It is currently Wed Jan 24, 2018 5:08 am
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
 Post subject: Very weird bike
PostPosted: Fri Aug 03, 2012 7:10 am
Hi guys,
Does anybody know what the heck this is, other than its a bike with a lot of carbon on it...
it was taken by some guys in trento italy.
 Post subject: Re: Very weird bike
PostPosted: Fri Aug 03, 2012 7:22 am
Are those another set of arms attached to the crank arms? The q-factor must be really wide with that..
Bike: Felt FC
Strava
PostPosted: Fri Aug 03, 2012 7:28 am
:unbelievable:
I'm seeing an interesting stem...
...and interesting rear wheel fairing...
... wth is that thing on the back?
and the bottle cage is glued on...
...and the fork looks to be all custom, too.
and the frame has a strange underside of the downtube, almost like it's not aero but more of a stringray shape.
and those pedal extensions are built off of THM Claviculas!!
And those are Lightweights....
:unbelievable:
Tell me you took more detailed shots!!
Where was this spotted?
PostPosted: Fri Aug 03, 2012 7:54 am
Interesting might be an understatement here.
The BB seems really high though, like 400mm. Although you would need it, as the two-piece crank arm would likely be 340mm when extended (that would mean pedalling in really really large circles?!).
Could be an electric bike though, with all the contraption behind the seat tube and within the fairings.
Do show more pics.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
PostPosted: Fri Aug 03, 2012 7:56 am
im sorry i dont have any more pics. not me that toke them :(
It was spotted it trento, Italy
PostPosted: Fri Aug 03, 2012 8:00 am
at the moment im thinking its a mad man with to much time on his hand with a lot of carbon or some kind of hybrid bike.
Since it was spotted in Italy. I thin the first teory might be the correct one.
PostPosted: Fri Aug 03, 2012 9:27 am
Do show more pics.
If not eletrict it might have some other solution inside that giant BB area for get some energy while pedaling (a spring?).
My current ride
PostPosted: Fri Aug 03, 2012 9:29 am
The pedal construction is plain weird. A moment I thought perhaps this guy is disabled and can't bend his knee, but even then the contraption is pointless. Why even bother with the crank in the first place if that is the problem.
PostPosted: Fri Aug 03, 2012 10:27 am
That kind of crank assembly allows multiple crank lengths by varying the angle between the two arms. Similar things are used on some size cycles. Why it is built off a clavicula donor crank is a mystery though?
The large metal plate at the bb allows the bb to be positioned at various heights by rotating it to the desired position.
My guess is that its some kind of whack-job size cycle. With lightweights. And a bazooka. And full carbon construction.
PostPosted: Fri Aug 03, 2012 10:33 am
Its a prototype ,its what Sky will be riding next year . :lol:
PostPosted: Fri Aug 03, 2012 12:31 pm
errm... he has a mirror!! wtf is this? :noidea:
PostPosted: Fri Aug 03, 2012 12:33 pm
Um. Surely that thing on the back is the battery pack for an electric motor, and the bizarre pedal arrangement is set up like the throttle pedal on a motorbike? ie. it's not a human powered machine. You'll notice wires coming out of where the BB is, and the oversized chunky construction is probably necessary to contain and resist the forces generated by the motor.
PostPosted: Fri Aug 03, 2012 12:55 pm
I am so very confused. Would you be able to pedal that? I can't help but think that a normal pedalling motion would yield you very little power at the bottom bracket
PostPosted: Fri Aug 03, 2012 1:09 pm
My first thought was it is set up for someone with a BKA and a cleat on their prosthesis. Then to make me more confused I noticed that the drive side crank doesn't appear to be anywhere that makes sense. If it was 180 to the non-drive side you should see it from the angle in the top picture. It doesn't look to be at the same position either if set up like motorbike as mentioned above as you would also see the through the rear wheel.
I will be very curious to see what it is.
PostPosted: Fri Aug 03, 2012 3:59 pm
Right pedal is also at the bottom, visible under BB. Wires from BB and wires from the "water bottle"/battery behind saddle
Would hazard a guess its a gearbox in the BB and the cranks allow peddaling if needed, but fold for powered drive and more comfy feet position. Looks like a internal geared read hub as well
Cervelo S3 2011. Blinged 6.718 Kg
There are no new unread posts for this topic. Attachment(s) Weird discoloration on carbon fork
dtsftw
Mon Dec 11, 2017 4:30 am
OutbackKid View the latest post
There are no new unread posts for this topic. Attachment(s) Weird Lightweight Chinese Steel Frame - CLR6200 Reynolds 520
waltthizzney
15
2639
Sat Nov 18, 2017 12:43 pm
ernestkus View the latest post
There are no new unread posts for this topic. Which one is fastest? UCI Time trial bike or non-UCI triathlon bike?
TonyM
Tue Dec 26, 2017 8:30 am
bllx View the latest post
There are no new unread posts for this topic. Help me find a bike article. Does anyone remember this bike?
alcatraz
10
1257
Sat Aug 05, 2017 8:08 am
alcatraz View the latest post
There are no new unread posts for this topic. 5kg bike claimed as "Worlds Lightest Bike"...
jimaizumi
11
3253
Sun Jun 25, 2017 5:40 am
SK5 View the latest post
Users browsing this forum: Baidu [Spider], dim, Google [Bot] and 32 guests
