It is currently Sun Jan 21, 2018 5:57 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
PostPosted: Sun May 20, 2012 2:18 am
I have the option to choose between an
Standard bar and a aero bar. Can anyone share with me any diff? Aero bar is a bit heavier. I
Have to seriously consider a bar for my new bike and 1st time to road.
And I have the option between
1) ritchey super logic 2 - standard
2) Easton ec90SLX3 standard and aero
3) 3t - one of the lightest but can remember which model.
Any advise.
PostPosted: Sun May 20, 2012 12:39 pm
assuming you are talking about standard drop bars with an aero profile, rather than full-on aero bars, in a review that zipp references on its website it says c. 5w saving with vukasprint bars
for wheels, zipp usually quotes based on riding at 300w at 48km/hr
presumably the 5w came from zipp and is based on a similar screnario, so if you ride fast for a long time, there'll be some benefit, but it's not huge
the blurb for easton aero ones seems to say the aero benefit comes from changed rider position, i can't see the bars themselves beating the zipp ones for drag
fwiw after finding lighter bars/stem too flexy (deda newton bars, zero 100 stem), i accepted that i needed to go heavier if wanted stiff, experimented and in the end i got a cinelli ram2 integrated, the extra weight was well worth it, no flex at all
now some say the zero 100 is a stiff stem, but of course it depends on your weight, power, riding style etc., if you do put a lot of oomph through the bars on hard climbs or sprints then it's something to consider
PostPosted: Tue May 22, 2012 9:54 am
worth learning about :thumbup:
like us on facebook
yishun bike: cost-effective carbon wheels/frame/bike parts
PostPosted: Tue May 22, 2012 12:21 pm
And how I have the option to use deda 35mm
PostPosted: Tue May 22, 2012 6:18 pm
Please excuse my thread-jacking, but does anyone have some numbers for watt savings with dropbars and aero clip-ons/extensions vs actual flat TT bar, when riding in the same position on the extensions? Ie, how much will the un-used drops with STI's/brifters hold one back, compared to wing shaped TT basebar with just aero brake levers?
The Shivenge
PostPosted: Tue May 22, 2012 6:45 pm
I genuinely think the fastest one is whichever is most comfortable for you. If the bar can keep you in a good position over the course of a ride, you'll almost certainly earn back that 5w savings.
If all are equal on comfort, then go for aero or lightest or stiffest as your priorities dictate.
PostPosted: Tue May 22, 2012 8:34 pm
:thumbup: :thumbup: :thumbup: :thumbup:
Best post ever on this forum...
PostPosted: Wed May 30, 2012 12:02 am
i ended up with this stem and bar
File comment: i ended up with this!
PostPosted: Wed May 30, 2012 2:01 am
Nah...
This is.
PostPosted: Wed May 30, 2012 1:21 pm
Numbers in the order of about 30-40w, depends how narrow you are and how good the aerobar is too! Its quite a lot of tubing/sti sticking out in the wind.
PostPosted: Wed May 30, 2012 3:11 pm
Holy cow! I would have figured it'd be closer to one third of that, tops.... The TT-bars are going on the roadbike ASAP. Rarely use the drops since I got the extensions anyway. Having to reach for the shifters when on the "hoods" seems very minor compared to 30+ watts when on the gas...
The Shivenge
PostPosted: Wed May 30, 2012 3:34 pm
Are the Zipp data with or without a rider? Since rider is drafting behind bars seems it would make a big difference.
I don't understand those 35 mm bars unless you're a 100 kg sprinter or have very wide shoulders. A bit of bar flex acts as suspension. There can be too much, perhaps, but those seem way overkill.
Sent from my ADR6300 using Tapatalk 2
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Fri Jun 01, 2012 4:16 pm
I can't believe the drops will generate 30-40W of drag ... e.g. 1/8th of the threshold power of a decent amateur ?
PostPosted: Fri Jun 01, 2012 8:19 pm
That sounds high to me. Of course it depends on speed.
For instance, going from a Specialized Tarmac with clipons on a handlebar to a Specialized Transition with a tt setup and otherwise the same variable you get a 20 watt advantage and that is divided up between the frameset, position and then the better aerobar:
http://www.bikeradar.com/gear/article/h ... ero-19273/
So maybe more like 5 watts at 25mph?
PostPosted: Fri Jun 01, 2012 8:37 pm
I never use the drops so I went this way.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
There are no new unread posts for this topic. Wich TT size is best (huge diff in BB drop !!) ?
LouisN
Mon Jan 15, 2018 4:16 am
alcatraz View the latest post
There are no new unread posts for this topic. 3T Ionic 0 LTD Seat Post Diff Lock Break
lw11
16
1262
Sat Apr 15, 2017 2:15 am
DuncanS View the latest post
There are no new unread posts for this topic. Aero bars on non aero race bike
gurk700
19
4561
Wed Jan 03, 2018 7:29 pm
Chans1ee View the latest post
There are no new unread posts for this topic. Lightweight Standard III Clincher- Tire width???
Berryrice
Wed Aug 09, 2017 10:58 pm
Berryrice View the latest post
There are no new unread posts for this topic. Fuji SST 1.0 Aero set up
jchehan
Mon Feb 27, 2017 9:49 pm
Allen254 View the latest post
Users browsing this forum: Delorre, em3, leej88, lovemyway, micky, tnc1970, wheelbuilder, wobbly, Yahoo [Bot] and 41 guests
cron
