It is currently Sun Dec 17, 2017 1:14 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sat Sep 01, 2012 12:35 am
Hello to all,
I just purchased the new XX gripshift and after installation I noticed that the left front shifter has some rotational movements prior to upshift.
It is roughly between 5-10mm of movement prior to the upshift.
Is this common?
If its not then is it possible to fix it?
Thanks for any insight
PostPosted: Sat Sep 01, 2012 6:54 am
Not sure what you mean, it has to pull the cable to create a shift, also depending on the front mech setup you may have some slack cable it has to take up as well.
Where are you measuring the 5-10mm (and is it 5 or is it 10) a gripshift rotates so an angle would seem a better way of indicating what you mean.
PostPosted: Sun Sep 02, 2012 2:06 am
The short answer is "no".
The instant you start twisting the front derailleur should start moving.
I have XX gripshift with a SRAM X9 front derailleur and the shifting is virtually instantaneous.
PostPosted: Mon Sep 03, 2012 1:19 am
Thanks for the replies and just to clarify, I am guessing (not good at figuring out angles) I can move shifter by 5 degrees before the front derailleur engages. If I put my thumb at a point on the handlebar and using a string to measure until where the FD moves then that is about 10mm.
The left shifter works but if this is not how it is suppose to be then I will just have to push for a replacement.
Thanks again.
PostPosted: Mon Sep 03, 2012 3:17 am
Is the shifter spinning a little on your handlebars? Make sure the shift clamp bolt is tight enough.
Is there any slack in the cable when you've got the chain on the little chainring/shifter in gear 1? If so, the movement at the shifter prior to the front derailleur moving is that slack being taken up and there is an error in your setup.
If the shifter is tight on the bar and not moving as a whole, and there is no slack in the cable when in the easiest gear then there is something wrong with the shifter.
There are no new unread posts for this topic. Campagnolo and Sram mixers question (Mods - could you move this to Road pls)
Mr.Gib
Tue Mar 14, 2017 3:10 am
Mr.Gib View the latest post
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 6 ]
Shrike
75
10919
Thu Dec 14, 2017 7:12 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Sram red 52/36?
commendatore
Mon Jul 03, 2017 9:44 pm
Alpine318is View the latest post
There are no new unread posts for this topic. Sram red leaver pin
SNUGSHIP
Tue Apr 18, 2017 11:00 pm
SNUGSHIP View the latest post
There are no new unread posts for this topic. Sram etap Red
Post Man Pat
Wed Mar 15, 2017 1:01 pm
keiro View the latest post
Users browsing this forum: Yahoo [Bot] and 5 guests
