It is currently Tue Jan 16, 2018 10:41 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Sep 12, 2012 5:18 pm
anyone know?
PostPosted: Thu Sep 13, 2012 4:32 pm
Anything pre 10-speed (so any 8/9 speed mech, I've no idea about older than that). It's only 10speed MTB that wont work with 10 speed road.
PostPosted: Fri Sep 21, 2012 12:41 pm
Any Shimano compatable rear mech as long as it has enough travel for the cassette width!
My Daughter is using an old 7 speed Alivio on a 9 speed cassette no issues.
PostPosted: Fri Sep 21, 2012 3:16 pm
7/8/9/10 Road is comapatibe with 7/8/9 MTB (assuming the correct cassette including the road 10speed cassette).
10 speed MTB is an entirely new system, the mech only work with 10speed mtb shifters and vice versa. The cassette is also slightly wider so doesn't use the 10speed spacer from the road cassettes. So you can't run a road casette in a mtb (well you can, but the shifitng isn't quite perfect, it'll be 0.1mm out with each gear depending on wher you set it that 0.5 each end or 0 one end and 1.0 the other). The chans are also different, DA chains are no longer the same as XTR (XT/ultegra, SLX/105, etc).
SRAM and shimano chains and cassettes are also interchangeable on the road (to an extent).
MTB they tweaked the chain/cassette in different ways, so whilst they're the same spaceing (so you can run SRAM shifters/mech on a shimano chain and cassette) the side plates and links are different widths, one has rollers links and sprockets (9s thickness) but thinner side plates, the other has thinner sprockets but ,retains the same side plate thickness as 9s but in a narrower chain. So supposedly SRAM/SRAM and Shimani/Shimano works best for chains/cassettes, but plenty of people have found a mix to work, and the road chains work well enough too, ditto 3rd parties like KMC.
PostPosted: Fri Sep 21, 2012 6:36 pm
The only caveat (as I put) is that some 7 speed may not have enough travel, and yes oversight, it needs to be 7,8,9 speed MTB.
PostPosted: Fri Sep 28, 2012 8:08 pm
I ran a 10sp 105 shifter with a 10sp Ultegra 11-23 cassette and an XTR-M972 Shadow 9sp rear mech. This worked fine.
Blog http://andrewhowett.blogspot.com"
There are no new unread posts for this topic. Does XT di2 fits to Ultegra di2 shifters [11 sp]
johancoenen59
Thu Jun 01, 2017 2:36 pm
PinaRene View the latest post
There are no new unread posts for this topic. Simplex 6600 Super LJ derailleurs
liam7020
Wed Nov 08, 2017 7:58 pm
liam7020 View the latest post
This topic is locked, you cannot edit posts or make further replies. Please read rules
robertpaulsenww
Wed Jun 14, 2017 8:41 pm
robertpaulsenww View the latest post
There are no new unread posts for this topic. Deleted - please read the rules.
montgoma
Fri Oct 27, 2017 1:27 am
montgoma View the latest post
There are no new unread posts for this topic. Post deleted- please read the rules
carbontulip
Thu Dec 21, 2017 4:30 pm
carbontulip View the latest post
Users browsing this forum: No registered users and 4 guests
cron
