It is currently Fri Jan 19, 2018 12:23 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sat May 26, 2012 8:14 pm
I've got PowerCordz Prime cables and housings on my ee brakes but suspect that other housings might work better (less drag) than the PC housings. Does anyone have succcessful experience mixing PC Prime brake cables w/other housings, ie I-Links, Jagwire, etc.?
How about for derailleur cables: any positive experience using other brand housings w/PC cables?
Cheers,
John
Wilier Cento1 SR
13.10 lbs (5.95 kgs) w/Enve 3.4-Tune 70/170 & Conti Competitions tubulars
12.53 lbs (5.68 kgs) w/FarSports 24-Extralite & Vittoria CX EVO II tubulars
PostPosted: Sun May 27, 2012 3:35 pm
I bought the Powercordz Nokon Liners from Fairwheel to use with my Nokon Cable Set and they seem to work well. I think you could probably use it on other cable systems though I am not sure. Ultimately, I ended up going back to steel cables because I could not get the Powercordz to fasten well enough to my EE Brakes. I tried the little blue rubber groumets but could not get it to work to my satisfaction. If you come up with a better solution I would love to hear about it. Mark
PostPosted: Sun May 27, 2012 4:17 pm
as above, nokon
the nokon liner is way better than the powercordz one, especially for the brake cables
PostPosted: Sun May 27, 2012 6:11 pm
While ago I had PC working with Nokon on my mtb bike, no issues.
Recently I've been using PC with Jagwire housing (brakes and dlrs) on road bike, with no issues.
Now I am on PC paired with Niro alloy housing and as above it works fine.
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Sat Jun 09, 2012 12:11 pm
sungod wrote:
as above, nokon
hang on a sec, i must've had my brain in neutral when i posted the above
the powercordz nokon-compatible liner is the good one (was transparent blue, i think it's now transparent yellowish), it's the stock nokon liner that is poor (black stuff, tight, and gets kinked inside the nokon segments over time)
so just to be clear, that's pttthhbbb to nokon liner, and hurrah for powercordz liner
PostPosted: Sun Jun 10, 2012 2:34 am
I suggest trying out the Alligator iLinks. I have used both iLinks and Nokons and I find the iLinks a lot easier to work with.
PostPosted: Mon Jun 11, 2012 3:43 pm
I found that the Power Cordz outer worked very nicely- in back to back (literally, the rear brake is still using iLink housing) testing there is noticeably less drag with the PC housing than the Alligator iLink, 7970 levers to EE brakes.
There are no new unread posts for this topic. ee brakes + powercordz
sungod
9
1368
Sun Mar 12, 2017 2:03 pm
mdeth1313 View the latest post
There are no new unread posts for this topic. Sram red 22 and segmented housing
NiFTY
Tue Sep 12, 2017 3:54 am
dereksmalls View the latest post
There are no new unread posts for this topic. Setting up AX3000s with Tune housing
4ibanez
Fri May 12, 2017 5:23 am
shimmeD View the latest post
There are no new unread posts for this topic. Fluo brake cable housing?
jever98
Wed Mar 15, 2017 7:11 pm
Kurets View the latest post
There are no new unread posts for this topic. Jagwire XEX-SL and KEB-SL derailleur and Brake housing
tommasini
Mon Jan 01, 2018 4:44 am
Mep View the latest post
Users browsing this forum: AZR3, Baidu [Spider], Bing [Bot], djel, Google [Bot], jpshorts, sugarkane, toshi, Yahoo [Bot], Zitter and 34 guests
cron
