It is currently Sun Oct 22, 2017 11:03 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Fri Jul 27, 2012 8:56 am
I am a new user and have been struggling with a frame size issue recently. Was curious to see what some of the more knowledgabe/experienced posters here might say.
I am 181 cm tall with an 89 cm inseam. Also have short femurs so I have a forwardish setback. Currently riding two Colnagos: one is a Super from the mid-80s in size 57 and one is CT2 in size 58. I am not sure if my CT2 is too big.
While the Super fits quite well, I can't seem to dial in the CT2. The Super has a TT of about 55.7 and the CT2 about 56.3. Super currently has a 100 mm stem, but I could probably bump it up to 110. CT2 has a 110. In terms of drop, the Super is right on the limit of comfort for me (about 10.5-11 cm), while the CT2 is around 9.5 cm.
Would it make sense to drop down to a 100 stem on the CT2 to solve what I suspect are reach issues (neck and shoulder pain on rides over 40km)? Is it possible the CT2 frame is simply too big?
PostPosted: Fri Jul 27, 2012 9:08 am
In standard Colnago geometry, at your height, I would have said a 58 is a size too big. Younger guys tha me would probably go for a 56.
PostPosted: Fri Jul 27, 2012 10:24 am
I think with my leg length though, the drop is almost perfect on the 58. I am not sure I could handle the drop on a 56. I just don't get why I feel like I am reaching on the 58; according to the numbers the increase in reach isn't that much.
PostPosted: Fri Jul 27, 2012 10:31 am
Have you got similar saddles and are the setbacks the same on both bikes?
Buy a cheap shorter stem to experiment with.
PostPosted: Fri Jul 27, 2012 11:57 am
Yup. I run Regals on both bikes and setback is identical. Was hesitant to try a 100 on the 58, as I didn't want to go shorter than 110, but I guess a 100 is still within the standard parameters of fit for the frame.
PostPosted: Fri Jul 27, 2012 1:12 pm
I don't know if the STAs are different, otherwise 6mm difference in TT is between stem sizes.
The other possibility is a different reach on the handlebars + the TT difference.
Measure from the tip of the saddle to the centre of the bars to check.
PostPosted: Fri Jul 27, 2012 1:56 pm
STAs are slightly different -- CT2 is just a bit slacker. Difference from saddle tip to bar center is .5 cm. I suppose it could be that the 10-speed hoods on the CT2 are accounting for the difference, since my Deda bar has about the same reach as the old Cinelli 64. The Super has C-record hoods.
I guess the 110 stem needs to go.
PostPosted: Fri Jul 27, 2012 4:34 pm
I also think 58 may be big for you. I am 182cm and ride a 57.
My 6536gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Fri Jul 27, 2012 10:08 pm
I am 183 and ride 56cm C50 with 100mm stem, it's perfect fit. 58 frame and 110mm stem seem would definitely be too much for me, esven being 2cm taller than you. Start off with experimenting with shorter stems and maybe saddle position too (even few millimeters can be a massive difference in comfort) - naturally it's much easier & cheaper to start with replacing the frame, isn't it?
Parlee Z1 Super Record / ENVE / Campangolo Bora
PostPosted: Fri Jul 27, 2012 11:01 pm
Kgt and IIhh, what are your inseams? I think that is the one area that makes me unsure about sizing down any further than a 57. I have about an 89 inseam and ride a saddle height of 78. With my 57, I am pretty much maxed out on drop... That was my reason for going 58 with the CT2 when I bought it.
I thought a general Colnago sizing rule was to take the BB-saddle top measure minus about 20 cms?
PostPosted: Fri Jul 27, 2012 11:17 pm
1cm frame differences aren't as critical as Small / Medium / Large frame sizes etc.
Try the shorter stem. It sounds like you should be able to get a position very close to your Super.
BTW double check all your dimensions. Just in case :wink:
PostPosted: Sat Jul 28, 2012 11:33 am
Colonia wrote:
Kgt and IIhh, what are your inseams? I think that is the one area that makes me unsure about sizing down any further than a 57. I have about an 89 inseam and ride a saddle height of 78. With my 57, I am pretty much maxed out on drop... That was my reason for going 58 with the CT2 when I bought it. I thought a general Colnago sizing rule was to take the BB-saddle top measure minus about 20 cms?
Mine is 86cm. I would still consider the top tube length as the critical dimension. Saddle high is something you can adjust. Reach is much more important. Colnago suggests longer stems anyway.
PostPosted: Sat Jul 28, 2012 12:51 pm
I think I might have to experiment more with the 58.
There are no new unread posts for this topic. Colnago World Cup frame size [help]
biker11122
16
693
Sat Aug 05, 2017 7:17 pm
biker11122 View the latest post
There are no new unread posts for this topic. Colnago Master frame size question
stam1668
Sun Jan 29, 2017 12:29 pm
kgt View the latest post
There are no new unread posts for this topic. Frame size comparison Evo Vs Synapse
ukracer
Sat Oct 07, 2017 8:38 pm
ukracer View the latest post
There are no new unread posts for this topic. Which frame size and stem length?
TonyM
Tue Sep 12, 2017 5:22 pm
TonyM View the latest post
There are no new unread posts for this topic. Is disc rotor size frame-specific?
Miller
9
871
Wed May 24, 2017 8:35 am
lwk View the latest post
Users browsing this forum: dmcgoy, Geordiepaul, PetSounds and 30 guests
