It is currently Thu Dec 14, 2017 8:32 pm
Post new topic  Reply to topic  [ 89 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Mon Sep 24, 2012 6:35 pm
CarbonSportsGmbH wrote:
Before we can give approval for usage of Black Prince pads in combination with Lightweight wheels, we have to do our own tests - both on road and in laboratory.
This will take some weeks. Until that only the Lightweight by Swissstop pads are allowed for Lightweights wheels to avoid a loss of warranty.
Has CarbonSports done any testing of the Black Prince pads yet?
PostPosted: Mon Sep 24, 2012 7:52 pm
They may not have, but the new set of Zipp 202 clinchers here came with dark grey pads marked Swisstop :wink:
charles@pezcyclingnews.com
PostPosted: Mon Sep 24, 2012 7:58 pm
Charles, are you implying that those dark grey pads are Lightweight pads (the pads which Lightweight provides with their wheels and which are the special version for Lightweight of the Swiss Stop yellows)? And if so, are you implying that those pads are being cleared out?
Where is "here" with respect to where the Zipp 202 clinchers came, and where did they come from?
PostPosted: Mon Sep 24, 2012 8:02 pm
nope...
These are Zipp badged swisstop pads and are a new pad. They came directly from Zipp along with the to-be-released Firecrest 202 clinchers.
They're not the same pads as the last gen lightweight labeled swisstops.
PostPosted: Mon Sep 24, 2012 8:22 pm
Other than the color, are they the same as the Swiss Stop Black Prince?
PostPosted: Mon Sep 24, 2012 8:24 pm
aren't the zipp tangente platinum pro made by swissstop? i'd guess that's what comes with the 202's
swissstop said the black prince pads would be available after interbike, but I haven't seen them yet.
PostPosted: Mon Sep 24, 2012 8:50 pm
Not intending to hi-jack this thread... but what about the specific Enve pads? Any experience with those?
I have just bought a set of them... swapping from yellow SS. Haven't tried them yet, but according to the guy who imports Enve rims, they are the best choice.
2012 Canyon Aeroad CF 8.0 Di2
2014 Canyon Ultimate CF SLX Di2
PostPosted: Tue Sep 25, 2012 4:21 am
Just bought a lightly used set of 2010 Reynolds carbon MV32 tubular set of wheels. Installed Swiss Yellow Stop brake pads which I've used in the past with other carbon wheels and has been the gold standard for carbon rims. Went for my first ride and now remember why I enjoy a 1050 gram carbon wheel set so much: Incredible and almost effortless acceleration, climbing and cornering. Had a PR for the year on a 8 mile 7-8% grade climb with some sections in the 10+% range. On descent, stopped several times to check on rim temperature; too hot to touch briefly on a couple of occasions but no evidence of glue softening or tire movement. Braking was good in slowing down from fast; 20-30 down to low teens. Braking hard to less than 10 mph in sharp switch backs was less confidence inspiring with minor squeal and bike traveling a fair distance (maybe 20- 30 feet) before coming to a complete stop. Sounds like the Reynolds blue pads may be a better choice for my wheel set from what others are saying. Or would you wait and get the new Swiss Stop Black pads that seem to be the newest kid on the block?
PostPosted: Tue Sep 25, 2012 5:20 am
charles' new zipp pad is most likely the new platinum evo pad. thinner for better wide rim clearance, but wider (taller, technically. the top is higher and the bottom is lower). i dont remember the details of any improvements. needless to say, it's slight, or they wouldve given it a new name/new color/charged more.
PostPosted: Tue Sep 25, 2012 8:20 am
We're still testing them.
Andreas Schiwy, CarbonSports GmbH
http://www.lightweight.info
support[at]lightweight.info
PostPosted: Tue Sep 25, 2012 9:59 am
I have been riding with the Zipp Tangente Platinum pads for a couple of months now. The performance is good but they leave grey streaks on both my carbon tubular wheelsets. It's damn tough to get then off too. The only way I can is hard wiping with alcohol such as nail varnish remover.
I'm hoping the new Black Prince pads will be better in this respect.
Any recommendations on high quality pads that don't leave streaks?
PostPosted: Thu Sep 27, 2012 6:38 pm
i'd go over the surface again with straight alcohol or at least water if youre using nailpolish remover. it may leave a residue that may soften the pad, causing more streaking.
PostPosted: Sat Dec 08, 2012 5:51 pm
These came with a pair of the new SRAM 2012 RED AeroLink Brakes, are are they for aluminium or carbon?
PostPosted: Sat Dec 08, 2012 6:52 pm
gray=carbon. SRAM pads for alum are black.
after 2 drinks I'm a loser, after 3 a star
PostPosted: Sat Dec 08, 2012 7:31 pm
Green are for aluminum also.
There are no new unread posts for this topic. Zipp 303/404, anyone using koolstop pads?
TurboTommy
26
2156
Wed Jul 12, 2017 2:21 pm
dorin View the latest post
There are no new unread posts for this topic. Campagnolo blue/red pads
Willier
Sat Aug 05, 2017 2:42 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Brake pads for Lightweight Meilenstein
mike001100
21
1164
Fri Nov 10, 2017 12:01 am
glepore View the latest post
There are no new unread posts for this topic. Disc brakes : new pads = brake rub??
Delorre
9
1011
Mon Oct 23, 2017 11:36 am
CBJ View the latest post
There are no new unread posts for this topic. Cycling short pads - your thoughts?
milesthedog
16
1720
Thu Apr 20, 2017 1:26 pm
milesthedog View the latest post
Users browsing this forum: antonioiglesius, Bing [Bot], darnellrm, topflightpro and 42 guests
