It is currently Sun Jan 21, 2018 4:02 am
PostPosted: Fri Jul 27, 2012 1:33 pm
I am thinking it's about time to replace the bearings in my Powertap Hub. I have the Pro+, and I bought it last May. It's making some interesting sounds, I know the bearing suck to begin with, and I was caught in a really dirty super heavy rain on dirty roads for about 3 hours last weekend...can't be good for bearings.
I saw this video online: http://www.youtube.com/watch?v=fS_BL1b2wns
The video is helpful, but it only shows one bearing being replaced. Isn't there at least 2? Does anyone know how the drive side bearing is replaced?
What bearings would you all suggest I order to replace the existing ones? I was looking at these (http://www.bikeman.com/BB1692.html) but honestly have no idea if that is a good bearing or a good price.
I have Campagnolo freehub, but it is less than one year old (switch from Shimano to Campy late last year) so I am thinking the bearings in it are fine.
If anyone could clarify those few points I would really appreciate it.
Thanks!
PostPosted: Fri Jul 27, 2012 1:44 pm
Search, there are plenty of Powertap bearing issues just on this forum. Just so you know, it's not the bearings that fail, it's the machining of the hub that loads the bearings too much. I had a new SL+ hub that would eat bearings every 300 miles. After 4 sets, they finally gave me a new hub [That new one is back at Cyclops for power reading issues now]. Service is great, product is not so.
PostPosted: Fri Jul 27, 2012 1:47 pm
Thanks Butcher. Is there an easy test or something I can do that will help me shed some light on the condition of the existing bearings? I don't know that these ones are bad, I just know they aren't the best bearings to begin with so I figured it wouldn't hurt to replace them and get a higher quality bearing in the process.
I was looking online, and there are a ton of "ceramic bearings" with a huge price range:
http://www.ebay.com/sch/i.html?_nkw=690 ... ic+bearing" onclick="window.open(this.href);return false;
Can anyone help clarify which are good, which are bad, etc...? I want to get good bearings, but don't want to spend more than I need to.
Thanks in advance.
Deleted quote. Please DO NOT quote immediately previous post. PP
PostPosted: Sun Jul 29, 2012 1:42 pm
I honestly cannot remember the brand of bearing that they are using, but it is not a cheap no name brand. It's really hard to blame a good bearing for failing. It is either used in the wrong way or not set up correctly. Roller bearings should not have [or very low] side load on them. Matter of fact, I have some Easton wheels [which I love] and never had an issue with bearings. They have an adjuster and I make certain there is a very slight amount of play so I know there is no side load on the balls/races.
The Powertap hubs are machined so there is no type of adjustment. If the hub is machined incorrectly, there is too much load on the sides of the bearings which caused mine to fail [as little as 100 miles to totaly seized by 300 miles]. They did not agree with my opinion and since I am just a consumer with no engineering degree, it took awhile to convince them it was not me but the hub. A new hub did fix my bearing issue but a year later, I was generating +1400 watts [and 300 watts while coasting]. They have them now and getting fixed.
The service dept. at Cycleops is fine. They have treated me with respect, listen to my frustrations, and have calmed me down after a frustrating weekend with a seized rear wheel. I would not buy another SL+ hub, but because of their service, may look into their newer hub design [it can't be worst could it?].
PostPosted: Sun Jul 29, 2012 3:26 pm
At least the G3 hub has a different design. The axle might still be captured by the main hub bearings (couldn't tell), but the NDS cap no longer presses against the bearing inner race (instead it just presses on the axle end), and the freehub has a little lateral play, so those aren't captured either. Should be more more forgiving.
dhendriksen... don't spend a lot on bearings... it's a waste of money.
formerly rruff...
PostPosted: Mon Jul 30, 2012 7:54 am
I prefer the enduro abec5 steel bearings over any of their other offerings, steel or ceramic. Just a solid, well made, maintainable bearing for just a little more than their standard ones.
PostPosted: Tue Jul 31, 2012 8:27 pm
Thanks for the responses guys. Like I said, I am getting a definite "scraping" sound, and it doesn't matter if I'm pedaling or not. In my eyes it HAS to be in either the front or rear hub. It seems that it is worse and ALWAYS present when I lean to one side.
So, I have a gift card to Amazon and figured why not use it for this. I'm looking at this bearing: http://www.amazon.com/S6902-2RS-Ceramic ... 02+Bearing" onclick="window.open(this.href);return false;
I am going to need two of them, right? And if I understand it, those two are for the drive train side? What do I need on the NON drive train side? If it makes a difference, I have Campagnolo.
PostPosted: Wed Aug 01, 2012 5:53 am
Inspired by this thread, I just checked my SL+ bearings and they were a bit gritty feeling. They are about a year old.
So I tried an old trick for lazy guys: I just pulled out the outer seal and sprayed the hell out of the two hub bearing with WD-40. I blasted the crap out of them to get rid of any dirt. Spinning and blasting with WD-40 until they felt a little cleaner.
Then, allowed them to dry a bit, repacked them solidly with Phil Wood Grease and zipped to whole thing back up. I didn't touch the cassette body bearings.
Big improvement!
But they are still far less than "perfectly smooth" so I guess I'll get some bearings on order and plan a project for early autumn.
PostPosted: Tue Oct 29, 2013 8:40 pm
You can change the hub bearings...It's easy...
You can press the drive side bearing in using a threaded rod with the olf bearing and some large washers...Pretty straight forward...
6902 - drive side bearing and 2 more of those in the freehub,,,
http://www.bearings.uk.com/acatalog/6902_Bearing.html"
Everything to measure power is within the hub, you do not disturb it...
PostPosted: Sun Nov 03, 2013 4:47 pm
I don't know of any Powertap hub that has 6902s in the freehub. Those and the NDS are 6802s.
formerly rruff...
There are no new unread posts for this topic. Replacing Bora One 35 Disc Freehub
taylorpetie
Tue Sep 26, 2017 6:39 am
TonyM View the latest post
There are no new unread posts for this topic. Replacing my Ultegra 6500 BB on my Trek 5200
nelsontod
Tue Aug 15, 2017 7:21 pm
nelsontod View the latest post
There are no new unread posts for this topic. Replacing batteries in ETAP shifter levers
goldmine848
7
656
Fri Dec 08, 2017 11:59 pm
oldnslow2 View the latest post
There are no new unread posts for this topic. Consensus on Merxcks Liege75? thinking of replacing a Schwinn Peloton 853 (circa 1998).
Catagory6
Sat Jan 13, 2018 4:31 am
mmendoza87 View the latest post
There are no new unread posts for this topic. Powertap G3 Hub spacing
joeyb1000
Fri Dec 29, 2017 11:44 pm
joeyb1000 View the latest post
Users browsing this forum: Bing [Bot], joejack951, springs and 18 guests
cron
