It is currently Fri Dec 15, 2017 5:35 am
Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Aug 13, 2013 12:36 pm
I realise you’re looking at full carbon stems, but they are typically both heavier and up to 4x more expensive than a decent Al stem (Deda Superlegga, Extralite, Zipp, 3T team), that said you might also consider the Pro Cavendish stem if stiffness is your primary focus (it won’t suit all tastes though)
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
PostPosted: Tue Aug 13, 2013 2:34 pm
Agree with the sentiments on alu vs carbon stems. I own the ARX LTD, but it is heavier, bulkier, and considerably more expensive than my alloy stem. The only real reason to go for a carbon stem is if you particularly like the aesthetic or if you're trying to match the rest of your cockpit. If you've got Enve bars/seatpost, I say go for Enve. If you have 3T LTD bars and seatpost, might as well get the ARX. If you don't have either, just get something lighter and cheaper.
PostPosted: Tue Aug 13, 2013 6:49 pm
100mm Enve weight 117 grams, 100mm 3T Arx weight 118 grams, I agree with the above post, you get the stem according from your choice of handlebar.
PostPosted: Tue Aug 13, 2013 7:53 pm
"I agree with the above post, you get the stem according from your choice of handlebar."
Yes or you get what you can find on sale or get a good deal on used and take the decals off. Economics speak more loudly to me than having my stem and handlebars match.
 Post subject:
PostPosted: Tue Aug 13, 2013 9:17 pm
I think I heard that the Enve and 3t LTD stems look so similar because they are made in the same factory, so you have gloss vs matte, faceplate aesthetics, recessed nuts for the 3t steerer clamp screws.
Sent from my EVO using Tapatalk 4
 Post subject: Re:
PostPosted: Wed Aug 14, 2013 3:54 am
"I think I heard that the Enve and 3t LTD stems look so similar because they are made in the same factory, so you have gloss vs matte, faceplate aesthetics, recessed nuts for the 3t steerer clamp screws."
I thought the Enve stem was made in the USA, in UT?
http://www.bikerumor.com/2012/05/17/enve-composites-factory-tour-inside-look-at-company-carbon-fiber-manufacturing/
PostPosted: Wed Aug 14, 2013 4:21 am
To quote the article you linked:
While the rims are all made in UT, their components are mostly made overseas for now. Some are made domestically, and Schiers says they’re working to do more here.
“First and foremost, we’re designing the laminates here, prototyping here and completely designing everything here, including the tooling,” Schiers says. “Then we take it over there, and we’re in frequent (weekly) communication with them to maintain a consistency in the product. Then we do the final testing here, too.”
They’re also contemplating a full time position at the foreign factories to oversee their production. Schiers said even if they could ramp up production here in the US to help speed aftermarket order fulfillment, there would always be an Asian component to their manufacturing. Why? Because OEM customers need the product quickly and it makes more sense to have it made in and delivered to the same area when their products are being spec’d on production bikes.
 Post subject: I have both...
PostPosted: Thu Aug 15, 2013 4:49 pm
...They are similar but not the same. The bolt design is different at the steerer. and the design is not apples to apples...
Get the one that matches the build.
carbonLORD.com
PostPosted: Sat Aug 17, 2013 10:16 pm
If your looking for a stiff stem/bar forget the ENVE stuff - they are very noodly. The 3T stuff is much stiffer.
I've had ENVE and now on 3T and wouldn't go back.
PostPosted: Mon Aug 19, 2013 3:50 am
Tinker, Taylor, Tart
^^ That's a MAHOOSIVE over-exaggeration right there!
PostPosted: Mon Aug 19, 2013 3:51 pm
Depends. I found the Ergosum LTD to be tons more flexy then the Ergonova Team I'm on which feels almost identical to the ENVE compact bar I'm riding.
carbonLORD.com
PostPosted: Mon Aug 19, 2013 6:45 pm
Does it absolutely have to be full carbon? I understand the bling factor - that's why I have a carbon matrix 4-axis on my Storck - but I did a price to weight comparison on stems a while ago and was stunned by how little weight you save with carbon stems (as in, generally none).
I like to keep my stems and bars from the same manufacturer. I know it won't make a difference in general, but in case one manufacturer's tolerances are a little off one way or the other, it will make sure everything works together. I am especially careful about matching a carbon bar with any other manufacturer's stem.
There are no new unread posts for this topic. Bars and stem - stiffness versus weight.
BennyC
Sun May 28, 2017 8:40 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Non-enve pads on enve wheels
AttacknowAttackoften
30
2859
Sun Nov 12, 2017 2:50 am
Nefarious86 View the latest post
There are no new unread posts for this topic. ENVE SES 4.5 with ENVE hub => brake rub
ODC
39
2877
Thu Dec 14, 2017 11:47 am
StradaJon View the latest post
There are no new unread posts for this topic. Attachment(s) does stiffness matter (w/numbers)
wwnick
24
1941
Thu Jul 06, 2017 8:50 am
Marin View the latest post
There are no new unread posts for this topic. Enve 3.4 V2 tubular
solarider
Fri Jun 16, 2017 7:26 pm
solarider View the latest post
Users browsing this forum: Bing [Bot], BobbySweeting, Boshk, mbdurham17, rcb78, toshi and 42 guests
