It is currently Fri Jan 19, 2018 5:08 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Fri Sep 14, 2012 4:22 pm
Hi all,
My friends daughter is 158 CM (5.2")
We wonder what frame size to get her.
It will be a Cannondale SS EVO.
The better size will be the women model size 44cm.
The thing is we need it to be a 700 wheel.
Does any one know if 44cm frame comes with 700 or 650 wheels?
Thank you all,
Peled
PostPosted: Fri Sep 14, 2012 4:36 pm
peled wrote:
158 CM (6.2")
158cm = ~5'2" and not 6'2".
PostPosted: Fri Sep 14, 2012 4:46 pm
158 cm = 5'2".
Same as my wife.
You will need the smallest size which they call a 48. With consideration to the seat tube angle of 74.5 degrees, the key dimension is the top tube which is 51.5. You will need a zero offset seatpost and a very short reach handle bar to make it work. You will also need to consider using the shortest reach shifters. IIRC Shimano shifters ride about 1 cm longer than Sram, so Sram may be your best choice. Once these parts are in place find the stem that works. My wife uses a 9 cm stem but most women this small end up with 8 cm or even shorter. Assuming proper positioning, the longer the stem that will work the better the handling will be - this is why short reach bars and shifters are so important.
Something to keep in mind is head tube size. 11 cm is normal for a frame of this size but may be too short for certain women. If she is young/racing it will probably be fine.
wheelsONfire wrote:
When we ride disc brakes the whole deal of braking is just like a leaving a fart. It happens and then it's over. Nothing planned and nothing to get nervous for.
PostPosted: Fri Sep 14, 2012 4:52 pm
Height is a really poor measurement to determine bike fit... You can take people of exactly the same height and have one fit one size, another person the same brand/model but a different size and a third person simply doesn't fit any size of that brand/model but fits perfect on another brand/model...
PostPosted: Fri Sep 14, 2012 5:04 pm
MY wife is 5'2 and rides a 44cm Cannondale.
I know it is almost impossible, but if you can find anywhere to test ride the frames you might want to.
My wife tried the top end carbon frames (more CErvelo than Cannondale in her size) and found the Synapse Feminine 5 (Aluminum) to be a BETTER ride for her size. It was more comfortable, the carbon frames were jarringly stiff, and there is almost no weight savings in those tiny sizes. In fact her top choice was the Cannondale AL, second choice was a cheap Giant AL frame, then the megabuck carbon racebikes from Cervelo and Cannondale.
Long story short, I was prepared to buy a $3000 frame, but ended up with a $600 one she likes WAY better.
At the extremes of the stock sizing spectrum bikes can REALLY ride different based on material or geometry compromises, so it is worth taking test rides, or thinking of getting her something custom.
44cm Cannondale frames are sized for 700c wheel BTW.
PostPosted: Fri Sep 14, 2012 9:02 pm
The Specialized Ruby is a good alternative...
PostPosted: Fri Sep 14, 2012 10:37 pm
Disagree. Height assuming fairly normal proportions will get you in the ball park. This is particularly true of with the limited sizing options offered by most modern manufacturers. Variability of proportion is further decreased when you are dealing with such a small athlete - she won't have 36 inch long arms for example. It would be a very rare occurrence to find a 5'2" female rider who would be better fit on any size of Cannondale Evo other than the smallest they offer - the 48.
PostPosted: Sat Sep 15, 2012 5:42 am
Thank you all for your answers.
Cannondale offer women model in 44 cm size.
The girl had been to a bike fitter in order to fit her MTB and current road bikes, so we have all the measurements we need.
In terms of TT length the 44size will be the best as we can go with the 90mm stem.
The thing is, we need 700c wheels.
I couldn't fined anywhere to tell me if it 700c or 650c wheels.
Peled
PostPosted: Sat Sep 15, 2012 7:36 am
+1 - I totally agree, it's all about proportions imo ...
PostPosted: Sat Sep 15, 2012 9:04 pm
My G.F is 5ft 3inch and rides a 48cm Super Six Hi Mod. 75mm Enve stem, set back post, 165mm chainset
PostPosted: Sat Sep 15, 2012 10:17 pm
Peled
Peled,
CANNONDALE USES 700C WHEELS ON SIZE 44cm WOMENS BIKE.
have a nice day.
PostPosted: Sun Sep 16, 2012 3:46 am
Thank you very much for A strait forward answer.
Peled
There are no new unread posts for this topic. Campagnolo Ultra torque advise
Tricky1
Wed Mar 29, 2017 6:53 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Where this small part come from?
3Pio
Tue Aug 01, 2017 6:33 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Attachment(s) Small / light cable stop
claus
Wed Oct 04, 2017 12:22 pm
morganb View the latest post
There are no new unread posts for this topic. small bikes for alpine descents
pya
Sun Jun 11, 2017 6:02 pm
pya View the latest post
There are no new unread posts for this topic. Campag reach adjustments for small hands
bikewithnoname
Sat Oct 21, 2017 5:35 am
Mr.Gib View the latest post
Users browsing this forum: Allen254, glam2deaf, Google Adsense [Bot], oldnslow2, pratt, tokyoturtle and 27 guests
