It is currently Fri Dec 15, 2017 5:29 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Fri Aug 31, 2012 8:53 am
help me
i used m2racer 31.6mm seatpost
Saddle craddle cracked are separate ..
now be discontinued spares m2racer can not be obtained.
Please inform us if you know the company or parts cradle compatible
thanks
doublerls
PostPosted: Fri Aug 31, 2012 2:07 pm
There is a reason M2Racer went out of business. I have several of their items and they were the lightest ever, but they all pushed the limits and eventually failed.
You can have light, strong, cheap choose any 2. In the case of M2 their stuff was extremely light and reasonably priced for the weight, but not strong. To make something as light as their seatposts that was actually strong would have cost 5 times as much.
For certain parts stiffer is more important than lighter.
PostPosted: Fri Aug 31, 2012 2:44 pm
You can try smud carbon.....may be compatible.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Fri Aug 31, 2012 5:40 pm
Lynskey also has a nice carbon cradle that cradles the entire rail for $25 with hardware. You'll have to measure yours and call them.
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Fri Aug 31, 2012 6:09 pm
the lynskey cradle weighs 13 grams!
PostPosted: Wed Dec 12, 2012 1:12 pm
The Lynskey cradle look nice, but when i tried to order one, they asked for $105 in shipping to Norway :evil: . That's insane for a small $25 part. Sendt them an e mail, and will post their answer when I get it.
Why does Shimano paint their groupsets the way they do? If i wanted fifty shades of grey - I'd buy the book.
PostPosted: Wed Dec 12, 2012 1:41 pm
Tubbie Guru
Hi,
From what I recall the reason they went out of business was the materials' prices going through the roof.
Maybe some of their products were pushing it but I own a few items by them and nothing's ever failed so far. Besides that quite a few of these products are now being copied and marketed by others. Some of which even lighter than the original ones.
I view M2Racer more as pioneers running into a bad set of circumstances rather than people that just pushed it too far.
Ciao, ;)
PostPosted: Wed Dec 12, 2012 3:06 pm
FibreLyte may do you a custom one. Call Stephen and ask if they would and cost etc.
PostPosted: Wed Dec 12, 2012 5:39 pm
Nice one. I'll remember that for when I make my next balls up.
PostPosted: Wed Dec 12, 2012 7:04 pm
The cradle from kcnc is widely available. For instance bike-components sell these. Also from R2 bike you can get some cradles.
PostPosted: Wed Dec 12, 2012 7:18 pm
That looks almost identical to the lower cradle on the Hylix zero offset seatposts on ebay, it even has the hole which will let lots of water into your frame if the post top is hollow.
File comment: Hylix post
PostPosted: Thu Dec 13, 2012 1:00 am
Tubbie Guru
Hi,
The bottom part of the seesaw would then go on top IIRC, the hole in the centre will let the bolt pass and there should go some sort of cylindrical nut to keep it all in place, correct?
If not that part is just an aluminium (?) half-pipe with the corners rounded so it can clamp the rails of the saddle down.
Seems easy enough to have it machined in a workshop.
Ciao, ;)
PostPosted: Fri Dec 14, 2012 2:03 am
Go on ebay and do a search for omni racer. Same cradle.
http://www.hackracer.com/
PostPosted: Fri Dec 14, 2012 3:01 am
Do you have any off cuts from steerers or seat posts. The LBS should have some bits of steerer.
If you can find a carbon tube that fits the curve you can jury rig a cradle pretty easily.
r o y g b i v
PostPosted: Fri Dec 14, 2012 8:06 am
I bought about 10 pcs Smud carbon cradles, they do fit with minimal sanding.
They were lighter than AX Europa cradles.
7 grams each if I recall right.
Experimental Prototype
There are no new unread posts for this topic. Cracked my Supersix hi mod
tarmackev
10
2335
Tue May 23, 2017 1:22 pm
Calnago View the latest post
There are no new unread posts for this topic. Attachment(s) Cracked Brand New Emonda :-(
Geordiepaul
19
2605
Sat Aug 12, 2017 9:30 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Pacenti SL23 cracked, now what?
DeLuz
11
934
Tue Oct 17, 2017 10:56 pm
hmai18 View the latest post
There are no new unread posts for this topic. Attachment(s) Cracked Fork or Paint Chip?
BlueberryCake
Tue Dec 12, 2017 7:26 am
AJS914 View the latest post
There are no new unread posts for this topic. Best frame for short bike racer
LouisN
14
1040
Tue Jul 11, 2017 4:30 pm
topflightpro View the latest post
Users browsing this forum: BobbySweeting, Google Adsense [Bot], gospastic, Jian81 and 38 guests
