It is currently Thu Nov 23, 2017 9:49 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sun May 27, 2012 8:15 pm
all comments will be really apreciated . :D
PostPosted: Mon May 28, 2012 3:29 pm
Administrator
not the pro version, but the team one. they have the same saddle cradle iirc.
viewtopic.php?f=3&t=69718
Quote:
PostPosted: Mon May 28, 2012 4:22 pm
Had one (Team version) and hated it. It looks nice but the clamp was crap. Would probably have kept it anyway but the design means the saddle has to sit further back than most 25mm set back posts, which didn't work for me.
Blog: http://thesetbackpost.com/
PostPosted: Mon May 28, 2012 4:46 pm
Same here; absolutely hated the clamp.
My Bikes
My Photoblog
PostPosted: Mon May 28, 2012 7:48 pm
I can agree with the previous posters. I have the Team-version and the clamp is not ok. It's a pain to set up, my post has been creaking for ages (not in the frame, but the clamp-part) and I am thinking about replacing it with a Fizik post.
PostPosted: Mon May 28, 2012 10:34 pm
I have the LTD. I concur on clamp crapiness. Thomspn clamps are primo..
PostPosted: Mon May 28, 2012 10:41 pm
another vote for crappy clamp, i have the LTD
PostPosted: Tue May 29, 2012 3:37 am
another vote for really annoyed with the clamp on the team dorico here...
PostPosted: Tue May 29, 2012 1:02 pm
had a 27.2 team on my last steal bike and 31.6 pro now.
if you look at the weights, team isnt really worth it weight savings wise, the alu one is heavy but the team isnt light either. if you want carbon for compliance reasons then fair enough.
and also yes, echoing everyone else, wish i had have spent more time with the first one, so i didnt buy again, its an attractive seat post, but the clamp is pretty average. too much set back, can work loose if not set up correctly, my saddle seams to work it self into a nose down position too.
kinda seems obvious why they have 2 types of offset seat posts once youve used a Dorico for a while...
PostPosted: Tue May 29, 2012 3:05 pm
I have a Dorico Team. I really didn't mind the clamp, and it didn't creak or give me any problems. From some other post I learned that you can only really tighten the front bolt and you have to be satisfied with having the rear bolt "as snug as you can without changing the tilt. "
So I used loctite on both bolts, set the tilt with the rear bolt, then tighten the front bolt as tight as I dared, followed by a final check on the rear bolt.
I recently changed to a Thomson setback, but mainly because it was so much lighter (~160 gms vs ~240 gms) The Thomson does have a much more robust clamp system also.
PostPosted: Thu May 31, 2012 3:15 am
I have a Team and a Pro. Neither is superlight, but I like the clamp as I wanted the extra setback. The lower part of the clamp is also quite long (longer than most), so there is lots of support for the rails. The two bolt clamp is a bit of a hassle to get setup, but it lets you set the saddle angle very precisely, it hasn't slipped and no creaks. Once set I haven't had to touch it.
AC
There are no new unread posts for this topic. Canyon US purchase experience
Pschnei3
Thu Sep 14, 2017 9:24 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Carbon Ti \ DA9000 chainring experience?
itsacarr
Fri Sep 01, 2017 5:30 pm
itsacarr View the latest post
There are no new unread posts for this topic. Tune Schwarzes Stuck, any experience?
Penthousepete
Wed Oct 11, 2017 2:32 pm
Penthousepete View the latest post
There are no new unread posts for this topic. Attachment(s) Tifosi SS26 Aero Experience?
MikeyBE
Wed Jul 19, 2017 3:56 pm
MikeyBE View the latest post
There are no new unread posts for this topic. Who has first have experience with Mavic Cosmic Ultimate/Pro shoes?
savechief
Fri Nov 03, 2017 1:51 am
savechief View the latest post
Users browsing this forum: -Robin-, Discodan, Google [Bot], Hexsense, Littlemad, Monkeyfudger, nephron and 38 guests
