New Headset Baseplate needed?
Do I actually need a new baseplate when installing a new fork on my bike? Assuming the original baseplate is being removed from original fork probably and there is no plan to re-use the old fork. The HS is Chris King 1 1/8 and the baseplate is in stainless stee.
By "Baseplate" do you mean Crown Race?
Yes. CK call its crown race=baseplate
The crown race (what you're calling the baseplate) is actually matched with the headset, not the fork. It should follow the headset, and if the fork is re-used, the headset that is installed should have its own crown race. However, I believe that crown races are functionally equivalent if they're from the same type of headset - for example, one IS41's (aka cane creek type) bearing angles are the same as another, therefore the crown race should have exactly the same angled contact surface.
Maybe I should rephrase my question:
I'm putting in a new fork. Is there any reason that I should not recycle the existing crown race?
- prendrefeu
- Contact:
While you're at it, and since this is WW, get the Ti "baseplate" from Chris King.
It's lighter, and therefore righter.
- Similar Topics
- Replies
- Views
- Last post
- 3 Replies
- 734 Views
Last post by stormur
Fri Aug 11, 2017 6:15 am
- 8 Replies
- 925 Views
Last post by stuh
Sat Nov 11, 2017 2:59 am
- 5 Replies
- 610 Views
Last post by TonyM
Mon Jan 08, 2018 7:39 am
- 15 Replies
- 717 Views
Last post by Marin
Tue Feb 13, 2018 11:32 pm
- 9 Replies
- 924 Views
Last post by addictR1
Thu Aug 31, 2017 7:18 am
