It is currently Mon Jan 22, 2018 5:40 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page 1 2 Next
 Post subject: New Scale project
PostPosted: Fri Jun 15, 2012 1:06 pm
Not sure whether this is of any interest to anyone however I've started building a project of my own based on an Scott Scale 30 from 2008.
This isnt a quick project (ive been collecting bits for the past 2/3 months) mainly due to money constraints however I would appreciate any input.
The breif was to create a XC / Enduro bike which will be used for racing so must be reliable and durable.
Spreadsheet Colour coding:
>Green means owned or accurate
>White is published weights
>Yellow is not yet bought and would appreciate advice.
On this assumption the bike should come out around the 9kg mark.
Cheers
Dan
 Post subject: Re: New Scale project
PostPosted: Fri Jun 15, 2012 4:05 pm
Pretty sweet build really. The KCNC post is about 153g for a 27.2x400 but don't know what size you are looking at. Keep in mind that if you run the Magura brakes, they use a thicker rotor. Not that the storm rotors are bad mind you but you could end up limited to what replacement rotors you can get down the road. Honestly, I couldn't be happier with my M985 brakes and Ashima rotors.
My Ritchey WSC stem w/ ti bolts is right around 130g and may very well cost less than the Easton. My Super logic bars weigh in at about 130 and have a 1/4" rise to them.
You might also shed a little weight by running the KMC X10sl chain over the Shimano.
Not sure if this bike is a 26 or 29er but for tires I say go with either the Racing Ralphs, Maxxis Ikons, or if on a 26" then Conti Race King Super Sonics (I had problems trying to get mine to go tubeless though but work great with tubes due to the larger volume for a 2.2 size). Another tire worth considering that is pretty light is the Specialized Rampage tire. All are pretty light and have a low tread pattern for fast rolling but don't do too well in the wet/mud.
Cannondale Synapse (alu)...it works
PostPosted: Fri Jun 15, 2012 4:06 pm
Cable outers, maybe look at iLinks
PostPosted: Sat Jun 16, 2012 12:02 am
Agree it is a good build. :thumbup:
The only obvious savings are going KNC or Ritchey foams grips that are about 18g. People here will always suggest going for a lighter saddle, but if it works for your butt - leave it. See you have't decided on pedals - consider eggbeaters, with aftermarket Ti spindles they easily get to around 180g.
Post some pics as well please. 8)
Norwood & Adelaide Uni CC
PostPosted: Sat Jun 16, 2012 2:00 am
Pics or its all LIES :twisted:
PostPosted: Sat Jun 16, 2012 8:17 am
To quash the shouts of lies :D (and now because I have sorted out my camera) please find the piccies attached below.
Frame
Seatpost and Clamp
Stem (not sure where my pic of Handlebars went
Groupset
Had to buy a new mech as this one didnt come with the BB plate So this is actually a 3x10 mech plate bolted on to a 2x10 w/o BB plate mech
Build progress to date (sorry about phone piccy)
PostPosted: Sat Jun 16, 2012 8:19 am
Grips as-well
Expecting brakeset delivery today
PostPosted: Mon Jun 18, 2012 2:29 pm
Egg beater pedals have been ordered, is this the best place to order aftermarket spindles
http://shop.titaniumspindles.com/Fits-2 ... cstrfrnt05
PostPosted: Mon Jun 18, 2012 9:43 pm
All cabled up, just wheels and pedals left :D
Egg beaters on order as I said above
PostPosted: Tue Jun 19, 2012 8:12 am
Looks promising, keep the thread going!
I'll be adding your data to my 'circa 9Kg' spreadsheet for comparison!
To save weight on my daughters Scott (where the tube fell between 34.9 and 31.8 stnd sizes) we used a 34.9 banded front mech with plastic reducers to 31.8mm and then used a flap wheel to enlarge them to the right size for her frame, saved about 30g over the E-type mount (she was using XT with alloy mount similar to yours).
Skewers?
PostPosted: Tue Jun 19, 2012 3:55 pm
Thanks for the interest - I know I am not uber lightweight however I want to make it a good climber!
PostPosted: Sat Jul 07, 2012 9:07 pm
Try 1x10? I love it and run it on all my mtbs. I run 11-34R&32t F on my AM bike and 11-32R&34/36t F on my hardtail with no complaints at all. Never looked back.
Superstar xcr chain guide is 70g and £16 then loose the rings and one set of bolts, that'll save 50-100g, the front mech goes, the front cable and outer alone can be 100g+ front shifter etc, and also you take about 3-5 links from chain, which is about 20g
The best thing about giving this a try is you'll loose about -300g or more for a very small cost, so if you don't get on with it you can go back. You won't go back
PostPosted: Sat Jul 07, 2012 9:12 pm
That sounds interesting, what sized front ring do you use?
PostPosted: Sun Jul 08, 2012 8:58 am
As mentioned, 34t or 36t front on hardtail. If your running 10 speed you ll have a 11/36 rear cassette which means with a 36t front ring you'll have a 1:1 climbing ratio. I have this (32/32) on my 28lb AM full suss and have done 10hr/two day trail centre jollies with no complaints.
Then that ll give you a 11/36 top end, good for about 30mph+ with 100 cadance which you'll only do on road, down hill, if you wanna go faster on road, buy a road bike.....
PostPosted: Sun Jul 08, 2012 1:38 pm
+100%
Unless you are doing some massive Alpine climbs on a daily ride basis I don't see any need for more than a 1 X 10 set up. A 1 X 5 would be even better but I mainly ride SS.
Looks like a nice build :)
There are no new unread posts for this topic. Scott Scale Ltd
02GF74
Wed Nov 08, 2017 9:42 pm
02GF74 View the latest post
There are no new unread posts for this topic. Scott Scale SL vs Premium?
in MTB
sandico
Tue Apr 04, 2017 6:15 pm
sandico View the latest post
There are no new unread posts for this topic. FS: Scott Scale LTD frame, NEW
rainerhq
Fri Oct 27, 2017 11:27 am
rainerhq View the latest post
There are no new unread posts for this topic. Scott Scale 29er
PastaDiPipo
Fri Jun 09, 2017 1:14 pm
PastaDiPipo View the latest post
There are no new unread posts for this topic. Upgrade for a Scott Scale 920.
in MTB
batcave
Tue Jul 04, 2017 1:47 pm
TheRookie View the latest post
Users browsing this forum: No registered users and 9 guests
