It is currently Sat Dec 16, 2017 12:16 pm
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: Braze on or clamp on ?
PostPosted: Sun Jul 29, 2012 12:32 pm
Just trying to find out which is going to be stiffer and offer better shifting, a braze on front mech with a carbon clamp or a built in clamp on front mech ?
PostPosted: Sun Jul 29, 2012 1:53 pm
I'd say that the forces involved are relatively small and that it doesn't matter at all ;)
PostPosted: Sun Jul 29, 2012 3:57 pm
If it's a "braze on" then the stiffness is going to depend on the way the manufacturer has dealt with it.
I note that Campy has had to introduce a stiffening gizmo because on some frames the braze on is not stiff enough to handle their EPS FD.
My view is that a clamp on system is probably more reliable, and offers better adjustability too.
There's sometimes a buggy.
One.
PostPosted: Mon Jul 30, 2012 3:48 am
Always hated the clamp on. It marks up the frame. Braze on! BS on that stiffness bit.
If the frame can't handle a front derailleur then that frame is not worthy of components.
PostPosted: Mon Jul 30, 2012 6:27 am
Cervelo's "braze ons" come to mind as being particularly awful.
If building up a steel or ti bike, go with braze on. Same if the mount is integrated into a carbon frame's mould. Otherwise, you don't have much choice. Shifting on a clamp-on style front derailer will typically be a little better than using a braze with lightweight adaptor if your rings are problematic. However, I'd wager a braze fd with a parlee or k-edge adaptor would be a bit lighter.
PostPosted: Mon Jul 30, 2012 7:35 am
Clamp-on derailleurs mount very solidly. If youre going to be using a carbon clamp, however, youre removing the clamp-on derailleur's one possible benefit. Braze benefits mostly revolve on not requiring the seat tube to be one of three round sizes. The seat tube also no longer has to bisect the bb. Many companies pay too little attention to fd mounting stiffness and adjustability, although more and more are waking up.
A side note, why doesnt shimano include the fd support setscrew of di2 derailleurs on mechanical derailleurs? They would certainly be a benefit on some bikes w weak mounts.
PostPosted: Wed Aug 08, 2012 5:52 am
Won't dent your CF seat tube w/ a designed-in braze on bracket. (friend's Super Six dented @ FD clamp location)
PostPosted: Wed Aug 08, 2012 9:40 am
Administrator
I went from a clamp on Record to a braze on using a Parlee carbon adapter. I really can't tell the difference in shifting but it is lighter! :beerchug:
RESIDENT GRUMPY OLD MAN.
PostPosted: Wed Aug 08, 2012 5:11 pm
I don't think it matters much;
But I notice that on quite a few carbon frames, the "braze-on" tab is really a "pop-rivit-on" tab. In those cases I think clamp on would be more reliable and secure.
PostPosted: Wed Aug 08, 2012 5:23 pm
On my carbon colnago frame the braze on has 4 pop rivets. It not going to go anywhere.
PostPosted: Wed Aug 08, 2012 5:59 pm
No brazing torch involvement, so I'll vote for the "integrated clamp", since it's lighter and looks better.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Wed Aug 08, 2012 6:11 pm
Cervelo's pop-rivet braze on hangers are awful. I have one on my slc-sl and it is FLEXY :oops: but my r5 has a molded carbon one that is very stiff and solid feeling :thumbup: .
Like socratease said, braze is lighter in most cases and can be stiffer if done correctly! If you run rotor or other elliptical chainrings, especially in large gearings like 54+, sometimes the braze on hangers don't have enough adjustment however. Same thing if you feel like running CX 36/46 gearing on a road bike (I don't know, just an example that I've tried!) - where the adjustment of the braze on is normally limited.
PostPosted: Wed Aug 08, 2012 8:19 pm
I doubt that the 54 chain ring would be a problem for a braze on.
Maybe a 60 tooth.
Also it would not be good to have braze on on ultra thin tubing walls.
For those a clamp is better.
PostPosted: Thu Aug 09, 2012 7:05 pm
Stella - I experimented with a 53 t rotor ring a while back to a 7800 front d and had to dremel a little material off of the braze on as I couldn't get the derailluer to sit high enough to clear the rings (eliptical, not round)... Can't quite remember what bike it was on - I think my Cervelo scl-sl but not sure. I don't think Sram front d would have this issue as they come with two mounting bolts for the front deraill and thus have a lot more adjust ability.
PostPosted: Thu Aug 09, 2012 7:59 pm
Thanks. My experiences were with round rings only.
There are no new unread posts for this topic. Supersix Evo braze on replacement
nickf
Tue Aug 01, 2017 9:13 pm
androidavies View the latest post
There are no new unread posts for this topic. Need someone to braze bosses: recommendations?
whydobearsxplod
Sat Sep 30, 2017 12:21 am
skimaxpower View the latest post
There are no new unread posts for this topic. ISO: Centaur 10 Speed QS braze on front derailleur
in Wanted
VTR1000SP2
Wed Nov 08, 2017 2:43 am
VTR1000SP2 View the latest post
There are no new unread posts for this topic. 30.8mm seatpost clamp on 30.0mm frame
Luca79
Fri Jul 28, 2017 7:01 am
kman View the latest post
There are no new unread posts for this topic. Ultralight 29.8mm seatpost clamp?
in Wanted
jahknob
Thu Oct 05, 2017 9:57 pm
jahknob View the latest post
Users browsing this forum: Attermann and 9 guests
