It is currently Wed Nov 22, 2017 5:08 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri Sep 28, 2012 10:54 pm
Hi, I am trying to decide which saddle to buy between:
SM Mantra,
SM Aspide FX,
SMP Evolution,
And would appreciate it if someone could provide me with any of these saddle's height from rails to top of saddle :)
PostPosted: Sat Sep 29, 2012 3:07 am
there are a couple ways this could be measured. for instance, when mounted on a bike and leveled off, the smp's rails are at a moderate angle. so... do you want the vertical distance from middle of rail up? and when you say "top of the saddle", do you mean the top-top, if a straight-edge is placed nose-to-tail, or do you mean to the top of the saddle at its midpoint?
PostPosted: Sat Sep 29, 2012 6:10 am
I don't know about the SSMs, but here's the Evo data. The Composite (same shell) was the same rail-to-center height. The SMP is totally different sitting experience, so I hope you've atleast tried (and liked) the ones on your list and are only using the measurements to further narrow it down.
PostPosted: Sat Sep 29, 2012 7:20 am
Currently ride Mantra. This diagram could help.
PostPosted: Sat Sep 29, 2012 7:56 pm
Wow thanks you guys rock!
I must admit not trying the SMP and I appreciate the warning, considering how different the ride might be. I am just looking for an anatomically "correct" saddle that has some good height on the rails, because I do not want to replace my already cut seatpost (pretty lame, I know) :/
I was previously using a Brooks B17 with a center height of 65mm. I thought these saddles were rather "tall" but I might be wrong. Any suggestions of saddles that are taller than the typical 40 to 50mm? I would hopefully be able to keep the weight below 250 grams! Maybe the Specialized Romin Expert??
PostPosted: Sun Sep 30, 2012 8:28 am
My experience you sit a fair bit farther back on the SMP, where it's higher still. Hence Steve Hogs advice to use zero setback.
Best saddle I ever owned by a ridiculous margin. Second ride I did with it was 5 hours in the saddle... I came of the bike with sore hands, but my posterior had zero issues, not even noticed it when I jumped on my commuter that afternoon to get groceries.
Of course, your experience might differ!
There are no new unread posts for this topic. Attachment(s) New Saddle: Selle Italia Carbonio Flow vs San Marco Aspide Carbon vs San Marco Mantra Carbon
3Pio
35
2710
Fri Oct 27, 2017 9:48 pm
3Pio View the latest post
There are no new unread posts for this topic. San Marco Regale Carbon FX Stack Height
Stolichnaya
Thu Dec 29, 2016 3:29 am
Denavelo View the latest post
There are no new unread posts for this topic. Selle SMP saddles - advice on fitting and model selection?
rynogee
11
1664
Mon Dec 26, 2016 5:32 pm
ryanw View the latest post
There are no new unread posts for this topic. Lightest Saddles For Clydledales?
tabl10s
7
803
Thu Aug 31, 2017 9:40 am
jemima View the latest post
There are no new unread posts for this topic. Saddle height and agility
dedobike
16
1179
Sun Oct 15, 2017 1:40 pm
dedobike View the latest post
Users browsing this forum: 5DII, Bing [Bot], donald, dvq, Google Adsense [Bot], jimaizumi, vanillaflyweight and 30 guests
