It is currently Tue Jan 23, 2018 3:20 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri Aug 24, 2012 8:08 am
I'm trying to remove a fork from a steel track frame with standard type threaded headset. I am holding the bottom nut above the headtube with a headset spanner, and trying to remove the top locknut with a large strong headset wrench. both are 32mm and fit the nuts.
No luck.
Feels like the top lock nut is stuck to the steel fork. It doesn't seem damaged as the headset and steering work fine. Im afraid to grab the fork from underneath the headtube to apply more pressure as I don't want bend the fork.
Lock nut is aluminum and fork is steel.
Any suggestions?
PostPosted: Fri Aug 24, 2012 1:10 pm
I think that's what you do when you have tried to undo the locknut with two wrenches. Plenty of WD40 might, of course, eventually help free the locknut.
A standard open-ended headset wrench is not the best thing for a locknut. You get proper locknut wrenches which provide more all-round grip, and your local bike mechanic might have one of these.
PostPosted: Fri Aug 24, 2012 10:47 pm
Plusgas is alot better than WD-40. Why even let WD-40 with 100ft of a bike.
www.thecycleclinic.co.uk
PostPosted: Sat Aug 25, 2012 8:14 pm
for seized bolts you could:
-Spray with penetrating oil (wd40 is not a good on at that, use PB blaster)
-"scare" it free, by tapping it
-using "reverse psychology", sometimes a bolt will go tighter and then free itself up
-use heat
-use ammonia when corrosion is the possible culprit
  • 2011 Cannondale Flash F1
  • 2010 Cannondale Caad9
  • 2000 Caad 4 aero
PostPosted: Sun Aug 26, 2012 1:18 am
Good ol' Galvanic corrosion. It used to be quite common during the stell frame/ alloy seatpost era.
If you don't require the headset, use heat. Mind you, if it's corroded in place, the headset's likely toast anyways. So yeah, heat. Keep in mind if you're using a torch to be aware of any previous chemicals you might have already poured into it. You might not like the end result if not.
PostPosted: Tue Aug 28, 2012 5:58 am
Thanks all. Sprayed it with some lube and bought a good park wrench and spanner and got it off finally.
There are no new unread posts for this topic. Middle threaded hole for Sidi Shoes?
Cheers!
11
1231
Thu Jan 26, 2017 3:13 pm
duvivr6 View the latest post
There are no new unread posts for this topic. Attachment(s) Fork Needed - straight, carbon, 1" threaded steerer - suggestions?
dadoflam08
12
756
Wed Jul 26, 2017 11:31 am
dadoflam08 View the latest post
There are no new unread posts for this topic. F10: Which headset top cap options are available?
TonyM
7
660
Sun Dec 31, 2017 11:02 pm
TonyM View the latest post
There are no new unread posts for this topic. CAAD12 headset
tomee
Fri Feb 03, 2017 1:58 am
tomee View the latest post
There are no new unread posts for this topic. Headset question
thebadgerboy1982
Sun Mar 12, 2017 11:21 pm
froze View the latest post
Users browsing this forum: Google [Bot], L3X, LAN, ms6073, nestornnk, Succisa75 and 49 guests
