It is currently Thu Sep 21, 2017 10:00 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Fri Jun 01, 2012 2:52 am
To anyone who did an internal di2 battery, what connector are you using?
I have a tenergy airsoft battery I am going to use with my build, but am a bit unsure whether I should stick with the mini tamiya connector or not. Is there a lot of concern with water entering the plug? I figure I can dab some silicone in the exposed areas and heatshrink the entire assembly after connected.
PostPosted: Fri Jun 01, 2012 8:06 am
just cut the shimano connector off the battery mount and splice this onto the LiPo battery.... red to red... black to black... then connect as usual.... then u dont have to worry bout compatibility issues, or waterproofness....
PostPosted: Fri Jun 01, 2012 6:24 pm
How do I charge the battery without cutting and soldering every time then? :shock:
PostPosted: Sat Jun 02, 2012 12:43 am
On the tenergy I used, there were 2 connectors, one generic, and one for charging...
Cut the generic off and solder/heat shrink the shimano connector on... The charging connector remains to allow easy charging....
PostPosted: Sat Jun 02, 2012 1:41 am
Internal routing on a P3C using JST connectors on the power leads for me.
PostPosted: Sat Jun 02, 2012 4:30 am
I don't have the original di2 battery, that's probably why I was confused :D
Looks like I'll just stick with the mini tamiya connector and shrink wrap the connection
PostPosted: Sun Jun 03, 2012 12:18 pm
Not the battery, just the battery mount... It is standard with the internal wiring harness.... Just cut the mount off the harness and join the battery on at this point, leaving the charging connector in place
PostPosted: Sun Jun 03, 2012 12:30 pm
http://www.amazon.co.uk/gp/product/B005 ... 05_s00_i00
PostPosted: Sun Jun 03, 2012 8:07 pm
Ah thanks a lot, makes sense. I was a bit confused because I don't have a balance charger, just a generic lipo battery charger (2 pin setup). Gonna see if I can exchange it for a 3 pin balance charger, this seems like the cleanest solution :)
PostPosted: Tue Jun 05, 2012 11:45 am
Dammit wrote:
http://www.amazon.co.uk/gp/product/B005 ... 05_s00_i00" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Here's version two the battery. Now with 18mm carbon fibre tube & capped with resin/micro-balloon slurry. weight is down to 60g.Image
PostPosted: Thu Jun 07, 2012 12:23 am
Just got the internal harness in today. Lucky I ordered the harness that has an extra long wire for the seatpost battery :D looks like it will fit perfectly.
Cut off the battery wire and I see there are two red two black. I'm assuming there are 2x positive/negative from the same power source, is that correct? If so it looks like all I have to do is solder the positive and negative to the battery 2 leads to one. Seems logical, just wanna be 100% sure!
Thanks for the help guys :D
PostPosted: Thu Jun 07, 2012 1:15 pm
Version 2 looks good Pete, when can I get my hands on one?
PostPosted: Thu Jun 07, 2012 3:07 pm
Yep
There are no new unread posts for this topic. Cervelo S3 2014 - Internal battery conversion
Xcessiv
Wed Feb 15, 2017 12:01 am
hambini View the latest post
There are no new unread posts for this topic. SRAM etap connector type
motd2k
Tue Jan 17, 2017 12:14 pm
motd2k View the latest post
There are no new unread posts for this topic. Finishing handlebar tape with RS910 handlebar junction connector
raggi
9
1067
Wed Aug 02, 2017 4:28 pm
dfischer1 View the latest post
There are no new unread posts for this topic. Campagnolo EPS V2 Battery Repair
Diverse
Sun Mar 19, 2017 5:11 pm
ferrarista View the latest post
There are no new unread posts for this topic. Di2 battery drain problem
quango2k
Tue Feb 21, 2017 1:30 pm
Pokerface07 View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Squashednuts and 43 guests
