It is currently Tue Jan 23, 2018 11:13 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Mon Jun 25, 2012 9:00 am
Looking at the Lynskey R230 and R330 frames - found weights for the R230 but not for R330.
R330 ML Weight?
R330 L Weight?
See on here NSPACES M weigh in at 1487g
Like the idea of the R330's stiffness but the R230 seems like it may come in lighter.
PostPosted: Mon Jun 25, 2012 9:16 am
Administrator
My 2008 R320 M/L came in at 1244 grams.
RESIDENT GRUMPY OLD MAN.
PostPosted: Mon Jun 25, 2012 9:26 am
Thanks Juanmoretime - 1250g is my target weight for my next frame.
Interesting difference in weight between yours and NSPACE - Did yours have the press-fit Alu insert in the seat tube?
I wonder if the amount of butting a tubeset gets varies much depending on which person at Lynskey is working in your frame.
PostPosted: Mon Jun 25, 2012 11:21 am
My R320 M is 1250g, but R330/340 are heavier , for at least 100 g
I have a short insert in the seat post to make the 31,6 mm diameter
PostPosted: Mon Jun 25, 2012 3:37 pm
Btw, any idea what the Helix OS frame weighs?
Mine is a size S but was delivered with the Cannondale Hollowgram SISL compact cranks so I did not bother weighing it.
My complete built-up bike came in at 7.2 kg or 15.6 lbs, with pedals, bottle cages, computer, and 28/32 clincher training wheels.
Mark
2012 Lynskey R330 with SRAM Red Quarq
2013 Parlee Z1 with DA 9070
2013 Lynskey Helix OS II with SRAM Red
PostPosted: Mon Jun 25, 2012 5:13 pm
Administrator
Yes my R320 does have a small, about 70mm long narrowing it down to 31.6mm. The diiference between the R320 has the Helix stays and the hooded dropouts. I'm really not sure about the other tubesets but I think the R330 has a much thicker insert taking it down to 27.2mm. The R320 has some pretty minimalist dropouts and its one of the things I love about the frame. I've never been a big fan of hodded dropouts.
If I remember correctly my M/L Helix OS frame was 1500 grams but the headset was already pressed in.
PostPosted: Mon Jun 25, 2012 8:23 pm
I have a 340 M/L. with a Cane Creek 110 headset installed, I think the frame was 1247g. Don't have the photo on my phone anymore, though. That includes the cable guide.
PostPosted: Mon Jun 25, 2012 8:32 pm
Antoine/ Juanmoretime, thanks again for the info. The R320 certainly looks like a great frame and would be on the list however I am specifically after the hooded dropouts. While not as ornate I can get a pair of subtle eyelets welded onto them - I can then run a three point pannier for the odd adventure with friends.
Tug Boat - Thanks for the figures.
Had a chat with Lynskey later today and it seems that the stiffness and weight of the R330 vs R230 are comparable. The R230 is more readily available in the UK so may head that way in the end. Keeping my eyes peeled for an R330 though.
PostPosted: Tue Jun 26, 2012 1:03 am
Correct, my Medium weighed in at 1487 including the steel cage bolts, a few grams less without them.
What I did discover in my thread was that previous generations were lighter. Someone mentioned theirs broke at the chainstays and they got another which was 30-40g heavier if I recall correctly. Presumably, they added more material.
Did you ask them about weights when you talked? Lynskey, as much as I like them, they always seem kind of sketchy about weights or even giving you a ball park. They don't publish anything it seems. They announced the R210 UL shortly after I bought my R330. UL was supposed to stand for Ultra Light, but to date, they haven't posted any weights. In my books, if you are going to call something UL you should be prepared to give a few more details than that.
I wouldn't be surprised anyways if they are building frames a tad beefier now, based on various readings. That said, I love my R330. Not a fan of helix tubes on their Helix frames, but this is the only frame they make where I don't mind them, they are very subtle and only on the seat stays. I wasn't a big fan of the aesthetics (given the choice of the 2) of the curved stays so I went for the R330. Originally I actually had the R230 on order, and it wasn't due until mid June, so I changed my order to the R330 when a window opened up. I suspect they build this bikes in waves to and re-tool for certain models all at once based on demand/production schedules.
R230 is definitely more readily available. Its interesting to note that ordering direct through Lynskey they quoted me mid June as I mentioned, for the R230. Maybe 2 months into the weight, with another 2 months to go, I noticed Chain Reaction had a full stocking of R230 sizes. Their dealers are also in their build queue, which was something I didn't consider. Had I continued the path of buying the R230, I would have been a tad frustrated to know that I could get the frame in a matter of days while they had my non-refundable deposit for the next 2 months. Anyways, not knocking them for it, but I assumed direct would be quicker, which is not always the caseā€”but it sounds like you already figured that out.
Whichever way you go, I am sure you will love the bike!
I definitely like the hooded dropouts. The plate drop outs would be lighter, but IMO the cloverleaf thing they do is a bit tacky and unslightly. Some standard looking windows would look a hell of a lot better. I have been tempted on my hooded drop outs to file out a little part for my skewer to fit in to (in the mid point between the chain and seatstays), but I am not brave enough :)
PostPosted: Tue Jun 26, 2012 4:37 am
I believe that "hooded" dropouts are properly known as "Breezer" dropouts.
PostPosted: Tue Jun 26, 2012 1:41 pm
Just a few more refernce points, My Level 3 Lynskey was right at 1170 ish in a size medium. My current Helix was 1250 in the same size.
PostPosted: Tue Jun 26, 2012 4:49 pm
Same difference, lots of different names. Wright style drop outs are also synonymous.
PostPosted: Tue Jun 26, 2012 9:20 pm
the downside of those drop outs are they dont fit in some trainers
PostPosted: Tue Jun 26, 2012 9:36 pm
One more reason to man up and ride outside :)
There are no new unread posts for this topic. Lynskey charges $195 to prep the frame for SRAM eTap
WonderSausage
Sun Feb 05, 2017 8:10 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Frame weights
BDP
Tue Oct 03, 2017 3:22 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Cannondale Supersix evo - frame weights
Beancouter
9
2998
Mon May 29, 2017 6:18 am
mcgheew View the latest post
There are no new unread posts for this topic. Between frame sizes - : Going larger frame vs going smaller frame
jeffy
16
1805
Sun Jul 09, 2017 11:03 pm
sooni View the latest post
There are no new unread posts for this topic. Schwalbe One tire weights?
2lo8
Sun Jun 25, 2017 12:28 am
gewichtweenie View the latest post
Users browsing this forum: AJS914, bfno, Bing [Bot], jimtbaker, themidge, wedgie, Wookski, wrenegade, Yahoo [Bot] and 30 guests
