Front derailleur hanger specific to frame?
Rideuphill
by Rideuphill
I assume a front derailleur hanger is built specific to each frame manufacture? Is that ture? Long story but i bent my front derailleur hanger on my road bike and managed to get it straightened back out and got everything working again but thought it wouldn't hurt to have a spare kicking around.
Do you normally have to order one straight from the manufacture?
Thanks,
prendrefeu
by prendrefeu
Only if the front derailler hanger/mount is removable for your frame.
More often than not, they are either riveted in or directly moulded (if CF)
Trek models may have the capability of replaceable front derailleur mounts, as BTP makes a 'lighter' version for upgrades. :D
Rideuphill
by Rideuphill
Thanks, I had to take mine off the bike to straighten it. Just haven't had time to stop at a shop to ask if they are available or if I should just contact the manufacture directly.
seandonovan
by seandonovan
Could you post some more details about this? Year/Make/Model in particular. A picture would be excellent.
Rideuphill
by Rideuphill
Norco
CRR SL
2011
cerro
by cerro
prendrefeu wrote:Trek models may have the capability of replaceable front derailleur mounts, as BTP makes a 'lighter' version for upgrades. :D
Seems like Cannondale does it too. A friend at work got a new derailleur hanger from Cannondale and changed the broken one on a SuperSIX Evo frame.
/jonas l
thisisatest
by thisisatest
that looks an awful lot like the one used on Specialized Transitions.
Cervelo p4/5 may be similar enough.
kuota kfactor too.
LouisN
by LouisN
Rideuphill,
Just came on this today.
Norco had some issues with 2010-2011 CRR's front derailleur hangers. The alloy piece was too soft. It happened to a friend's Norco too.
Norco simply sent a 2012 FD hanger. Problem solved, under warranty.
Louis :)
Rideuphill
by Rideuphill
Thanks LouisN,
Norco seems impossible to contact but I ended up finding one at a local shop and they said it was recently sent to them directly from Norco. That was September 2012 so hopefully it is the modified version you speak of.
Thanks again,
