the really small "sprinters" switches which you can get from Japan that can be mounted anywhere, elegant.
10 SuperSix Hi-Mod
07 System 6.
06 Caad 8
90s Merlin Extralight.
PostPosted: Mon Nov 12, 2012 11:14 pm
Snooping around, I found this page which has the changelog (not very detailed) on the firmware versions. It appears that the new firmware deals with "energy saving". My guess is that it addresses the issue people had with Ultegra Di2 depleting batteries at a higher rate than the Dura Ace 7970 version.
http://e-tubeproject.shimano.com/
PostPosted: Wed Nov 14, 2012 11:14 am
do you guys think the RD has a great enough range of motion to do 11s?
PostPosted: Wed Nov 14, 2012 1:06 pm
Yes.
Scott Scale 35 26"
PostPosted: Wed Nov 14, 2012 2:35 pm
The number of speeds the system will shift for, and the distance that it will move per shift, is controlled at the rear derailleur.
In other words:
6770 can shift 11speed, if you use a 9070 rear derailleur. 9070 can shift 10speed, if you use a 6770 rear derailleur.
This is how the Shimano guys at interbike explained it on more than one occasion.
PostPosted: Thu Nov 15, 2012 6:18 am
Working with very small electric motors (amongst other things), I assume that means the motors are not 'stepping' motors, but infinitely variable - otherwise you couldn't have a 10-step motor run 11 cogs
2011 Scott Addict R3 (DA groupset, Tune Skyline RR wheelset, Rotor 52/36 Q-Rings)
2008 Giant Trinity A1 (cheapass 50mm carbon clinchers)
No easy road goes anywhere worth going
PostPosted: Thu Nov 15, 2012 11:32 am
In other words:
Excellent information :thumbup:
Well, along with the 9 (10spd) or 10 (11spd) steps for gear change, they also have 15 steps inward and 15 steps outward from the initial position.
Scott Scale 35 26"
PostPosted: Thu Nov 15, 2012 5:48 pm
Would love to hear any more info people can dig up about mix and match compatibility with di2 9070.
I'm guessing that to use the new 9070 internal battery will just require a new cockpit junction box (so that you have the charging port) and that the box will work fine in a 6770 system. Sounds like if you picked the 5 port version you would also get ANT+ broadcasting?
Also if anyone hears anything about reverse-engineering the Can bus protocol messaging for custom applications. Maybe a potential source being the messaging between a PC and the system via the system checker?
PostPosted: Thu Nov 15, 2012 10:01 pm
The protocol didn't looked like CANBus in the quick measurements we have done. With the old Dura Ace DI2 hacking it was really easy. The protocols were a bit strange (it works like home made stuff), but very easy to record and replicate. The communication frequency on the new E-tube stuff is a lot higher, which makes it impossible to decode the protocol with cheap hardware.
There are no new unread posts for this topic. Ultegra 6770 Di2 Auto-trim?
Staffan
Sun Nov 05, 2017 1:35 pm
glepore View the latest post
There are no new unread posts for this topic. Need schematic of rd 6770
yumseyo
Mon Jun 05, 2017 8:59 pm
yumseyo View the latest post
There are no new unread posts for this topic. New Ultegra (Di2) ???
stormur
Thu Mar 23, 2017 10:42 am
stormur View the latest post
There are no new unread posts for this topic. Ultegra brake
Timmy269
Fri Oct 13, 2017 1:08 pm
Timmy269 View the latest post
There are no new unread posts for this topic. Does XT di2 fits to Ultegra di2 shifters [11 sp]
johancoenen59
Thu Jun 01, 2017 2:36 pm
PinaRene View the latest post
Users browsing this forum: benzebub, jacobeh and 34 guests
