It is currently Fri Nov 24, 2017 10:50 pm
Post new topic  Reply to topic  [ 42 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Jul 11, 2012 3:17 am
First time poster.
I have had this sweet machine for two months and the ride is perfect. Was trying to pick between this and the Colnago C59, but after I had a test ride on the Parlee, the decision was "no contest" for me. Details follow:
Size M/L with Tall HT option.
Frame weight out of the box was 830 grams, uncut fork was 310 grams.
Full Dura-Ace Di2 with all stock DA 7900 bits...brakes, crank, chain, wires.
DA WH-7900-24-TL wheels with Maxxis Padrone tires (plus sealant)
Speedplay Zero Stainless pedals
Arundel Mandible bottle cages
Zipp SL Speed carbon post and stem (110 mm)
Zipp Zipp Contour SL handlebars (46 cm)
Far and Near Road Skewers
Fizik Antares 00 saddle
Garmin Edge 800 standard mount and speed/cadence sensor
Thanks to Matt at All-American Bikes in Damascus MD & Eric at Bicycle Pro Shop in Alexandria, VA for taking my money and making this dream come true.
...still a ways to go for WW purposes (maybe new wheels in a few months), so it's...
...15.03 lbs as you see it (sorry for the amateur pics)
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
Last edited by carlislegeorge on Sun Dec 15, 2013 7:43 pm, edited 5 times in total.
PostPosted: Wed Jul 11, 2012 10:22 pm
Stunning. I have the SL, and I love it, incredible bike - even if a tiny bit of me is regretting not getting the SLi.
Enjoy
PostPosted: Wed Jul 11, 2012 11:47 pm
A beauty!!! Should have gotten a Parlee instead of my SWorks SL4. Nonetheless a Parlee will be next!
PostPosted: Thu Jul 12, 2012 12:00 am
I traded up from a 2011 Tarmac Pro SL3 in Project Black. The Parlee is way sweeter, even though the Spesh is a fine ride. Luckily there is a nice resale market for the project black!
PostPosted: Thu Mar 14, 2013 8:53 pm
As it sits now...down to 6.52 kg (or 14.35 lbs)
Dura-Ace Di2 with stock DA 7970 bits, except...Praxis 52/36 rings
Farsports 38mm carbon clinchers w/Novatec SL hubs, Sapim Cx-Ray, Veloflex Corsa 23 tires
Generic bottle cages (38 grams/pair)
Ritchey Superlogic seatpost and 3T Team Arx stem
Thomson Road Carbon handlebar (size 44)
One23 skewers
Racewaredirect mount for Garmin 800
Cane Creek blue headset pieces
PostPosted: Thu Mar 14, 2013 10:19 pm
What's your opinion on the handlebars?
Between these and the ritchey superlogic evo curve I chose latter because I did not like the graphics on the KFC cross bars, which are more similar in shape to the superlogics. If the Thomson bars are as good as the rest of their line they are a steal though.
  • 2011 Cannondale Flash F1
  • 2010 Cannondale Caad9
  • 2000 Caad 4 aero
PostPosted: Thu Mar 14, 2013 11:27 pm
I really like the handlebars, best ones I've had yet. They are comfortable on the road and fit my hands much better than the Zipp carbon bars I just took off. They came in a few grams under advertised weight. Graphics on these are pretty minimal.
PostPosted: Fri Mar 15, 2013 12:24 am
Looks great now! I like the little bit of colour. I'm so excited to pick up my Thomson bars... every time I hear someone say they like their's I get giddy!
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Fri Mar 15, 2013 11:09 am
Nice bike!
Could you tell me the difference with the SL3?
I hesitate with a Cervelo R5 for the stifsness...Is the Parlee not so stiff and nervous that 'pro' frame?
Thank You for your review.
PostPosted: Fri Mar 15, 2013 2:27 pm
Purely subjective, the Parlee Z5 SLi feels noticeably better than the Tarmac...but this is incremental rather than leaps and bounds. The Parlee is just as quick and responsive and stiff, if not more so, and it does it at a higher comfort level. When I jump on it, it takes off just as quickly or even quicker as the Tarmac Pro SL3 I had previously. I haven't flexed anything BB-wise, ever, as far as I can tell. It handles very precisely and surefootedly, but the Tarmac never gave me a problem either, it felt stiff but not particularly "nervous" as far as I could tell. Climbing? The Parlee seems to leap up the hills when I have the legs to push it.
Bottom line the Tarmac SL3 was a very fine ride, but I was in the market for something different. This Z5 SLi just kind of disappeared underneath me on a long test ride, and my mind was made up. It does everything very very well, exceeds my meager abilities and engine.
PostPosted: Sat Mar 16, 2013 9:18 am
Not keen on the blue personally, but otherwise nice build!
Scott CR1SL 6.25Kg | CAAD10 6.56Kg
PostPosted: Mon Mar 18, 2013 6:52 pm
Awesome build. I would change the blue parts and maybe the cable housings and also the cranks if the frame has bb30. but these cranks are the best anyways. geometry seems really good, i love the tall head tube.
Happy Trails !!!
PostPosted: Mon Mar 18, 2013 10:28 pm
Cable housings? Not sure about that one. I am going to put on some Hollowgram SL cranks to see how they look with the Praxis rings. And those cheapo bottle cages may have saved 17 grams but seem way too loose while riding. The Arundel Mandible cages are going back on.
PostPosted: Tue Mar 19, 2013 2:24 am
Gorgeous! I like the blue, but I think the amount on the HS doesn't balance well with the rest of the bike. Maybe swap in some black spacers are use a blue seatpost clamp to even things out?
My Thompson bars should arrive Wednesday. I went with the cross model (tape will cover the graphics) because of the shorter drop. Glad to hear you like yours!
__________
Seven 622 SLX
Colnago C50 Extreme Power
Zanconato CX
PostPosted: Mon Apr 08, 2013 5:05 pm
A couple small updates to Parlee Z5 SLi....brakes (black TRP R979 EQ), KMC X10SL DLC black chain, and used Hollowgram SL crank arms...weight as shown is down to 6.41 kg / 14.13 lb...
There are no new unread posts for this topic. Parlee Z3 - Rebuild... Full build pics at bottom of page 1.
Lig
18
2789
Wed Jan 18, 2017 6:34 pm
Lig View the latest post
There are no new unread posts for this topic. FM-008 size 58, BC Flechtwerk - finished, pics page 2
kidrob
33
7946
Tue Nov 21, 2017 9:36 am
RazorL View the latest post
There are no new unread posts for this topic. 2012 Cervelo R5 VWD 6.718kg. Oldie but Goodie. Updated PICS/Build. Pg 2!
MomentumR5
28
3143
Thu Oct 12, 2017 5:43 am
MomentumR5 View the latest post
There are no new unread posts for this topic. 2016 Storck Aernario 59cm limited ed. #59/200 frameset - freshly repainted/restored
byron505
Tue Aug 29, 2017 11:55 pm
byron505 View the latest post
There are no new unread posts for this topic. Ax Lightness - no more! -Not so much, read page 2 respond by Nils
[ Go to page: 1 2 3 4 ]
wheelsONfire
50
7943
Mon Jul 10, 2017 3:17 pm
tharmor View the latest post
Users browsing this forum: 4ibanez, garjo and 10 guests
