Scott Addict RC (5490 gr)
jvanv8
by jvanv8
Here's my new Scott Addict RC with most of the parts swapped over from my old Addict SL.
The frame is 100+ grams heavier than the SL although both have identical specifications.
The fork originally weighed 390 grams but was so overbuilt that even the headset bearing couldn't fit over it. The replacement was standard Addict weight ~320 grams - and more importantly, it works.
Saddle was moved back slightly and leveled up after these initial photos and a few rides.
Fybre-Lite with Far and Near chain catcher and black KMC DLC Chain
slightly modified Red
With a little filing work, I was able to fit the Jagwire carbon adjusters into the guides
Before filing:
Half-way there:
iLink install always takes me forever
PowerCordz + iLinks for brakes & front derailleur
Continental Sprinter (rear), Zipp Tangente (front)
Initial fork (uncut)
Replacement fork (uncut)
350mm seatpost
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
Strava: Wayward Cyclist
prendrefeu
by prendrefeu
The pair look good together. Happy riding with your sweetie.
jmilliron
by jmilliron
Sharp!
Tinea Pedis
by Tinea Pedis
Fantastic!
Worth a sticky I feel.
jvanv8
by jvanv8
Yes, the MCFK saddle is working well and I like it a lot. What you see in the photos is the "everyday" setup. I had to use an SLR saddle while the Addict was getting prodded and probed at the bike shop during the warranty process and was glad to have it back (and the VumaQuad's low Q-factor).
Side note, my New Ultimate seatpost was broken when it returned from the shop. I had that New Ultimate since 2009 and I think it had enough hours on it to circle the globe. I'm guessing someone >90kg really wanted to try a carbon saddle. I guess I should have anticipated this. Glad I hadn't installed the MCFK post yet! Thankfully the saddle stood up to the "test", whoever he (or she) was.
The Fibre-Lyte rings have lived well past their expected life. I was told to expect 1000-1500 miles, but these must have 4000+ on them. Still work great.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
jvanv8
by jvanv8
Here's what New Ultimate looked like after I picked it up from the shop.
It was slated to go on the white Addict.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
fadr
by fadr
beautiful machine, carbon where you look, nice bike :P
jvanv8
by jvanv8
Dik, fadr.
The white bike has a little more Czech flavor to it ;)
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
denzity
by denzity
Great bike :thumbup:
Is there any reason you went for SRAM cassette instead of recon?
worstshotever
by worstshotever
I like. Not bad looking when assembled with the right parts.
jvanv8
by jvanv8
I did use a Recon cassette in the past but I was tired with the subpar shifting and the short lifespan.
After a month or 2 it would skip gears when you push hard... or in the middle of a busy intersection...
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
ArferBar
by ArferBar
wow! your RC frameset weighs SO much less then mine, my fork weighs what your first fork did. so your bearing race didnt fit (mine does)so they sent you another fork that was way lighter!! what size is your frame?
my cut fork-380g
my push fit 54 RC frame-920g
Mattias Hellöre
by Mattias Hellöre
Take the post back to shop and tell them what they did??
I would not accept someone break my stuff and not tell me that.
Experimental Prototype
jvanv8
by jvanv8
They had no idea what happened but they took my word for it and gave me store credit for the replacement cost.
AX Vial Evo: 4970g
Addict SL : 5235g
My Cycling Blog
