It is currently Sat Jan 20, 2018 12:43 pm
Post new topic  Reply to topic  [ 283 posts ]  Go to page Previous 1 2 3 4 5 619 Next
PostPosted: Mon Jul 09, 2012 11:18 am
durkonion wrote:
Sorry, the laser etching should face the inside not the outside. Your inner ring is on backwards.
Just checked some other picks, damn your right! seems to be working OK, I may swap my Praxis 39 on there since it's 3 grams lighter.
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
PostPosted: Mon Jul 09, 2012 11:21 am
timzcat wrote:
CBRE,
How do you like the new front derailleur? I just ordered one to replace my force derailleur.
I am running the Praxis clover rings.
Did you change over to all new red?
Front derailleur is stellar, as are the shifters, crank and rear cog(I have the 11-26 on my DT's and a 11-28 on my Boyds 24's), the rear derailleur seem no better than the old which is not a bad thing:) I got everything but the brakes as they were to heavy.
Curt Brown
PostPosted: Mon Jul 09, 2012 12:08 pm
AptosBigRing wrote:
CBRE -
Can you give me a call tomorrow at our office?
I want to pick your brain on something...
Adam@Praxis
831-708-2161
Santa Cruz County
Manufacturer
Curious :hmm:
I'm also rather nosy..... 8)
PostPosted: Mon Jul 09, 2012 12:25 pm
Would like to ask Adam of praxis about the Praxis chainring not oriented properly with the crank arm, since the chain catch pin is not behind the arm, will this affect the timing of the shift?
thanks
Micropox
Praxis ring user on S-works cranks :)
PostPosted: Mon Jul 09, 2012 2:28 pm
Well he's using the SRAM inner ring with the Praxis outer ring, so timing would be off no matter what. If I were you, I'd rotate the outer ring so that the catch pin is 180 degrees from the crank arm and use the matching Praxis inner ring.
Sorry to pick on you, it's just that mixing rings is a pet peeve of mine.
PostPosted: Mon Jul 09, 2012 3:05 pm
Catch pin must be eliminated to use on this crank. Does save one gram:) Not needed with this new Sram stuff anyway from what I can see, shifts are stupid precise.
Curt Brown
PostPosted: Mon Jul 09, 2012 3:47 pm
OK last pic, just swapped the inner ring to the Praxis also, 31g vs 34g for the Sram ring, sorry for the dirty bike:(
Curt Brown
PostPosted: Mon Jul 09, 2012 7:21 pm
Can you confirm how the hidden bolt mount works please - is there a dedicated spacer that fits between the outer and inner rings or some such ?
Many thanks
Andy
PostPosted: Mon Jul 09, 2012 7:22 pm
Yep, there is a spacer that comes with the Red crankset. Everything should mount fine as long as the Praxis outer ring is the same thickness as the SRAM outer ring.
PostPosted: Mon Jul 09, 2012 7:56 pm
I would imagine the shifting is not 100% as good as it can be on the new Red crank with praxis rings. The shift in bolt location moves the pins away slightly from the power phase of the stroke. How is it shifting now? Have you used the rings on another crank before. Is it not noticeable?
PostPosted: Tue Jul 10, 2012 3:33 am
IMHO the combo of the 39/53 rings shift better and are more quiet than the SRAM, also better looking and much lighter, could not be happier.
Curt Brown
PostPosted: Thu Jul 12, 2012 8:16 pm
Curt, did you get to talk with Praxis guy, did he share any interesting info for the public?
PostPosted: Thu Jul 12, 2012 9:54 pm
Talked to Adam, it was happy to see I was using there rings with the new SRAM Red crank, he mentioned that each set has matched shift ramps and wanted to make sure my shifted smoothly since I had to rotate the rings with this crank, and they shift perfect.
Curt Brown
PostPosted: Fri Jul 13, 2012 3:35 am
Looks good and I look forward to more reviews of the crankset. Sounds like a valid option.
PostPosted: Tue Jul 17, 2012 5:09 am
What specifically needs to Be done to the praxis rings for this to work
There are no new unread posts for this topic. Ax Lightness - no more! -Not so much, read page 2 respond by Nils
[ Go to page: 1 2 3 4 ]
wheelsONfire
50
8767
Mon Jul 10, 2017 3:17 pm
tharmor View the latest post
There are no new unread posts for this topic. Wahoo KICKR trainer issues. Read if you use Campagnolo!!
dgasmd
20
1342
Sun Oct 29, 2017 3:08 pm
basurper View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1314
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Searching for Shimano shoe info: R300 to R321/RC7
naylor343
Sat Dec 30, 2017 3:58 pm
naylor343 View the latest post
There are no new unread posts for this topic. Crank arm size
WhyZ
Sat Feb 18, 2017 10:20 am
Kayrehn View the latest post
Users browsing this forum: Alex60, alorast, Google Adsense [Bot], killeen, rsantos450, rynogee and 41 guests
cron
