Kai-ming's kitchen
kai-ming
by kai-ming
To avoid the unnecessary flaming/provocation laugh that I have received at the recent thread of Shaving material off heavy rim, I list herewith statements to disclaim my responsibility of flaming that might arouse:-
1. I could be new to all of you and I understand my User name is not presentable under European's eyes, however, I am proud of being a Hong Kong Chinese.
2. I am a qualified engineer with B Sc Second Class Honours (1st Division) in Mechanical Engineering from UK, Chartered Engineer for decades. So please equip yourself with the necessary basic engineering knowledge before you open-fire/start the flaming.
3. I will try to be humble and polite to answer any question. However, if I sense provocation of a fight, there is no guarantee that I do not fight back similar to my responses at the above thread.
:mrgreen:
This is my original design of a tuned seat post, how it works is quite similar to recent pencil thin seat stay design aiming to make the seat post/seat tube under controllable flex. Feel free to copy the design and implement into your products if you think it is a good idea, all I am asking is to name the design ''Kai-ming's seatpost''.
:lol:
That is a 27.2mm carbon seatpost with 27.2/31.6mm sleeves fixed to the post permanently (but can be removed easily). The lower sleeve is screwed to the post end while the upper sleeve is AA glued/Epoxy to the post which can be easily debonded by placing a big flat screw driver at the cut slot and turn. I have had problem of slippage of seatpost in carbon frame set, turning the collar too tight might damage the expensive frame set. There is no slippage any more + lower torque at the collar, i.e. a lighter/weaker collar will do the job. Grease can be put at the sleeve/frame interface, so no worry on the fused seatpost/frame problem.
These holes on the seatpost are mainly for making the section flexible which will bend inside the seat tube of the frame under the load of a rider, reduced weight is just icing on the cake.
The post is lighter than any post that I have ever own. :P
HillRPete
by HillRPete
Nice work.
Not sure if your request to for naming is serious, but people have done this before.
http://www.flickr.com/photos/phorsus/6257388080/
http://sfgfc.wordpress.com/2008/05/02/c ... -seatpost/
... many more ...
crohnsy
by crohnsy
You need to post scale pics. Please quantify how much weight you saved in this configuration....
:thumbup: :smartass:
kai-ming
by kai-ming
wassertreter wrote:Nice work.
http://www.flickr.com/photos/phorsus/6257388080/" onclick="window.open(this.href);return false;
http://sfgfc.wordpress.com/2008/05/02/c ... -seatpost/" onclick="window.open(this.href);return false;
... many more ...
It appears that you misunderstand the basic design concept.
kai-ming
by kai-ming
crohnsy wrote:You need to post scale pics. Please quantify how much weight you saved in this configuration....
I forgot :noidea: , reduced weight is of secondary importance. :smartass:
ergott
by ergott
Wouldn't you have saved more weight if you just cut 2" below the top collar? You have a lot of extra seatpost in the frame.
edit. Nevermind, I see what you are trying to do.
Do you have any way of evaluating just how much "flex" you gained with this?
kai-ming
by kai-ming
ergott wrote:....
By riding it with high pressure tires on poor road surface. The flex can be further tuned by increase/decrease the length of the upper collar and/or making the flex section more flexible by drilling with engineering sense.
kai-ming
by kai-ming
kai-ming wrote:
ergott wrote:....
p.s. Do I deserve the naming of the design? :oops: I honestly wish to get comments, good or bad, from your (all of you) heart. :hello:
crohnsy
by crohnsy
Then quantify the amount of flex you are getting please. You are an engineer please provide data to validate your claims
kai-ming
by kai-ming
I didn't bother to do tests to get the flex data. By tuning with the above methods the ride on rough road with high tire pressure is so..so much smoother when seated.
motorthings
by motorthings
The SOTP method of testing, excellent!
kai-ming
by kai-ming
motorthings wrote:The SOTP method of testing, excellent!
Please explain SOTP. :noidea:
prendrefeu
by prendrefeu
Seat Of The Pants.
kai-ming
by kai-ming
Yes,and NO (if you mean to do something difficult without the necessary experience or ability). With educated/trained engineering sense, mind you, this is a concept design.
Craigagogo
by Craigagogo
To take your idea another step further...
Support the post at the clamp as you have done but have no support at the end of the seat post.
Now you would have a cantilevered beam @ the seat which resist the bending moment that is supported rigidly at the clamp and intermittently at the end of the post in the frame.
This allows for large deflection of seat for the first 2.0 +/- mm of movement at the lower end of the seat post. Then as the first 2.0 mm of lower post deflection is observed, secondary flexing due to the further deflection of the seat post that is supported between contact with the frame and at the clamp. You could tune this effect with an elastomer at the base of the seat post.
More than 10 years a Weenie!
