It is currently Tue Jan 16, 2018 8:52 pm
Post new topic  Reply to topic  [ 92 posts ]  Go to page 1 2 3 4 57 Next
PostPosted: Sun Sep 09, 2012 2:40 am
a coworker of mine just picked up a new supersix evo with the sisl2 cranks. as any mechanic would do, he started taking it all apart. here's what he found:
compression plug assembly is 14g complete, vs 50g for the old one. crank individual parts have not been weighed (yet).
PostPosted: Sun Sep 09, 2012 3:44 am
I like that plug design. Will have to pick one up on ebay.
PostPosted: Sun Sep 09, 2012 4:23 am
Interesting. Looks like they lightened the spindles.
The new expander is great, have to get one of those since I am running the stock expander since the extralite expander was a piece of crap.
PostPosted: Sun Sep 09, 2012 4:00 pm
which parts are interchangeable with the old SI SL crank?
PostPosted: Sun Sep 09, 2012 9:18 pm
Maybe its just me, but doesn't it look like the Black crank fixing bolt is larger in diameter than the green one??
If so, the black one which I assume is the SiSL2 would not fit the Hollowgram crank...
I was hoping this was the quick fix for my SRM dillema... I can only assume somehow the SiSl2 crank will not play nice with the SRM powermeter... would only make sense... nothing is backwards compatible these days.. grrrrrrrrrrrrrrrrrr
PostPosted: Sun Sep 09, 2012 10:00 pm
Bolt is same diameter, same threads. 12point hole for the 10mm allen wrench lets them take six little slivers out. Bolt is overall shorter, but most of the part chopped off was tapered anyway. Steel washer is more substantial, shinier, slightly less easy to lose.
Spindle is 109mm, a 5mm gain. I am very, very happy about that, as cannondale was simply running their rings too close to the frame for a long time. Now their chainline is inline with road standards. Also plenty of clearance between lockring and pf30 cups, srm should be a drop-in part. Note there is no built-in shoulder anymore, both sides use a spacer. With that, the wavy washer moves to the non-drive side. Inner bore past the threads seems like it's larger, not measured. And, as shown before, holes drilled in the lobes of the splines.
I tested it, bolts are interchangeable, as are arms (onto the spindle).
NOTE- this is NOT the sisl2, but the forged hollow SI cranks, new for this year.
Pics to follow.
PostPosted: Mon Sep 10, 2012 7:34 am
Pics and weight on scale please ;)
I Will make the leap
PostPosted: Wed Sep 12, 2012 6:25 am
here are some pics in no particular order:
14g compression plug assembly
extra-hollow spindle
spindle length (109mm)
sisl2 crankset weight (434g arms, spider, spider lockring, rings, ring bolts)
PostPosted: Wed Sep 12, 2012 5:16 pm
Do you also have the weight of the new lighter spindle?
PostPosted: Thu Sep 13, 2012 1:02 am
when will new spindles and parts be available for sale?
PostPosted: Thu Sep 13, 2012 2:24 am
parts and spindles will be available for sale.
Pariscarbon has one on order from his lbs, apparently it's a bit of a wait right now.
i do not have pics of the new spindle because... because im very forgetful. thats all i got.
PostPosted: Thu Sep 13, 2012 4:22 am
What size were the SiSL2 arms and that appears to be 130BCD spider and gears.
That means 110BCD should be even lighter and I am hoping you say they are 175 arms so that 172.5 are lighter. :shock:
PostPosted: Thu Sep 13, 2012 5:42 am
I have the Spindle kit on order, was 60-90 days... in the meantime I have got the shoulder cut off my 104 spindle so I can use my 2010 SRM on my EVO now...
the 109mm spindle will offer a standard Q factor so I will be swapping out as soon as it becomes available..
PostPosted: Sat Sep 15, 2012 11:55 am
Can you use New crank arms with old spindle? I lucked upon some new SI SL 2 arms on ebay but I can't get the new spindle ...
PostPosted: Sat Sep 15, 2012 8:53 pm
Can you just put on arm on scale?
thanks
There are no new unread posts for this topic. compression plug
addictR1
19
1626
Fri Dec 29, 2017 12:07 am
prendrefeu View the latest post
There are no new unread posts for this topic. Attachment(s) Colnago Ottanta5 - any details?!
greentimgreen
28
4796
Fri Feb 10, 2017 4:45 am
fogman View the latest post
There are no new unread posts for this topic. Time XPro pedals - any details?
BdaGhisallo
34
3342
Wed Jan 03, 2018 11:10 pm
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) New SISL2 crank arms - Is this a defect or normal?
glowder
Wed Dec 06, 2017 11:55 pm
Jenmoss View the latest post
There are no new unread posts for this topic. Hollow gram sisl2 / 109mm spindle / bsa-30mm bb possible ???
caballero
14
1465
Wed Jun 07, 2017 1:00 am
llpatrick View the latest post
Users browsing this forum: joeg26er, Malammik and 37 guests
cron
