It is currently Wed Jan 17, 2018 6:22 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sat Jul 21, 2012 11:52 pm
Does anyone here use a Campy Record front derailleur for their mtb drivetrain? Any performance issues? I have Sram XO triggers...
Ridley Excalibur
Scott Spark LTD 8.15kg (retired)
Giant NRS (Retired)
http://weightweenies.starbike.com/forum/viewtopic.php?f=1&t=104531
PostPosted: Sun Jul 22, 2012 12:51 am
I have 3 or 4 seasons on a Record triple front derailleur with no issues.
PostPosted: Sun Jul 22, 2012 5:11 am
it depends on how hard you are on your stuff, and what the consequences are for you if something fails.
i ran a record (double) front derailleur a few bikes ago on a 42/29 double ring setup. it worked very well, but then the carbon outer cage plate came unglued from the plastic part at the bottom end. the rivet under the linkage loosened and the carbon part was able to pivot independent of the rest of the derailleur. this is an occasional, documented occurrence with record front derailleurs. it's not catastrophic if this happens, but if you go on 5+hour backcountry rides, i wouldnt do it.
PostPosted: Sun Jul 22, 2012 9:55 am
i us B-T-P Tune Campagnolo Record 10s 61gr for long time ( 3 years ) and it works super with X.o gripshifters and XX triggers
cannondale Rush carbon SL team 8.75kg/19.29 1x10
viewtopic.php?f=10&t=101405
old WW bikes
Epic carbon 2006 9.3kg
Spark 10 2008 8.2Kg
Anthem Adv 9kg ( solt after 3 weeks not done )
scalpel 2009 7.97kg
PostPosted: Sun Jul 22, 2012 10:35 pm
I used a Campy Record compact for about four years on my 2007 Epic S-works. Updated to a 2011 frame, so I had to abandon it. Never had any issues, it worked great. With X0 gripshifters. I also dremelled quite a lot stuff off of it.
-px | pxx.fi | Spec Epic S-Works 8934g
There are no new unread posts for this topic. Campagnolo Front Derailleur Question
matty
16
1419
Sun Mar 19, 2017 11:10 am
matty View the latest post
There are no new unread posts for this topic. SRAM Red Front Derailleur Tuning (YAW)
prendrefeu
Wed Jan 10, 2018 12:45 pm
Jenmoss View the latest post
There are no new unread posts for this topic. Campagnolo EPS Super Record rear derailleur
rosuch
Mon Oct 30, 2017 10:21 pm
avispa View the latest post
There are no new unread posts for this topic. SRAM eTap Front Derailleur Adjustment
goldmine848
Wed Sep 06, 2017 12:54 am
commendatore View the latest post
There are no new unread posts for this topic. Compatibility between etap front derailleur and the 53-39 Q-ring
Eclat
Wed Mar 08, 2017 6:11 pm
1415chris View the latest post
Users browsing this forum: ja11 and 6 guests
cron
