It is currently Fri Nov 24, 2017 11:40 pm
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Tue Jun 19, 2012 11:57 am
I recently bought a new LOOK 695 SR. The bike has been incredible so far but i have just one gripe with it. The chain ring bolts are creaking even after freshly greasing and the chain ring bolts set to recommended torque settings. I did manage to shear off one bolt, i just think i need a stronger bolt set in there as i'm 89kgs and put a fair bit of torque through the cranks when climbing. The creaking is only noticeable when rocking left to right and out of the saddle. I have never had any issues with DA or SRAM cranks/chain rings doing this so i'm convinced its the bolts on the Zed 2 cranks. I can hear it come from that area and it's not the BB. The bolts are stupidly lightweight alloy, i'm sure a heavier gauge bolt would fix the problem.
If anyone could shed some light on a more durable stronger bolt option it would be most appreciated.
Thanks in advance.
PostPosted: Tue Jun 19, 2012 12:13 pm
Not sure if there is one as the bolts on the 695 are longer than standard chainring bolts. The torquing specs on these bolts are really specific. Do you think the creaking is coming from the threads or because the bolts are rubbing against the chainrings themselves?
PostPosted: Tue Jun 19, 2012 12:25 pm
I don't think it's the threads as they are freshly greased. I think it's the bolts physically creaking from the lateral force of the torque on the chain rings. It's as if the chain rings are flexing. If i sit down and ride hard without rocking the bike side to side (as in climbing mode) it doesn't do it. I am using SRAM Red chain rings on the cranks so might try switching them over to the LOOK specific ones or a SRAM TT disc type ring which i also have on another bike.
I know FSA have a huge range of chain ring bolts and it might be worth trying to find out what size the LOOK bolts are and whether any of their range would work.
PostPosted: Tue Jun 19, 2012 2:50 pm
Creaks almost always sound like they're coming from the cranks but hardly ever do. If it only makes the sound when you're standing up, I'd check the headset/stem/shift levers. The quick releases are also a pretty common noise maker.
PostPosted: Tue Jun 19, 2012 7:10 pm
Had the exact same issue, changed the bolts to kcnc same lenth as the looks.
Wrapped them in ptfe plumbers tape, stopped them creaking and working loose on this sr frameset.
Steve
PostPosted: Tue Jun 19, 2012 10:10 pm
Steve
Cool, thanks for the info. Can you remember which model the KCNC bolts are, there is a decent range here http://www.torontocycles.com/Selling/Ch ... ranks.html
Did you you continue to use the female part of the Look bolt or did you swap out the whole male and female parts?
Thanks again.
PostPosted: Tue Jun 19, 2012 10:36 pm
I think the kcnc come as standard.... You do need to use the zed crank female bolts, these are required to work with the crankset.
steve
Ps.....I've just checked your link, it's not the campy ones you need.
PostPosted: Mon Jul 30, 2012 11:04 am
Hi guys... I have had a 695 for 18months now. Great bike but a few creaks as well. The bearings have been repacked and the local disties are going to replace them. I don't ride that often. The bike has only done 3500km total in that time. After around 7 months I was climbing a steep incline and all of the chain ring bolts sheared. The bolts were replaced with steel male bolts (original LOOK were alloy) and lock-tited. Bike started creaking again and we noticed that 3 bolts were loose and one had fallen out.
How many KMs have you ridden on the replacement bolts? any other problems showing up?
Cheers
KJB
PostPosted: Mon Jul 30, 2012 3:34 pm
Has anyone provided feedback to Look? Not sure how common this problem is, but perhaps some design tweaking is in order, or has Look perhaps already done this and new units are better?
PostPosted: Mon Sep 03, 2012 3:32 am
creaking noise from BB area when climbing 8%+ slopes with small ring - no noise when hard pedaling with big ring
anyone else having the same issue?
btw, riding rotor 50-34 q-rings
Ride safe!
Eduardo
2011 Look 695 SR
PostPosted: Mon Sep 03, 2012 9:24 pm
Hi,
I'd bet it's your rear quick release, climbing put 2-3x more torque on the rear wheel than flat riding (for any given torque at the crank)... Had this problem this year after switching to KCNC QRs, these creaks always sound like it's coming from the crank/BB :)
Jeremy
PostPosted: Tue Sep 04, 2012 3:09 am
So Iget this right, no one has had an issue on the original LOOK/TA specialties rings? Just other brands
PostPosted: Tue Sep 04, 2012 11:51 am
I would also check the freehub and cassette as they do make noise under load if there are issues
Sent from my HTC One XL using Tapatalk 2
N+1 It Never Stops
There are no new unread posts for this topic. lightest PM + crank option?
addictR1
11
628
Wed Nov 15, 2017 7:18 am
uraqt View the latest post
There are no new unread posts for this topic. Rotor chainring bolt/nuts to long for my Red 22 chainrings?
ill principe
Mon Mar 13, 2017 7:26 pm
ill principe View the latest post
There are no new unread posts for this topic. Praxis Works chainring bolt torque spec
SpecializedColnago
Sat Feb 18, 2017 6:13 am
sp3000 View the latest post
There are no new unread posts for this topic. Giro Republic : Using 2-Bolt Cleat Mount with 3-Bolt cleats
gerryc89
Fri Jul 28, 2017 3:24 pm
TheKaiser View the latest post
There are no new unread posts for this topic. From Evo 386 BB to other BB option weight penalty?
stockae92
11
778
Wed Dec 14, 2016 8:05 pm
wingguy View the latest post
Users browsing this forum: Baidu [Spider], DDX, lockxchg, Robius and 39 guests
