Tuned Dura-ace 7900 group.
kevosinn
by kevosinn
The cut off bolts worked perfect! Probably didn't save much weight but it looks cleaner.
Snicks
by Snicks
Brakes next or is that TOO weenie...
(I kid myself, nothing is too weenie right?)
No but seriously, I know the DA brakes will always be chubby chubby but imagine dropping some weight off those and still keeping the braking performance...
kevosinn
by kevosinn
Nothing is to weenie haha but I know someone that machined out some DA brakes and they did get pretty flexy. Im running the AX lightness calipers right now at 107 grams so im ok there! :)
lechat
by lechat
I think you could probably remove a chunk of material and still retain their stiffness. You'd have to maintain their outline and not monkey with the pivots. A lot of the KCNC's flex comes from play in the pivots, especially the 1st gen. where you have aluminum on aluminum.
PSM
by PSM
[quote="Frankie - B"]Do we need to ban psm from weight weenies because of his responses. I suggest a couple of hours, purely for not being ww enough. ;)
:lol:
PSM
by PSM
DRILL THE FRAME AS WELL !! :D
kevosinn
by kevosinn
HAHA THATS NEXT!! .......not
deluxerider
by deluxerider
very cool. it looks very race only.
Valy
by Valy
mad, but i gotta ask - did you make the arm thing on FD shorter with the tuned part? Would not that make shifts require more effort?
kevosinn
by kevosinn
Nope the arm is the same length!
oysters
by oysters
kevosinn wrote:The cut off bolts worked perfect! Probably didn't save much weight but it looks cleaner.
How long were the bolts after you had cut them down? Would these have fit/done the job (the "Titanium Platform Pedal / Socket Set Screws" on the page below). Being allen head grub screws, it wouldn't matter if they didn't protrude from the top of the derailleur so that you can use a screwdriver. Not sure if there would be a much of a weight difference between a cut down Al bolt vs a slightly recessed Ti grub screw, though the latter might be more elegant.
http://www.torontocycles.com/Selling/Titanium.html" onclick="window.open(this.href);return false;
I think they also sell an 11mm long version.
austke
by austke
I love Colnago's and I love Tuning, Both together is TOTALY AWESOME!!!
Top work, I like the bare essentials look that tuning gives, Yes Racy, is what somebody mentioned. I agree. :beerchug:
I am about to attack my brand spankers XTR front mech (which unfortunately weighed exactly the same as my cheapo no name brand front mech, 127gr) and shifters that are for my rather average Triple Tandem. All in the pursuit of weight Weenieness, not looks. 8)
austke
2013 Giant TCR Advanced SL 0, 6.92kg
2013 Giant Defy Composite 2 M, 8.5kg - Wife's
Azzurro Torino 8.55g
Fuji 650 10.8kg
Miele Lupa Triple Tandem 38,89kg
markyboy
by markyboy
Does it effect the function of the rear mech at all with all the changes?
COLNAGO C60 SUPER RECORD EPS
Pinarello f8 sram etap
Eddy merckx 69 ultegra disc winter bike
kulivontot
by kulivontot
I'm ok with this. I think I draw the line at drilling structural components. IE wheels, seat post, frame, saddle rails... Although I am aware others here have no qualms with this...
kevosinn
by kevosinn
The front and rear derailleur work EXACTLY the same as stock. You really can't tell a difference. I'm planning on drilling it out more to get it under 140 grams.
