It is currently Sun Aug 20, 2017 7:07 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Fri Aug 31, 2012 8:58 pm
I made the mistake of opening one of my pd7810s because I was concerned it had got water in the bearings. It hadn't, but I had obviously dislodged something because now it will not close. It gets to within about half a mm on the threads compared to how it used to be adjusted, but not all the way. Correct number of bearings installed (17, 9 and the roller bearing) and it hasn't got too much grease in there whilst I figure out what is wrong. How should the bearing retainer on the larger race sit?
Anyone else serviced one of these or can point me towards a how to? The Park one just says don't do it!
PostPosted: Fri Aug 31, 2012 11:05 pm
See photo below:
http://db.tt/LU9AgwOX
LH pedal is correctly adjusted, RH is not. The first gap between the spindle and the axle cone assembly is too small on the RH pedal, meaning that the axle cone assembly cannot close up snugly to the pedal body. The exploded view
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/PD/EV-PD-7810-2662_v1_m56577569830612675.pdf" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
does not shed any light on how I have managed to move the cone on the spindle, but it certainly didn't require a lot of force! Any help greatly appreciated.
PostPosted: Fri Aug 31, 2012 11:59 pm
Coincidentally, I've been working on overhauling a set of PD-7810 pedals for the last two days.
I posted about it here:
http://forums.roadbikereview.com/compon ... 89166.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
My issue is play in the spindle (assembly). I think my problem may be related to the rubber sleeve (wear?) that sits between the spindle and cone piece, but I have yet to find a way to eliminate the play.
For your issue, can you not simply back off on the locknut? There should be a gap there.
PostPosted: Sat Sep 01, 2012 4:20 am
Sorry to hear is. In my experience, opening a Shimano pedal is the kiss of death. Once opened- they will die in 6 months.
Shimano pedals usually last forever- but when you get a bad one it is all over.
PostPosted: Sat Sep 01, 2012 11:25 am
Thanks guys! Yes, wish I had never touched them. The good side has been perfect from the day I bought them and is buttery smooth after thousands of wet kms. The bad side developed a tiny bit of play but I should never have touched it.
Sanrensho, how do you access the rubber sleeve/get the cone bit off the spindle? Take the circlip off? Yes I can tighten the locknut closer to the pedal body but not far enough, the cone assembly seems to be in the wrong place on the spindle by about a mm and I'm not sure how it got there. The first gap after the pedal thread stopper was about 1.5 mm and is now about half a mom.
PostPosted: Sat Sep 01, 2012 3:38 pm
See the exploded view chart for the components: http://techdocs.shimano.com/media/techd ... 612675.pdf
The rubber seal should be 'underneath' the ball bearings, on the pedal thread side. Use something small and pointy between the bearings to push the seal down if they interfere with the bearings. If the seal sits correctly, the bearings should fall in to place and should be touching each other (there should not be any gap!) when you push the lock nut towards the circlip. If they do not fall into place while assembling, push the locknut up so the bearings sit in the right place while assembling.
PostPosted: Sat Sep 01, 2012 8:23 pm
^^ daj, top man, thank you. I don't think the seal is seating properly as the bearings are not sitting together, I will try to push it back gently and then rebuild with fresh balls.
PostPosted: Sun Sep 02, 2012 7:19 pm
Thanks for this, daj. It sounds like the rubber seal needs to be sitting a certain way when the axle assembly is finally inserted into the body, but I'm having a hard time picturing this.
Do I need to position the rubber seal in the direction of the bearings, so that the seal and sliding part (cone) eliminate any play between the cone, bearings, and circlip? So it's a positioning/play adjustment that needs to be done right before reinserting the axle assembly into the body?
Thanks!
PostPosted: Sun Nov 17, 2013 3:05 am
So my left hand DA 9000 pedal seems to be 'leaking' grease
only just noticed it. Which given my bike is washed every couple of rides, can only be within the last day or so.
Spinning the pedal it also feels 'rough'. Thoughts?
http://www.nicksquillari.com.au
The Gram
The Men of Steel
PostPosted: Sun Nov 17, 2013 5:37 am
If it feels rough it needs a rebuild. Probably including a new seal.
PostPosted: Tue Sep 02, 2014 4:30 pm
I guess I will be testing that theory.
I have a 7900 set that was still very smooth, but was in fact so frictionless that the pedals wobbled around wildly and made it difficult to clip in.
I had just come off experimenting with the Look Keo Blade 2, which doesn't rotate at all when unclipped, which was actually easier for me to clip into because they stayed in the position you last unclipped.
So I removed the spindle assembly from the 7900 set (just as shown in the Park Tools webpage instruction) and jammed the bearings full of a heavy marine grease without removing the bearings from the spindle assembly. I then pretty easily adjusted the bearing preload so that they are smooth, with no play or noticeable bearing drag.
It seemed successful; it "quieted down" the rotation of the pedals, but they are still low friction and smooth, just a lot more viscous. It was really quite simple with 20mm and 17mm cone wrenches. We'll see how long they last now, and I will report back.
PostPosted: Thu Apr 07, 2016 11:36 am
Thread resurrection...
@Rick;
1. Did the pedals remain smooth after you serviced them?
2. When you took them apart, did you by any chance get a look down into the pedal body, and check out the loose ball and needle bearing assembly? If so, how was it positioned? Were the loose balls sitting right at the end of the pedal body cavity, with the needle bearing sitting further in, around the middle of the axle?
Would love to be able to find a cutaway diagram / photo of an assembled Dura Ace pedal.
My Youtube Channel; Technical Bike Stuff, LOLz and Neo-Noir visions from the mirror realm
PostPosted: Thu Apr 07, 2016 8:45 pm
There's diagrams in DM-PD0002-07-ENG.pdf (the dealer manual) in the techdocs link above.
The balls and needles at the end of the axle have always stayed in place for me. Doesn't mean they will for you of course.
I have taken three or four apart and they're all still working well.
PostPosted: Fri Apr 08, 2016 3:26 am
@Rick;
Yes. No problems at all. I am still using them and they are very smooth. In fact, I have not regreased or anything since that original posting, and I was shocked to look back and see how old it is!. The heavy marine grease did exactly what I had hoped and the pedals still feel a lot more viscous than stock, but the bearings are still smooth.
Well, I don't remember specifically, except that I think I MUST have looked down into the body because I tried to get it really "packed tight" with grease. It was oozing grease pretty good as I was screwing the cover back into the body. I didn't see any "loose" bearing in there. Maybe it was just held in place by the original grease. :noidea:
There are no new unread posts for this topic. Tips for dura ace 9000 hood replacement.
SpecializedColnago
Wed Jan 25, 2017 7:21 pm
rossjm11 View the latest post
There are no new unread posts for this topic. Look pedal removal - allen key vs pedal wrench?
mvcap
Thu May 11, 2017 1:40 pm
Geoff View the latest post
There are no new unread posts for this topic. Colnago warranty service?
wilwil
12
1051
Sun Jun 25, 2017 5:48 pm
wilwil View the latest post
There are no new unread posts for this topic. Attachment(s) Comparing frame geometries\fit tool\service
itsacarr
26
2083
Fri May 26, 2017 1:08 pm
itsacarr View the latest post
There are no new unread posts for this topic. Fetha mount for Zipp Service SL Stem
SpecializedColnago
7
716
Tue Feb 21, 2017 4:13 pm
Shrike View the latest post
Users browsing this forum: estrin, Google Adsense [Bot], HFGent, Juggernaut, sun and 24 guests
