It is currently Mon Dec 18, 2017 10:19 am
Post new topic  Reply to topic  [ 283 posts ]  Go to page Previous 112 13 14 15 1619 Next
PostPosted: Wed Nov 28, 2012 9:06 am
Here are some pics comparing the spider connection points on both chainrings. In both pics, the SRAM 50T ring is on top.
First off, the connection to the crankarm (hidden one)
Now, all the other connection points on the SRAM one are different to the crankarm one, as seen here
Here is the profile of the cutout on the crankarm (BB30 compact). You can see why the cahinring has some different machining.
All makes sense now. For BB30 Compacts, the Praxis rings need to be filed slightly to match the profile as per the SRAM 50T chainring :smartass:
Problem solved. :thumbup:
PostPosted: Wed Nov 28, 2012 4:27 pm
thanks, that really helps, great pics.
PostPosted: Mon Dec 10, 2012 2:35 pm
I got my Exogram BB30 Compact 50-34, 172.5mm last week.
523g ... genuinely light even by WW crank standards.
...and less WW was the price ... $350 new from an ebay retailer
PostPosted: Tue Dec 11, 2012 10:12 pm
So - pre-stripping.
170mm 53/39 BB30 and 549g, with a decent chunk of grease that came on the spindle, doesn't include the pedal washers or PF30 fittings.
Plan is to strip it back to bare carbon, 303 it, add some Praxis Classic rings and then stick it on my Firefly. When I have I'll use a camera rather than an iphone for a photo!
Praxis classic - SRAM red
112g - 139g
32g - 33g
Saving 28g
So pre strip 519g (there was 2 grams of thick blue grease on the spindle as well!)
For comparison my da7900 170mm 50/34 was 653g and I will be dropping a pf30 adaptor from the mix as well.
____________________________________________________________________________
Firefly FF050
Scott Plasma 5 eTap
Trek Fuel EX9
Last edited by Stuartclark1977 on Tue Dec 18, 2012 11:40 pm, edited 1 time in total.
PostPosted: Tue Dec 18, 2012 9:01 pm
Has anyone tried to fit Red Black rings to the Exogram crankset? I don't like the new ring design. Does this fit and shift properly, also with older Red front derailleurs?
PostPosted: Tue Dec 18, 2012 9:21 pm
You'd be doing a MAJOR disservice by using red black rings... the best part of the new crankset is shift performance and these rings perform light years better than the old.
That said, I'm sure they'll fit. Knock yourself out.
Current:
T2
Retired:
PostPosted: Wed Dec 19, 2012 12:20 am
Stuartclark1977 wrote:
So - pre-stripping.
112g - 139g
32g - 33g
Saving 28g
I'm surprised by the weight difference on the Praxis rings. I'm also using the classics and mine were 98g and 31g respectively.
PostPosted: Thu Dec 20, 2012 7:06 am
Couldn't be more happy. Filing wasn't very hard nor do you have to file much at all.
2012 Izalco Pro 2.0*Re-Grouped*
PostPosted: Thu Dec 20, 2012 7:44 am
I presume yours was BB30 & compact ?
PostPosted: Thu Dec 20, 2012 10:10 am
Yes it is, BB30 172.5 with Praxis 52/36. I had the luxury to open couple of standard BB30 and GXP cranks with the corresponding BCD Praxis rings to confirm. Should've just read Page 8. :roll:
PostPosted: Thu Dec 27, 2012 7:07 pm
Did you tried them yet?
How is the shifting with these 52/36?
PostPosted: Thu Dec 27, 2012 11:10 pm
Great info here! Does anyone have a weight for a BB30 Quarq setup? Someone posted a gxp quarq combo which was heavy but I was wondering if the BB30 setup would be lighter.
PostPosted: Fri Dec 28, 2012 4:26 am
From reading this thread it appears that, including BB's, the 170mm BB30 compact I just ordered for my wife's bike will be within 1g of my old THM Clavicula BSA 175mm using the same rings. This is truly appalling. :shock: Maybe I miscalculated....
PostPosted: Sat Dec 29, 2012 5:44 pm
Could someone do me a favor and weigh just the left-side arm/spindle of a BB30 style crank? A scale picture would be best. I ask because I am running a Quarq on an BB30 S900 and I am wondering how much weight I could save by using a Red crank on the left side. Also, does anyone know if this combo would work? Would the left/right arms be 180 degrees?
PostPosted: Sat Dec 29, 2012 6:29 pm
Without lock-ring
With lock-ring
Spline pattern
This has lost the SRAM graphics but not been aggressively sanded.
I'm also not sure how the end shot of the spline weighs an extra 2 grams than the side on shot but should help you determine if the cranks would line up okay. (Maybe you should average them to a 179g without the lockring.)
They are 170mm 2012 SRAM Red BB30, hope that helps.
Firefly FF050
Scott Plasma 5 eTap
Trek Fuel EX9
There are no new unread posts for this topic. Ax Lightness - no more! -Not so much, read page 2 respond by Nils
[ Go to page: 1 2 3 4 ]
wheelsONfire
50
8362
Mon Jul 10, 2017 3:17 pm
tharmor View the latest post
There are no new unread posts for this topic. Wahoo KICKR trainer issues. Read if you use Campagnolo!!
dgasmd
20
1081
Sun Oct 29, 2017 3:08 pm
basurper View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1153
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. srm crank length
simoncx
7
438
Tue Oct 10, 2017 4:23 pm
simoncx View the latest post
There are no new unread posts for this topic. 130 BCD crank w/ 52/36 chainrings?
jbaillie
9
1539
Sat Jan 28, 2017 3:35 pm
mythical View the latest post
Users browsing this forum: Google [Bot], JScycle, Marin, parker0320 and 38 guests
